pre 4.0.0_b67
I've changed:
/circ/level x y (where x is the channel, y the level)
/circ/prepalevel x y
/sub/text x blabla
/sub/level x y
/sub/flash x y
/sub/phase x y.y
all the /subStick messages and also the /device ones
for the devices it looks like
/device s i i (string (/attribut/parameter), int (device numbr), int (value))
I know that all your pd patchs, touchOSC stuff, etc... won't work anymore
but it gain clarity and parsing efficiency.
happy hacking
-added support for usb pro mk2 (revB)
-added wait times to chaser editor $
- vbs
- Thank you received: 1
for instance my submaster 1 use to be;
/subStick/1/level
and submaster 1 tekst;
/subStick/4/text
Should i change this in
/sub/text/1/x
/sub/text/1/y
Records Vincent
/subStick/1/level
/subStick/4/text
now you should use:
/subStick/level 1 xxx (where xxx is the level)
/subStick/text 4 yourTextAsTheSecondArgument
touchOSC does not seem able to handle yet multiple argumentation.
I wrote them in order to ask for this feature, and I guess the more we will wrote to them, the more we will get a chance for this feature to be coded...
I realize that for now we don't have a solution until touchOSC update their code....
please ask them to allow multiple argumentation for sliders/buttons/labels/etc....
the correct sentence is:
/subStick/level x yourText
with a space between level and x and between x and yourText
this is the multiple argumentation
- celio
- Thank you received: 72
Pas sûr de bien comprendre ce que tu entends par xxx si The level (on met du coup la valeur maxi ?)
Pour yourText meme genre de question...
En tout cas je comprends que touchosc ne gère pas la multiple argumentation. Par contre si j'arrivais à comprendre mieux (je ne désespère pas) la nouvelle syntaxe je peux peut être créer un Patch isadora qui lui pourra renvoyer l'info en multi transmit il gère ca a priori.
A plus. Célio.
tu donnes comme premier argument le numéro du sub/circuit/subStick que tu veux controler
en deuxième argument la valeur
dans l'exmple précédent, si je veux le sub 6 à FF j'écris:
/subStick/level 6 255
et si je veux le sub 6 à 50% j'écris:
/subStick/level 6 127
- celio
C'est peut-être complètement con comme question et je m'en excuse
A plus. Célio.
dans ton touchOSC tu vas écrire pour chaque slider:
/subStick/level x (ou x est le numéro du stick) et tu vas laisser touchOSC ajouter la valeur du slider comme deuxième argument.
si tu fais du pureData, tu fais pareil... le premier argument est le numéro du sub que tu veux piloter, le deuxième la valeur que tu veux lui donner.
mais toi tu fais du isadora...
mais ça doit etre pareil.
- Jefff
J'ai l'impression que le texte dans le champ des subs ne reste pas après avoir changé de page de sub et en revenant dessus.
