Astera Titan Tube in 4 pixel mode
3 years 4 months ago #25344 by SaFaRi187
Astera Titan Tube in 4 pixel mode was created by SaFaRi187
Hello!
Yet again another question.
I am working with several Astera Titan Tubes for an upcoming show.
The are in Mode 23 (Dim RGBAW 4 pixels).
So the full bar is divided in 4 pieces (each with their intensity and RGBAW).
See also attached personality file.
The problem is as follows. When I change the intensity in a cue, only the parameter dimmer is affected, not dimmer_2/4, dimmer_3/4, dimmer_4/4.
So only the level of the first segment of the bar is controlled by the level in a cue, not the full bar (the other 3 segments).
Any solution to this?
Or do I miss something?
Thanks in andvance!
B.
3 years 4 months ago #25345 by SafeTilt
Replied by SafeTilt on topic Astera Titan Tube in 4 pixel mode
you need to create a device for each RGBAW Dimmer group. Split your tube as needed.
The following user(s) said Thank You: SaFaRi187
3 years 4 months ago #25346 by SaFaRi187
Replied by SaFaRi187 on topic Astera Titan Tube in 4 pixel mode
That's indeed the solution for me.
Stupid that I didn't think of it myself...
Thanks for helping me out!
Time to create page: 0.122 seconds
