4.0.0_b65
10 years 6 months ago #12454 by sl1200mk2
4.0.0_b65 was created by sl1200mk2
available for everyone with a new one for ARCHLinux systems (64bits only)
there's enough changes to make an update...
I didn't finished all the clean though...
- the main window has been polished to fit within small screen systems
- you can sample devices
- many many bug/trick fixes
enjoy,
The following user(s) said Thank You: spoutnik16
10 years 6 months ago #12455 by spoutnik16
Replied by spoutnik16 on topic 4.0.0_b65
Hello, here are some features requests/ideas :)
- named channels in the patch menu
- when you hover a channel, you can see the name
- when you start DL, you don't have to start a new show before anything works. That's just not consistent with how any other software works.
- x fader with the mouse
- shortcut for joystick (ie you press X and then your mouse is the joystick)
and a few bugs :
- when saving a pdf, and typing "esc", the soft says "Done !!"
- patch menu -> when you select a channel, and hover the "D-Patch" column with your mouse, it turns into a pen that is useless
10 years 6 months ago #12456 by nosmile
Replied by nosmile on topic 4.0.0_b65
mmh, j'ai téléchargé une b65 il y a 4 jours... c'est la même ou il y a eu une erreur de numérotation???
Sinon, je l'utilise pour une créa (simple) depuis quelque jours et tout tourne. Ceci dis, je n'utilise rien de compliqué et pas les devices donc... (chase, cue et ID mais j'ai fait mes remarques à ce propose dans le sujet de la release b64 vu que c'était le dernier, j'ai oublié que les numéros ne correspondait pas...)
10 years 6 months ago - 10 years 6 months ago #12470 by zenerve
Replied by zenerve on topic 4.0.0_b65
"Arch-Spezial" ... Had to update tk.tcl and init.tcl TO THE ACTUAL, MORE MODERN LIBS YOU PROVIDED YOURSELF...
Whahaha. EDIT : Latest Arch Native is 8.6.4-1 BTW
Those files where stil looking for *.4 :
Code:
[jph@ArchDMX ~]$ sh bin/DLight-64-Linux/DLight.sh Tk_Init failed: Can't find a usable tk.tcl in the following directories: /home/jph/bin/DLight-64-Linux/lib/tcl8.6/tk8.6 /home/jph/bin/DLight-64-Linux/lib/tk8.6 /usr/local/lib/tk8.6 /home/jph/bin/lib/tk8.6 /home/jph/bin/DLight-64-Linux/library /home/jph/bin/DLight-64-Linux/lib/tk8.6/tk.tcl: version conflict for package "Tk": have 8.6.5, need exactly 8.6.4 version conflict for package "Tk": have 8.6.5, need exactly 8.6.4 while executing "package require -exact Tk 8.6.4" (file "/home/jph/bin/DLight-64-Linux/lib/tk8.6/tk.tcl" line 16) invoked from within "source /home/jph/bin/DLight-64-Linux/lib/tk8.6/tk.tcl" ("uplevel" body line 1) invoked from within "uplevel #0 [list source $file]"
Edited them, starts fine now. Suggest you update those files ASAP :-P
New-old thinkpad + Ubuntu + b-65-non-arch had first performance monday, its fine but can reliably crash it with "new" from cold start; loading .sho works.
EDIT : Put my tweaked configs Arch to live business since Tuesday, no issues so far.
Jean-Philippe.
Last edit: 10 years 6 months ago by zenerve.
10 years 6 months ago #12489 by vbs
Replied by vbs on topic 4.0.0_b65
I have some strange behaviors in the Sequence list.
*Let say i am in step 5 que3
In the sequence i give the command steps 11 delete, what happens: is deleting que 3
I know the command is Delete step 11, but if you make a mistake your que is gone.
In other works if you give the command delete in the sequence you delete the cue you are in (red) in stead of the que.
