4.0.0_b29
11 years 7 months ago #9689
4.0.0_b29 was created by sl1200mk2
-should fix Win64 package
-Sequence : StepID
this is the big new stuff which allow you to register an 'identifiant (ID)' for a step.
Thus you can call the step thanx to new shortcuts stepID_load and stepID_goto where xxxx_load is used to set the ID for a step and xxxxx_goto is used to trigger the step
there cannot be two stepID with the same number....
in the setup you can choose if MSC Load message is mapped with the cues (as before) or with the stepID
in OSC, two new messages : /seq/ID_goto xx.xxx and /seq/X2LoadAndFireID xx.xxx
-HourTrigger:
functions have been re-written
+bug fixes
please test and report,
-Sequence : StepID
-HourTrigger:
+bug fixes
The following user(s) said Thank You: nomatter
- Jefff
- Thank you received: 7
- bgoubert
- Thank you received: 22
- bgoubert
- bgoubert
- bgoubert
- bgoubert
Time to create page: 0.181 seconds
