4.0.0_b33
11 years 6 months ago #9898 by sl1200mk2
4.0.0_b33 was created by sl1200mk2
so,
with this one I've put everything I want for 4.0.0.
I don't say work is finished... there will surely be more work for the 4.0.1, etc... but I'm pretty glad with it for now.
news:
-should fix all errors reported for the b32 (except TLink that collapse, I've forgot....)
-Patch:
complete rewrite of this window.
the left part display channels, the right part display dimmers.
D-Patch is the first address of patch for Devices
you can drag'n drop from channels to dimmers
you can select several dimmers like 1 + 2 Thru 10 + 20 + 44
the remote should not work anymore, let's try to write another one...
+ many many more little stuff that make life better ;-)
please report any wrong behavior,
enjoy,
11 years 6 months ago #9900 by vbs
Replied by vbs on topic 4.0.0_b33
Hi Nico,
The patch is looking nice but i have several crash in DL, the interface disappear.
I tried drag drag from left to right but it crash.
I don't 100% sure if i do it right.
i try 12+24+33@10 witch mean to me dimmer 12+24+33 at channel 10 but nothing is happening.
Can you explain ?
Thanks Vincent
11 years 6 months ago #9903 by sl1200mk2
Replied by sl1200mk2 on topic 4.0.0_b33
Hi Vincent,
thanx for testing...
I don't remember if you're running DL on Mac or PC...
if it's on Mac, can you send me the crash log?
it means the same thing for me...
here it works...
you've push enter at the end, right?
I've tried to list all of them here:
www.nicole-banana.com/wiki/index.php?title=@mode#PATCH_Editor
11 years 6 months ago #9906 by bgoubert
Replied by bgoubert on topic 4.0.0_b33
Hi Nico
J'ai commencé à noter des choses sur le patch. Jusqu'à mardi je vais pas avoir trop le temps, mais après je me met au test serieux et à la réecriture d'une teleco.
11 years 6 months ago #9908 by sl1200mk2
@bruno,
ça m'arrangerait bien si tu pouvais poster tes notes... comme ça je peux corriger.
thanx,
11 years 6 months ago #9912 by sl1200mk2
b34 is online