Regards Vincent
10 years 6 months ago #12491 by sl1200mk2
Replied by sl1200mk2 on topic 4.0.0_b65
@zenerve,
distributed tcl/tck in 8.6.5, so +1 regarding to the arch one
but you're right, I need to update listed files
thanx
@vbs
[DELETE] is a primary word in DL, thus if nothing comes after, it will delete the cue (by default) of the active step.
maybe a warning could solve this?
10 years 5 months ago #12503 by Jefff
Replied by Jefff on topic 4.0.0_b65
La b65 fait chauffer mon ordi... Dlight tourne à 100% dans le moniteur système. La b64 non.
Sur mac el captain...
10 years 5 months ago #12504 by sl1200mk2
@Jefff
yes j'ai vu et corrigé pour la b66.
j'ai tenté un truc mais c'était pas bon.... sorry.
10 years 5 months ago #12513 by vbs
I notice that the short cut list is not in the right order.
Que-record and update are mixt up
Regards Vincent
10 years 5 months ago #12515 by sl1200mk2
@Vincent,
thanx...
fixed for b66
10 years 5 months ago #12518 by spoutnik16
Je ne sais pas trop où poster ça, donc je le poste ici, vu que ça a foiré sous b65 (mais je ne sais pas si c'est reproductible ou pas) :
En tournée, je charge mon fichier ASC depuis ma disquette Presto, première date, tout fonctionne correctement. Réglage lumière, première date, tout marche. Je plie mon matos, et part pour le second lieu.
Et en rallumant mon ordi, plus aucun projo ne s'allume. En fait, j'avais toujours mes cues, les noms, les timers, mais elles étaient toutes vides.
Quelques infos sur mon matériel
DLight4.0.0_b65
ordi sous Linux Mint Rebecca 17.1 cinnamon x86_64
conduite ASC importée depuis pupitre AVAB Presto
le tout avec un entec RJ45 (noeud Artnet)
Et j'en ai marre des softs de jeu d'orgue développés par des mecs dans leurs garages, qui buggent, qui n'ont pas de QA (je sors d'une très mauvaise expérience sous LightRegie120). J'ai l'impression de m'être fait floué par sl1200mk2 qui sur IRC m'a conseillé d'utiliser la B65, qui a l'air d'être une RC et pas une stable.
Si on me demande mon avis sur DLight actuellement, tout ce que je pourrais dire c'est que ça ne fonctionne pas.
10 years 5 months ago #12519 by sl1200mk2
ohlàlà... comment t'y vas... floué ?!
tu peux poster ta conduite pour voir?
et le fichier ascii tant que t'y es...
10 years 5 months ago #12520 by totoine
Replied by totoine on topic 4.0.0_b65
Bonjour Spoutnik !
Si tu te sens floué pour un soft gratuit (avec donation ...;)) libre à toi de prendre un jeu d'orgue à plusieurs centaines (voir milliers d'euros...)
Mais la démarche avec D::Light quand tu as un problème, c'est plutôt d'essayer de le résoudre que de demander réparation ...
Et pour info, oui la B65 est comme son nom l'indique une beta !
10 years 5 months ago #12521 by sl1200mk2
je pense que ce qui est important c'est de savoir pourquoi ça lui est arrivé et est-ce que c'est reproductible...
est-ce que c'est spécifique à Linux...
10 years 5 months ago #12522 by totoine
Salut nico !
Petit bug trouvé hier avec un régisseur que j'ai accueilli sous Win64, D::L 4b65.
Dans la petite fenêtre d'info en haut à droite, au bout d'un certain moment d'utilisation (et pas mal de correctif de conduite), lors de la modification de la mémoire, le buffer remontait plus haut.
Par exemple, une fois modifié la Cue 120, la fenêtre remonté pour affiché que la Cue 107 avait bien été modifié, il fallait à chaque fois redescendre pour avoir les dernières infos.
Ca m'a permit de lui expliquer le point rouge/blanc, mais il avait l'habitude de toujours regarder cette fenêtre pour vérifier que ca modification avait été enregistré
Time to create page: 0.177 seconds
