4.0.18
8 years 9 months ago - 8 years 9 months ago #16173 by sl1200mk2
4.0.18 was created by sl1200mk2
Here's landing D::Light 4.0.18
(special thanks to all guys who have tested and report during beta cycle)
available for almost every systems (Linux version will be uploaded ASAP... sorry guys for the looooong waiting).
it comes with a long list of new features and bug fixes... they're all listed here:
getdlight.com/wiki/index.php/ChangeLog
but here's a summary:
  • SLinks (pronounce Step Links).
  • -one can send custom Midi or OSC messages per sequence's step. Thus, it allows D::Light to become the master sequencer of your show as it can trigger specific cues/steps in other software.
    -one can also load custom curves for output(s)/channel(s) on every steps of the sequence.
  • Patch:
  • -new 'quick select' option in order to select all outputs patched to selected channels
    -new Channel/Output test shortcut
    -speedUp display
  • Sample:
  • -smart +%/-% which only operate on recorded levels for selected channel(s) over a region or at one frame
  • Sequence:
  • -in the main sequence window, one can now arrange columns as desired
    -new searchBox to quickly find a step/cue associated to a text
  • MasterLink/TimeLink/DeviceLink/StepLink Editor:
  • -one can now select active step
    -more shortcuts
  • SubMaster Editor:
  • -one can now select active submaster
  • Curves:
  • -new design with more powerful editing
  • ShortCuts:
  • -new searchBox to quickly find a shortcut
  • Save/SaveAs:
  • -warning when directory is not writable
  • Force DeviceLink:
  • -one can now use FullForce new option and select which attributes will be recorded
  • Device:
  • -the main window should reflect active color for device. (it works for RGB or CMY colors only...)
  • General:
  • -selection style is now more obvious (yellow square is 'around' selected channels)
  • Palette Editor:
  • -one can move in Palette thanks to the new Up/Down switcher
  • Palette Listing:
  • -Colour Palette are now colored for EZ view
    enjoy :)
    Last edit: 8 years 9 months ago by sl1200mk2.
    8 years 9 months ago #16174 by leoclarys
    Replied by leoclarys on topic 4.0.18
    Merci pour toutes ces améliorations.
    J'ai constaté un petit bug qui est également présent dans la 4.0.18 (OS 12.12)
    Les textes dans les carrés des samples disparaissent quand je relance ma session et parfois quand je change de page. J'ai testé différentes façon d'écrire et ça se reproduit systématiquement, même si j'encode le texte dans la fenêtre sample.
    Bonne soirée!
    Léo
    8 years 9 months ago #16177 by sl1200mk2
    Replied by sl1200mk2 on topic 4.0.18
    salut Léo,
    ah zut.... j'ai oublié...
    bon en même temps, fallait que je la sorte la 18.
    ça sera pour la 19 :whistle:
    8 years 9 months ago #16179 by Morpho
    Replied by Morpho on topic 4.0.18
    Petite question Nico concercnant la release note :
    Palette Listing:
    Les palettes sont sensées être colorées dans la fenêtre palette listing ? Pas le cas pour moi.
    Dans la fenêtre principale c'est vraiment super d'avoir les couleurs sur les charnels des Device. (Même si j'utilise des 7x couleurs ca donne une idée)
    Dlight c'est génial merci !
    8 years 9 months ago #16180 by sl1200mk2
    @morpho
    tu peux poster une photo de ton palette listing, stp?
    voici le mien:
    8 years 9 months ago #16182 by Morpho
    Peut être parce que c'est des palettes créées sur les selador 7x ?
    Pourtant ce fonctionne dans la fenêtre principale
    8 years 9 months ago #16183 by sl1200mk2
    il faut que tu inscrives tes channels dans cette fenetre....
    genre 1 c 10 >
    8 years 9 months ago #16184 by Morpho
    Cool ca fonctionne.
    Par contre ce serait bien si la surface de couleur affichée était plus grande et la couleur orange sur la gauche plus diserte genre gris.
    8 years 9 months ago #16187 by bgoubert
    Replied by bgoubert on topic 4.0.18
    @nico
    super les couleurs sur les palettes. Pour aller plus loin, tu crois que ce serait possible sur le main board display des palettes.
    Autre petite question, il y eu dans le temps une fonction qui permettait de modifier les polices d'affichage, je l'ai recherchée et pas trouvée. Je me suis retrouvé avec un pc de dépannage avec un affichage beaucoup trop grand et donc aucune lisibilité. Y'a-t-il quand même un moyen de modifier cela.
    Me reste à tester toutes les autres modifs pour encore plus de fun.
    8 years 9 months ago #16188 by Morpho
    Tu parles de cette fenêtre Brice ?
    Ca serait bien d'avoir les couleurs oui et le fond des cellules en gris gris foncé comme le reste.
    8 years 9 months ago #16190 by sl1200mk2
    c'est pas possible sur cette fentre car il peut y avoir plusieurs Device sélectionnés et chacun avec une couleur différente par Palette.
    nope... ya plus
    8 years 9 months ago #16197 by leoclarys
    J'ai remarqué que l'affichage en valeur réelle dans la fenêtre Dlink ne fonctionne pas bien, à savoir pour 22 decimals dans le device command il m'affiche 5632 dans la fenêtre Dlink. Je te joins l'image.
    Bonne journée!
    8 years 9 months ago #16200 by bgoubert
    même constat.
    8 years 9 months ago #16201 by bgoubert
    @ nico
    et en reprenant juste les couleurs du palette listing ?
    8 years 9 months ago #16202 by sl1200mk2
    les valeurs des DLinks sont en 16 bits, c'est pour ça que vous voyez des valeurs > 255
    Time to create page: 0.212 seconds
