Max to D::light via OSC
8 years 5 months ago #16576 by vinnyj
Max to D::light via OSC was created by vinnyj
Hi, I am trying to control D::light (version 4.0.14) from Max, and specifically activate several submasters using the TIME. I've been able to control it with the following OSC messages (an example to activate the TIME on the 3rd Submaster:
/sub/page 1
/subStick/flash 3 255
/subStick/flash 3 0
will turn it on when I press it the first time, and off the second time.
However, when I try this for a second page, it will go to that page but crash.
Some questions:
* D::Light won't respond anymore. It seems to me that I'm only able to control one page. Is that true?
* Is there a way to do it so that it doesn't flip to a page visually when sending OSC commands from Max? So that we can run 10 faders with Max and the rest manually.
Any suggestions are greatly appreciated. Thanks.
8 years 5 months ago #16581 by sl1200mk2
Replied by sl1200mk2 on topic Max to D::light via OSC
Hi Vinny,
first, substick command are designed to work with te active submaster page.
It means that if active submaster page is 1, substick 1 will control submaster 1. If active submaster page is 2, substick 1 will control submaster 11.
Thus, there's only 10 substick available.
in the coming 4.0.19, I've put more check or DL to not crash when user is asking for substick > 10.
hope it's clear for you...
If you want to control submasters that are not displayed, you should use :
/sub/flash 13 255
(please note that in the 4.0.19 release I've allowed several OSC messaging types, you'll be able to use /sub/13/flash 255, or /subStick/3/flash 255)
Time to create page: 0.126 seconds
