4.0.25_RC5
7 years 10 months ago #17693 by bgoubert
Replied by bgoubert on topic 4.0.25_RC5
@nico
Bugs
Si j'ai une fenêtre déjà ouverte et que j'utilise le bouton attributes,: freeze & fucking wheel. Forcer à quitter obligatoire.
Window size : small & medium = écran noir.
Crash sur save (voir report).
A l'ouverture, systématiquement load backup, mais ne fonctionne pas. video par mail.
Esc : shorcuts don't exist, ne fonctionne pas video par mail
Crash sur des modifs dans shortcuts. (voir report)
et quand pas crash franc, fenêtre principale disparait, il reste juste shortcuts mais figée, forcer à quitter.
Remarques
Un truc un peu chiant, quand tu ouvres une fenêtre genre D8 ou T8 elle s'ouvre en tout petit.
A propos du switch dB/ Masters, c'est peut-être con, mais pourquoi ne pas rajouter une ligne dans le bouton Attribute, permettant de passer par masters ?
to be continued...
bruno
7 years 10 months ago - 7 years 10 months ago #17695 by dFVarela
Replied by dFVarela on topic 4.0.25_RC5
Hello:
Here goes my small tests done so far(Win7 Home Premium), and some thoughts:
-ESC key doesn't work in DynamicBotton,it would be more useful you can switch between DB and SUBS (uPalletes levels are not showned in DB or in Devive Command)!
-If double clicking in a channel or a sub sets the level written in the command line, shouldn't it set also on DB and in DC?
-Enter key for selecting channel is OK, but i think the logic would be selecting Sub, channel or group depending on what mode you are working!
-When opening DLight always appears the error message and asks if BackUp file is to be loaded, if answering yes nothing happens!(When double clicking on a file or opening from start menu)
-Double pressing BackSpace deselects channels is it a bug or an undocumented feature?(Nice anyway!)
Attached a log, when Bound to chaser in Pallete Listing!
For now that's all!
dFVarela
File Attachment:
File Name: Error1.txt
File Size:836 B
dFVarela
Last edit: 7 years 10 months ago by dFVarela.
7 years 10 months ago #17697 by sl1200mk2
Replied by sl1200mk2 on topic 4.0.25_RC5
merci pour vos prompts retours....
tous les crashs que vous mentionnez sont dues à la gestion du fenetrage et la compatibilité avec Mojave... grosso modo je pense que c'est pas encore prêt...
je vais donc sortir la 4.025 sans la native et continuer à bosser dessus.
@celio,
Le esc marche bien ici pour le DB mais il affiche shortcut does not exist
yep, j'ai vu
Par contre passe en fenêtre principale pas quand on le coche mais quand on le décoche.
bien vu...
Erreur quand réglage du pan tilt à la souris via le point rouge milieu du Device command (cf pj)
ok
Liblo server error 9904 quand je veux activer l’osc cf pj
c'est qu'il y a déjà qqun qui écoute sur le même port que DL
Très long délai d’affichage de la liste de couleur pour les sub dans le sub editor + choix de couleur problématique cf pj
pour le choix des couleurs c'est fixed, pour le temps d'affichage de la liste des couleurs ici c'est immédiat.... Je vais essayer de comprendre pourquoi ça peut être très long...
@aroom
ps: j'ai un gros problème avec le forum, il est toujours cassé sur safari, ya plein d'aberration au niveau de l'affichage, dont un gros problème avec les pièces jointes, c'est une vrais misère à les ouvrir, voir impossible. quand je passe la souris dessus, la pièces jointe bouge et je peux pas l'ouvrir...
c'est la template du site qui fait ça... p-e qu'il faut en changer du coup...
@bruno
ça je pense l'avoir fixé
mais ça je comprends toujours pas...
le bouton de switch permettrai d'afficher les subs sans avoir à déselectionner les devices, c'est ça?
@Daniel
will try on windows but the purpose of Esc (for now) is to reset focus of selection to the main panel (aka channels).
for example, select a device, you can do == to set the level.
now in the dB, select a column or a cell, you can do == to the new selection.
the purpose of Esc is to reset the dB selection to gain access again to == for the channel's panel.
yes it should...
you're absolutely right
yep... I saw and forgot to fix...
an undocumented feature... :)
as 0 c
k
thanks guys!!
7 years 10 months ago #17698 by bgoubert
@nico
that's it.
bruno
7 years 10 months ago - 7 years 10 months ago #17699 by dFVarela
@nico
Great one must say :)!
-ESC key is working but on the information windows appears the message 'Shortcut does not exists'
-If can't delete cue 0, should you be abble to delete pallete 0?
-Opening the DC window, selecting a column and pressing TAB switches bettwen windows.
(Only after selecting a cell switches cell)
-ENTER key should work in DC to select channels also!
-It's great the feature of having a small window whit the dBAttributes(shouldn't be abble to make it full screen), why not make the same whith COM? (For the mouse dependents!)
dFVarela
dFVarela
7 years 10 months ago #17709 by sl1200mk2
@All,
je vous propose Control+Tab pour switcher l'affichage du dynamicBottom
aussi, tant que j'y suis, je vais virer le Shift-Left/Right pour changer le circuit sélectionné. Dorénavant ce ne sera que xx Enter.
l'idée étant de réserver Shift+Left/Right à de la sélection de circuits.
@Bruno,
pas un bouton mais le raccourci clavier Control-Tab.
do u like?
@Daniel,
absolutely no.
this is fixed.
this is by design
agree.
not sure to be able to do that before 4.0.25 though
because everyone should loose the mouse :)
7 years 10 months ago #17713 by dFVarela
@Nico
Seems OK!
And Control+Left/Righ to test @FF channels is GREAT!(or is it another undocumented feature?)
Waiting for 4.0.26 :( B)
Agree but there are always those who don't want to loose it! :(
dFVarela
OffTopic:Will we get a Linux version?
dFVarela
7 years 10 months ago #17716 by bgoubert
@nico
ça me va.:)
bruno
7 years 10 months ago #17725 by sl1200mk2
@all,
la 4.0.25 est publique (j'attends un peu avant de faire l'annonce au cas ou....)
j'ai pas pu tout mettre notamment au regard des différentes combinaisons de touches pour la sélection de circuit, ni le déploiement de xx Enter (pour sélectionner les ch) aux éditeurs.
mais bon :) elle parait quand même pas mal.
autre petite nouveauté les M8, T8, D8 et S8 affichent les textes du pas de séquence qu'ils affichent et pour les M8, les liens sont en couleur si les subs le sont.
bref...
merci beaucoup d'avoir répondu présent pendant toute la phase de dev de cette release !!
c'est dommage pour la Native, mais ce n'est que partie remise.
Time to create page: 0.148 seconds
