4.0.19_b5
8 years 5 months ago #16554
4.0.19_b5 was created by sl1200mk2
changelog is here:
getdlight.com/wiki/index.php/ChangeLog
unless one say so, it should be close to the release.
please test and report,
The following user(s) said Thank You: SoundSurfer
- Morpho
- Thank you received: 1
- SoundSurfer
- Thank you received: 3
8 years 5 months ago #16577
by SoundSurfer
Replied by SoundSurfer on topic 4.0.19_b5
Hey Nico,
Really pleased with all your work so far.
I am currently programming a show with shitty lights (eurolite TMH6 <$130) . they are that shitty that the intensity and the strobe are in the same channel. Also, the dimmer values run backwards.. (made in china....)
Is it possible to:
- add the function to the device editor that you can reverse the dmx values, as long as they add up to 255? what i mean is that you can reverse a section of a dmx channel.
in example: 0-4 closed, 100-5 dimmer, 101 - 245 strobe, 246 - 255 open ...
- have alle the basic Device commands on one page?
- hide commands that are not defined in the fixture file
Thanks in advance!
Is it possible to:
Thanks in advance!
8 years 5 months ago #16582
Replied by sl1200mk2 on topic 4.0.19_b5
@soundsurfer,
Hi,
Thus if you use from 100 and to 5 it will be reversed.
Hi,
not for the 4.0.19, but for the next one, I can work on the Device Editor to be able to add several Attribute/Parameter to the same offset and also make the from-to more consistent.in example: 0-4 closed, 100-5 dimmer, 101 - 245 strobe, 246 - 255 open ...
not easily...- have alle the basic Device commands on one page?
not easily- hide commands that are not defined in the fixture file
- SoundSurfer
8 years 5 months ago #16587
by SoundSurfer
another thing i just noticed,
Can you make it possible to double click any number box to get a FL value, in particular in the device commands window, like with the dimmer value at the home screen?
keep up the good work!
Soundsurfer
Soundsurfer
Time to create page: 0.160 seconds
