Par Led sans dimmer
5 years 4 months ago #21719 by Von Zurich
Par Led sans dimmer was created by Von Zurich
Bonjour
J’ai un soucis avec des pars led qui n’ont pas de dimmers.
Lorsque je crée une mémoire avec un rouge par exemple et que dans la mémoire d’après je veux bêtement qu’il se coupe, j’ai beau updater ou ecraser la mémoire d’après il ne se coupe pas.
Des que je clique sur update le projo se remet en paramètre rouge a fond.
Je ne comprends pas pourquoi ce paramètre ne reste pas à zéro...
5 years 4 months ago #21721 by celio
Replied by celio on topic Par Led sans dimmer
Dans ta création de device tu dois ajouter le paramètre virtuel intensity.
Bonne journée. Celio.
5 years 4 months ago #21726 by sl1200mk2
Replied by sl1200mk2 on topic Par Led sans dimmer
Comme l'a dit @Celio il faut que tu coches 'virtual Intensity' pour tes sources dans le device Listing.
Dès lors le move in black fonctionnera mieux et tu pourras gérer tes sources normalement.
Dis nous si c ok.
5 years 4 months ago #21729 by Von Zurich
Replied by Von Zurich on topic Par Led sans dimmer
Ok je vais tester.
Merci a vous.
5 years 3 days ago #22264 by Woody Guthrie
Replied by Woody Guthrie on topic Par Led sans dimmer
Hi!
I've to work with some RGB PAR LED without general dimming ch and I've created the personality with the personality editor. 3 ch/3 colors. But when I open it in the device listing there is no option for virtual intensity.
Any suggestion?
Thank you!
5 years 3 days ago #22265 by sl1200mk2
@woody
Which version of DLight are you using?
There should be a column in the device listing where you can click on a box to virtualize dimmer.
5 years 3 days ago #22266 by Woody Guthrie
Hi! Is an old one. 4.0.0_b54.
5 years 3 days ago #22267 by celio
It’s difficult to have New features with old versions…
Last versions is really really better.
Best regards
Celio.
5 years 2 days ago #22270 by Woody Guthrie
No doubt! I've use the last one version with another company. But here things are different.
Thank you!
5 years 1 day ago #22284 by sl1200mk2
@Woody,
you can deactivate the licence key from the other company's computer (if they don't tour) and use it with another one.
Thus you can use latest DL version for both.
Time to create page: 0.159 seconds
