4.0.0_b26
11 years 7 months ago #9539 by sl1200mk2
4.0.0_b26 was created by sl1200mk2
Hey !!
new beta available for every supported systems (with the addition of Windows 64bits)
ATTENTION: on MacOS 10.6_10.7, DL is built against XQuartz 2.7.7 (please update your server...)
bug fixes release + new features:
OLA:
the server have been updated to 0.9.5
Sequence :
the big sequence window is a whole new code with drag'n drop support for every parameters
Track :
now display DLinks associated to a channel for sequence's steps
OSC : new /sub/x/text message.
it's only an outgoing message that display text associated with subs. DL will not respond to this message
MIDI :
new MidiSwitch +/- bind available
Device :
Inverse Pan/Tilt now available in the Device's Listing
please test and report any satisfaction / wrong behavior
special thank to Aroom for the work on the wiki...
11 years 7 months ago #9541 by sl1200mk2
Replied by sl1200mk2 on topic 4.0.0_b26
and as usual:
Device's Personality are stored here:
github.com/dlight-tools/dlight-devices
there's now a HOWTO in the wiki about github and how to grow device's personality:
www.nicole-banana.com/wiki/index.php?title=Dlight-tools
11 years 7 months ago - 11 years 7 months ago #9542 by jeanmig
Replied by jeanmig on topic 4.0.0_b26
Je viens d'essayer d'installer la dernière bêta de Dlight sur un MBP 2013 avec osx 10.9.5.
DLight reste bloqué après le lancement de X11.
Il y a SIMBL Agent qui quitte de manière imprévue (je ne sais pas si cela a un lien).
Cordialement,
Jean-Michel
Last edit: 11 years 7 months ago by jeanmig.
11 years 7 months ago #9543 by sl1200mk2
@jean-michel
merci de ton test, j'en ai vraiment besoin.
t'as bien une version de XQuartz >= 2.7.5 d'installée?
peux-tu essayer de lancer DL par la ligne de commande?
si tu as copiéDL dans /Applications, dans un terminal tu tapes:
et tu valides par Enter
11 years 7 months ago - 11 years 7 months ago #9544 by jeanmig
- J'ai refais un test avec la 3.24, le soft fonctionne
- Xquartz, c'est la version 2.7.7
- J'ai tapé la ligne de commande, cela lance X11, mais apparemment cela ne va pas beaucoup plus loin. Dans le moniteur d'activité, je vois 2 opérations DLight qui prennent chacune 100% du processeur
Jean-Michel
11 years 7 months ago #9545 by sl1200mk2
et le terminal ne te dit rien?
11 years 7 months ago - 11 years 7 months ago #9546 by jeanmig
Rien dans le terminal
Je pars en preta, pour de nouveaux test ce sera ce soir ou demain.
Jean-Michel
11 years 7 months ago #9547 by sl1200mk2
mince...
tu veux pas redémarrer ton ordi pour voir.
partir d'une base clean
thanx
11 years 7 months ago #9548 by jeanmig
Je prends 5mn de plus.
- J'ai redémarré le MBP.
- Lancé DLight 4b26
- X11 lancé
- Ventilos aussi :)
- 1 opération DLght dans moniteur d'activité 100%
- ventilos calmes
- SIMBL Agent ne répond plus
- Cela ne bouge plus
Jean-MIchel
11 years 7 months ago #9549 by sl1200mk2
va falloir qu'on trouve cette histoire...
bonne presta en attendant et prévient moi quand t'es dispo.
si jamais tu peux venir faire un tour sur l'IRC qu'on en discute c'est bien aussi:
www.nicole-banana.com/index.php/forum/1-general/5520-irc-dlight
11 years 7 months ago #9550 by sl1200mk2
juste un petit truc comme ça, t'as installé quelle beta sur ton MacOS 10.9?
11 years 7 months ago - 11 years 7 months ago #9551 by boeckel
Replied by boeckel on topic 4.0.0_b26
Hello Nico,
Quel boulot, bravo...
Je confirme sur 10.9.5 avec Xquartz 2.7.7, DL ne se lance pas complètement
Sur un 10.9.5 (autre machine) avec X quartz 2.7.5, ça fonctionne
Malheureusement je n'aurai plus le temps de tester avant une bonne 10ene de jours.
Last edit: 11 years 7 months ago by boeckel.
11 years 7 months ago #9552 by sl1200mk2
hey Pascal,
merci pour ce retour précieux.
je vais donc unifier les serveur X avec lesquels DL est compilé
donc pour la prochaine beta ça sera XQuartz 2.7.7 pour tout le monde
mais quand tu reviendras, ça sera encore mieux...
encore merci pour cette info qui m'évite des milliards de micro secondes de stress
11 years 7 months ago #9553 by jeanmig
Bonsoir,
Me revoilà.
- J'ai désinstallé SIMBL.
- Lancer DL 4.0.0b26
même résultat qu'aux essais précédents.
- Bloquage DL
Jean-Michel
11 years 7 months ago #9554 by sl1200mk2
@Jean-Michel,
a priori il y a une incompatibilité d'XQuartz entre celui que j'utilise et celui que t'utilises.
je vais updater mon système avec XQuartz 2.7.7 (le meme que le tien) et là ça devra passer.
la suite à la prochaine beta qui devrait pas tarder (genre demain....)
merci pour les tests
Time to create page: 0.173 seconds
