4.0.0_b56
10 years 9 months ago - 10 years 9 months ago #11734 by sl1200mk2
4.0.0_b56 was created by sl1200mk2
only 4 MacOS 10.6 -> 10.11
Last edit: 10 years 9 months ago by sl1200mk2. Reason: more OS
10 years 9 months ago #11745 by Wilf
Replied by Wilf on topic 4.0.0_b56
Yes! The device patch now works!
When making a palette without giving a name one get a warning with log writing capability, in stead of a GUI prompt, but that's a detail :)
10 years 9 months ago #11746 by Jefff
Replied by Jefff on topic 4.0.0_b56
Je teste ça cette semaine.
Ça sert à quoi le petit bouton au dessus des subs ?
10 years 9 months ago #11747 by Wilf
You mean the small blue one? It only shows the subs that are in use at that time if I'm correct. Just like what it does in channel test and the main screen. It cleans up visually.
10 years 9 months ago #11748 by leoclarys
Replied by leoclarys on topic 4.0.0_b56
Salut Nico! Bonne année et merci pour toutes ces améliorations. Je me pose aussi la question quant à ce petit cercle noir et blanc au dessus des subs. J'ai remarqué qu'il permettait de faire glisser le sub vers le bas. Uniquement esthétique?
10 years 9 months ago #11749 by Wilf
I felt a little lucky and did a show with this version. No faults occurred.
10 years 9 months ago #11752 by sl1200mk2
Replied by sl1200mk2 on topic 4.0.0_b56
the new stuff upon the submasters is designed for the future... B)
it's a scrolling stuff that is adding extra space for sub and will hold new commands for the sub...
10 years 9 months ago #11755 by bgoubert
Replied by bgoubert on topic 4.0.0_b56
@nico
crash en enregistrant une mémoire.
réouvert, les textes des subs ont changé de place.
File Attachment:
File Name: DLight_201...rash.zip
File Size:13.35 KB
bruno
ps: je ne reçois plus aucun mail des sujets auxquels j'ai souscrit, depuis 2 ou 3 mois. ???????
10 years 9 months ago #11760 by sl1200mk2
@bruno,
il va etre difficile celui là...
tu peux joindre le sho, stp?
vient sur l'IRC, faut demander à totoine
10 years 9 months ago #11761 by bgoubert
@nico
le sho est simplissime, je démarrai juste
File Attachment:
File Name: REFLET1.sho.zip
File Size:12.27 KB
bruno
10 years 9 months ago #11782 by vbs
Replied by vbs on topic 4.0.0_b56
Hi,
I have a problem with my Ficture file.
When i make a new show i build a fixture with 19 channels.
I make a few presets and colors and stuff.
After i save the show and re open the show again my fixture file have no more channels.
After i import and patch the fixture again it works again but don,t understand.
The problem seems to be in the fixture file but don't know how
I enclose my Show and the fixture file.
10 years 9 months ago #11783 by sl1200mk2
@Vincent,
it's a tricky thing... but the / in the model name of your personality screw everything...
The following user(s) said Thank You: vbs
10 years 9 months ago #11784 by vbs
Hi Nico,
That seems to work thanks!
One other thing is how do i edit a pallet?
I select the device commands - palette select pallet nr7. make the adjustments in the device command and select update.
The it say first choose a pallet ????
See Pict 1
Also how do i get the device commands into the main software bord?
Pict 2
Regards Vincent
10 years 9 months ago #11785 by sl1200mk2
@Vincent,
you have 2 methods to update a palette:
1) use the palette editor
2) once you have set new values for your device, type the palette number and click update
you can't...
all the stuff that belongs to devices is handle in the 'Device Commands' panel.
10 years 9 months ago #11786 by vbs
Hi Nico,
I will try that the update part.
About the control panel.
In the wiki at Device it say you can select in the control panel.
Or is this al ready not up to date any more.
Pic. Pallets
Time to create page: 0.186 seconds
