4.0.0_b37
11 years 5 months ago #9980 by sl1200mk2
4.0.0_b37 was created by sl1200mk2
A base de popopopop!!!!
just to let you know where I'm going...
removed things:
channelcheck definitely removed (use Patch functions for this purpose)
Color Scroller definitely removed (use Devices functions for this purpose)
news/update/fixes:
Patch:
-you can now select several channels, and if you give one dimmer, channels we be patched as list starting with the given dimmer.
(@mode exemple: CH 1 THRU 10 = 5 ENTER will patch ch 1 to dimmer 5, ch 2 to dimmer 6, etc...).
-double click is available for check level
Balance:
submaster that are in TIME mode and the little blue square of the sub is set, what's inside the submaster won't be touched by the Balance Mode
Artnet:
now inegrated to the setup.
more simple, more usefull, honor the broadcast/unicast mode, honor selected nodes to use in unicast mode.
Submasters:
there's now a little indicator close to the sub that show progression in case of MLink start or Times Start
Midi Time Code:
new inhib MTC function in the setup
+many various bug fixes
please test and report,
and please consider making donation if you find the software useful
Nicolas
11 years 5 months ago #9982 by sl1200mk2
Replied by sl1200mk2 on topic 4.0.0_b37
oops, I've almost forget...
I did a lot of job too about the remote (using OSC messaging system)
now, every error warnings or message can be ack or not by the remote (using yes/no mechanism)...
I did a lot of job too about submasters
I'll tell you later about used messages but basically, they are the same as /sub/xx/level except that the prefix is /subStick
attached the .touchOSC
Nicolas
The following user(s) said Thank You: aroom
11 years 5 months ago #9983 by aroom
Replied by aroom on topic 4.0.0_b37
thanks !
11 years 5 months ago - 11 years 5 months ago #9984 by birt
Replied by birt on topic 4.0.0_b37
when patching with @ the program stops as soon as you hit enter. for example:
"dimmer 45 channel 19 @ enter" and the program will quit.
i have not been following the beta's and don't know the new patch yet so i was just trying things out. any tips?
i can't seem to find older versions of the beta and i can't use version 3 on OSX10.10
Last edit: 11 years 5 months ago by birt.
11 years 5 months ago #9985 by sl1200mk2
Hi Birt,
thanx for trying out the betas...
sorry for the crash... I didn't thought about this possibility of syntax....
will fix for the next beta.
correct syntax is
CHANNEL 19 @ 45 ENTER
ou
DIMMER 45 @ 19 ENTER
when @mode is selected, DL should display a list of accepted syntax in the "I" icon of the upper right corner of windows.
11 years 5 months ago #9992 by sl1200mk2
@Birt
I can't reproduce your crash...
is there's any chance you can send me the bug report?
There's an application called Console in /Application/Uitlity that display bug reports
thanx,
11 years 5 months ago #10004 by Jefff
Replied by Jefff on topic 4.0.0_b37
Hello, peut-être un petit problème :
Si une interface midi n'est pas branchée avant le lancement de Dlight il n'y a plus la possibilité de la retrouver avec la double flèche bleue.
11 years 5 months ago - 11 years 5 months ago #10005 by pan
Replied by pan on topic 4.0.0_b37
Problème avec l'export PDF de la séquence. DLight se ferme direct.
(sur ubuntu 15.10)
Sinon toujours trop top :)
Last edit: 11 years 5 months ago by pan.
11 years 5 months ago #10006 by sl1200mk2
@Jeff
bien vu, je pense l'avoir réparé
@pan
tu peux poster ta conduite, stp?
ici sur la ubuntu 12.04 64bits ça fonctionne...
prochaine beta en début de semaine...
11 years 5 months ago #10007 by totoine
Replied by totoine on topic 4.0.0_b37
pan wrote: Hello,
(sur ubuntu 15.10)
Ubuntu 15.10 existe ??
je pensais qu'on était à la 15.04 ?
11 years 5 months ago #10008 by sl1200mk2
@antoine,
et toi, t'as une ubuntu 15.x ?
l'export pdf fonctionne chez toi?
11 years 5 months ago - 11 years 5 months ago #10009 by totoine
Hello !
Et non, je viens de passer à Debian Jeesie (8). et l'export PDF fonctionne très bien sur plusieurs de mes conduites.
Last edit: 11 years 5 months ago by totoine. Reason: mal lu le Wiki, solution déjà présenté ...
11 years 5 months ago #10010 by sl1200mk2
@antoinee,
ok, merci!!
11 years 5 months ago - 11 years 5 months ago #10011 by Wilf
Replied by Wilf on topic 4.0.0_b37
Nico, trop bien! Haven't seen the updates since b10 so I can only say WOW! Patch looks GOOD! Very nice and much faster this way.
I will miss the Channel Check though. Why? Because I give the Channels in Channel Check names. This way I have a quick overview and can check if I really patched every fixture I need. The names I give are the roles these fixtures have, like "Left front OW", "Middle side L201" or "Special top left Frost L257". With the cleanup-button in Check Channels I thus had a good list of every fixture and run by them very fast. I do this after patching and regularly find one thing I forgot to patch.
Last edit: 11 years 5 months ago by Wilf.
11 years 5 months ago - 11 years 5 months ago #10012 by totoine
Hello wilf !
Sorry for my English ;)
Nico said in a previous message on b35 that he will add the channel's name in the patch window...
D'ailleurs Nico, pour reprendre la gestion de la fenêtre d'alerte dans le patch, maintenant, si j'affecte un dimmer déjà affecté, j'ai bien la nouvelle fenêtre tout belle toute rose au premier plan, mais elle n'est pas sélectionné (espace et entré agisse sur la fenêtre principale)... je suis obligé de reprendre le focus à la souris sur cette fenêtre.
La tabulation qui me permet de passer d'une fenêtre à l'autre (c'est toi qui a rajouté ce raccourci clavier ou je ne l'avais pas vu avant ou c'est ma nouvelle debian qui le fait ?) ne passe pas sur cette fenêtre...
Time to create page: 0.206 seconds
