4.1.09
6 years 7 months ago - 6 years 7 months ago #19806 by sl1200mk2
4.1.09 was created by sl1200mk2
D::Light 4.1.09 is online.
available for every supported 64bits systems. (Mac, Pc, Linux, raspberryPi4)
  • SetUp
  • -new Splitted 'UI' mode // nouvelle interface 'Splitted' pour la fenêtre principale
  • Fixes&&Improvements
  • Enjoy,
    Last edit: 6 years 7 months ago by sl1200mk2.
    The following user(s) said Thank You: quico
    6 years 7 months ago #19807 by SoundSurfer
    Replied by SoundSurfer on topic 4.1.09
    splitted mode gives me a window i cannot change the size of and is almost only the title bar..
    .sho is called 'Patroon Jannes.sho'
    on mac OS 10.15.3
    6 years 7 months ago #19808 by sl1200mk2
    Replied by sl1200mk2 on topic 4.1.09
    @soundsurfer,
    Hi,
    can you please post the Patroon Jannes sho?
    6 years 7 months ago #19809 by SoundSurfer
    here you are
    6 years 7 months ago #19810 by SoundSurfer
    it only occurs when you change from attached to splitted, but not when you change from detached to splitted
    6 years 7 months ago #19811 by SoundSurfer
    also, perhaps its time you change the screenshot of d::light on the getdlight website, to the current version, so its looks cooler ;-)
    6 years 7 months ago #19812 by sl1200mk2
    Hi Jannes,
    so I've updated the front page of the web site, you were right it's better :)
    I've tested patroonJannes and in no way I succeed to reproduce your issue. going back and forth from attached/splitted/attached/detached/splitted, everything is good here. macOS 10.15.3 also
    so there must be something but I don't know what...
    ++ and take care
    6 years 7 months ago #19824 by SoundSurfer
    funny enough, i restarted my macbook, and now I cannot re-create it.
    perhaps it has something tot do that the original .sho file was created with an older version of dlight, but im not sure. Also, I am running "bettersnaptool" on my macbook, which enables me to easily give certain windows a fixed place on my screen..
    keep safe! (physically and financially!)
    6 years 7 months ago #19872 by anatol
    Replied by anatol on topic 4.1.09/4.1.06 ubuntu release
    i was using the 4.0.0_b72 ubuntu version on manjaro/arch linux with a 5.4.26-rt17 kernel running through an enttech pro usb box and everthing was fine.
    when i switched to the licensed version (4.1.06) it broke a few things:
    - gtk libs gave a few errors (no big deal, just version conflicts and easily solved with a few symlinks and costum libs)
    - the enttech box went wild and sent out random dmx values (i had to switch back to the beta version since did not find any apparent cause/solution)
    1. did anyone have similar problems?
    2. (follow up) has the problem been addressed in the most recent version?
    6 years 7 months ago #19873 by sl1200mk2
    @Anatol,
    4.1.09 is released also for Linux, did you try it? I think this version is really better than the 4.1.06.
    this is weird as DL does not use gtk... it does use glibc but that's it.
    which lib gave you trouble?
    using 4.1.09, you'll need a licence in order to have a clean DMX.
    when you launch DL, it should tell you (in the upper right part of the software) if it's running in DEMO mode (DMX is shitty) or if it is licensed.
    6 years 6 months ago #19874 by anatol
    gtk was a typo, i meant glib.
    with the 4.1.09 i can't seem to get out of demo mode.
    it might have to do with this error message:
    ../DLight-64-Linux/bin/libuuid.so.1: no version information available (required by /usr/lib/libfontconfig.so.1)
    maybe if you'd package the linux version in something like appimage or snapcraft (not my first choice) it would save a lot of trouble.
    when i tried to get the b72 to run on debian 64 i got nowhere because of lib version conflicts.
    6 years 6 months ago #19875 by sl1200mk2
    @anatol,
    Hi,
    how do you try to run DL? using the script.sh I provide?
    because this script should link the exe against lib I distribute. this way, there should not have any lib conflicts (except the glib one of your computer).
    6 years 6 months ago - 6 years 6 months ago #19876 by anatol
    hi,
    yep, i run it via the shell script (after the chmod +x DLight.sh thing)
    i've got the several versions in different folders in my home mount
    so far only the b72 version runs and behaves like it should except the non graceful exit: it hangs on the "close struct".
    Last edit: 6 years 6 months ago by anatol.
    6 years 6 months ago #19877 by sl1200mk2
    ok,
    so just to be clear on this topic.
    you run 4.1.09, but DMX is crappy? _ right? you need a licence.
    you run 4.1.09 and your system complain about bad libuuid? _ right ? if so, I'll recompile libuuid for DL 4.1.10_b3
    6 years 6 months ago #19888 by anatol
    yes, libuuid seems to be the issue while activating the license, at least on the manjaro system
    (5.4.26-rt17-MANJARO #1 SMP PREEMPT_RT Sat Mar 21 18:11:27 UTC 2020 x86_64 GNU/Linux)
    Time to create page: 0.230 seconds
