4.5.10
1 year 10 months ago - 1 year 10 months ago #27784 by sl1200mk2
4.5.10 was created by sl1200mk2
Here's landing D:Light 4.5.10 for every supported systems(aka macOS, Windows, Linux, raspberryPi64bits). Windows version tagged x86_64 is for Intel processors.macOS version tagged Native is for Intel processors.
macOS version tagged Silicon is for Apple M* processors.
This is a huge release (with lots of bugFixes) as it introduces new execution commands for Submasters.
news:
  • Submasters:
 several new executions mode are proposed // plusieurs nouveau mode d'exécutions des Subs sont proposés:
-HTP : The content of the sub will appear when levels are above the scene's levels. // Les niveaux provenant du Submaster n'apparaissent que lorsqu'ils dépassent ceux de la scène.
-STP (softLTP) : The content of the sub could fade the scene's levels to reach its own levels. //  Les niveaux provenant du Submaster atténuent les niveaux de la scène jusqu'à leurs niveaux.
-SUP (Super) : Submaster's content cannot be lowered // Les niveaux provenant du Submaster ne peuvent pas être réduits.
-DIR (Direct) : Submaster's content are immediately flushed to scene // Les niveaux provenant du Submaster sont directement appliqués à la scene indépendemment du niveau d'ouverture du Submaster.
-MAD : This mode is designed to work with DMX Input that comes from MadMapper // Ce mode est à utiliser lorsque MadMapper génère un flux DMX et récupéré par l'InputDMX des protocoles sACN ou artNet.
-NUL : This mode temporarily disables the Submaster's output // Ce mode désactive temporairement la sortie du Submaster.-
XTP (Custom) : This mode allows the use of other modes for specific attributes (e.g., Intensity, Colour, Focus, etc.) // Ce mode permet d'utiliser les autres modes pour des attributs spécifiques (e.g., Intensity, Colour, Focus, etc.).
In practice, HTP and STP are useful for conventional lighting. When devices are in use, you'll want to use XTP, as intensity is managed in HTP while parameters are handled in STP. // En pratique vous allez génaralement utiliser les modes HTP ou STP pour le trad tandis que quand des Devices sont en jeu vous voudrez généralement utiliser le mode XTP qui combine HTP pour l'intensité et STP pour les paramètres.
of course those new modes can be toggled by Midi and OSC (/subStick/xx/execMode @s et /sub/xx/execMode @s) // Ces nouveaux modes peuvent être modifiés par des messages Midi et OSC.
  • Palette Editor:
 There's a new 'Reference Palettes' button which allows you to reference other palettes for selected parameters // Un nouveau bouton 'Reference Palettes' dans le Palette Editor vous permet d'assigner d'autres Palettes pour les paramètres sélectionnés.
++bugFixes&&improvements
Enjoy,
Nicolas
Last edit: 1 year 10 months ago by sl1200mk2.
The following user(s) said Thank You: Poypoy
Time to create page: 0.302 seconds
