4.4.14
2 years 6 months ago - 2 years 6 months ago #26703 by sl1200mk2
4.4.14 was created by sl1200mk2
Here's landing D:Light 4.4.14 for every supported systems (aka macOS, Windows, Linux, raspberryPi64bits).
Windows version tagged x86_64 is for Intel processors.
news:
  • Palette
- new 'Import From Sho' / 'Import From File' function (from the File menu)  let you merge Palettes // deux nouvelles fonctionnalités  'Import From Sho' / 'Import From File' accessibles depuis le menu File vous permettent de faire du merge de Palettes.
- new 'Paremeter(s) Level(s) Propagation' function (from the Palette menu of the dynamicBottom) that let you massively modify parameter's levels for one or all palettes // nouvelle fonction 'Paremeter(s) Level(s) Propagation'  (accessible depuis le menu Palette du dynamicBottom) qui vous permets de massivement modifier les niveaux d'un ou de plusieurs paramètres pour une ou toute les Palettes.
  • device Listing
- new way to Load Devices wher eyou can define the number of Devices to load and even to Patch them // lors du Load de Devices vous avez dorénavant la possibilité de définir le nombre de machines à charger et même de les Patcher.
and many fixes && improvements
Enjoy,
Last edit: 2 years 6 months ago by sl1200mk2.
2 years 6 months ago - 2 years 6 months ago #26710 by sl1200mk2
Replied by sl1200mk2 on topic 4.4.14
D::Light 4.4.14-2 is online.
This is mainly a IKCM release (In Kurt Cobain's Memory)...
It contains a small fix for Device's definitions with an Hold timing that was not honoured.
Also it add the ability to patch a MIDI Note to a specific ringBuffer Item and complete Preset overwrite from the Preset Editor
Time to create page: 0.114 seconds
