4.4.12
2 years 7 months ago - 2 years 7 months ago #26664 by sl1200mk2
4.4.12 was created by sl1200mk2
Here's landing D:Light 4.4.12 for every supported systems (aka macOS, Windows, Linux, raspberryPi64bits).
Windows version tagged x86_64 is for Intel processors.
news:
  • Device's Library
In the SetUp/Devices you'll be able to load inside the software an updated file of Devices personalities // dans le setUp/Devices vous pourrez dorénavant charger des mises à jour de la bibliothèque des personnalités de Devices.
  • Palette Parameters
a new option is available under the Palette menu of the dynamicBottom that let you 'propagate levels' to one/many parameters of all registered Palettes // une nouvelle option 'propagate levels' est disponible dans le menu Palette du dynamicBottom pour assigner un niveau à un/des paramètres sur toutes les Palettes existantes.
++ many fixes && several improvements
Enjoy,
Nicolas
Last edit: 2 years 7 months ago by sl1200mk2.
The following user(s) said Thank You: noelvd
Time to create page: 0.187 seconds
