4.0.0_b57
10 years 9 months ago - 10 years 8 months ago #11799 by sl1200mk2
4.0.0_b57 was created by sl1200mk2
available for MacOS systems... and 64bits Windows and Linux
getdlight.com/index.php/forum/2-releases...-pre-4-0-0-b57#11798
enjoy and shout
Last edit: 10 years 8 months ago by sl1200mk2. Reason: more OS
10 years 8 months ago #11801 by Wilf
Replied by Wilf on topic 4.0.0_b57
What is different/new? Couldn't find faults in 56b (yet).
10 years 8 months ago #11802 by sl1200mk2
Replied by sl1200mk2 on topic 4.0.0_b57
Hey Wilf,
I made a gig recently (
) with 15 devices and I realize some stuff can be better... so here's a new one :-)
main news are listed here:
getdlight.com/index.php/forum/2-releases/5782-pre-4-0-0-b57
10 years 8 months ago #11803 by Wilf
Thnx, I used it. Still one thing that I don't know how to do, but maybe it's because I use video projection and the popups aren't moveable and stuck between the screens, unreadable. Thing is: I have a show with conventional lights, so I have 1 channel for multiple lights. Now more and more venues have LED but not always repatchable. So can I put one device (one channel) on multiple addresses somehow?
10 years 8 months ago #11804 by sl1200mk2
I may have make things right... :whistle:
Normally, you can swap a traditional channel with a device.
Just open the device listing, import a device and set it a channel.
10 years 8 months ago #11805 by sl1200mk2
Sorry, i misread...
You can't on several devices.
10 years 8 months ago - 10 years 8 months ago #11809 by Wilf
Ok, thanks. then I'll remake the show with multiple channels. More and more venues here are working with the ETC lights and with a standard light plan and do not want to change the addresses.
Last edit: 10 years 8 months ago by Wilf.
10 years 8 months ago #11810 by bgoubert
Replied by bgoubert on topic 4.0.0_b57
@nico
10.7 OS
Impossible de renseigner les IP dans l'OSC, la flèche ne fonctionne plus.
bruno
10 years 8 months ago #11811 by bgoubert
@nico
c'est revenu après avoir fermé et réouvert la fenêtre setup.
Avec les autres adresses qui avaient disparues.
:huh:
bruno
10 years 8 months ago #11812 by celio
Replied by celio on topic 4.0.0_b57
ça m'avait fait pareil sur la B56 mais je croyais que c'est moi qu'était un peu truffe :)
ce qui d'ailleurs ne veut pas dire que je ne le sois pas un peu quand même de temps en temps à la rigueur....
10 years 8 months ago #11815 by bgoubert
@celio
as-tu aussi les légendes des groupes qui se mélangent ou disparaissent dans les masters. ?
bruno
10 years 8 months ago #11825 by celio
pour l'instant ça ne m'est pas arrivé....
bonne journée
Célio
10 years 8 months ago - 10 years 8 months ago #11831 by sl1200mk2
au regard des noms que vous donnez à ce qui est chargé dans les subs, il y a un bug si vous passez par le sub lui-m^me.
si par exemple vous voulez nommer des groupes ou des chaze ou autre, faites le par les Listing, pas par les subs....
faut que je corrige ça....
Last edit: 10 years 8 months ago by sl1200mk2. Reason: orthographe
10 years 8 months ago #11849 by bgoubert
@nico
effectivement, ça ne le fait que si on passe par les subs. En listing c'est ok.
bruno
10 years 8 months ago #11850 by zenerve
Replied by zenerve on topic 4.0.0_b57
Hey Nicolas, what was your setup on that Wampas gig ?
(In particular, what controller did you use?)
Care to share your .sho? I do have a hard time figuring out how to use moving heads live with DL.
Time to create page: 0.181 seconds
