3.0.24
11 years 8 months ago #9425 by luiananda
Replied by luiananda on topic 3.0.24
I had a new problem, the day before I was running a show and it worked fine at the end I saved the show and closed the PC, the next day going to open the show, come a little window say error wrong color, set again, or a windows saying not find the file, which indeed the file where on the place where it was saved, I run the windows explorer and the show is where I saved, after many time restarting the System and the D::Light, I was able to open another file of the same show but I had in 15 Min. to reprogram everything, very stressful,with public just coming in, I have no idea why the show was not saved correctly, at the end of the show I saved again in two orders and reopened and it worked....I don't know what to say....also wrote in another comment, on the Patch file you can't anymore type a number on the channels or Dimmer to jump with the enter to Dimmer number you want, example, if I am on the Patch window and usualy if I was to dimmer 1 I could jump to a Dimmer 12, just marking the 1, put the 12 and enter, now if from 1 I want to go 18 I have to run all number one by one
Greetings, Luigi
11 years 8 months ago #9426 by sl1200mk2
Replied by sl1200mk2 on topic 3.0.24
Luigi,
sorry to hear that...
did you by chance kept the damaged .sho file?
if so, can you post it here?
nope, because it was leading to very bad things from certain users...
by the way you can use shortcuts to access either channel ('c' shortcut) and dimmers ('v' shortcut)
11 years 7 months ago #9540 by sl1200mk2
new beta 4.0.0_b26 is online
11 years 1 month ago #10717 by Wilf
Replied by Wilf on topic 3.0.24
I am running a new computer now, with OSX 10.10, the latest download of 3 is up to X.9. Can I use this safely for a show? Or is the Beta 4.0.47 safe enough...?
11 years 1 month ago #10718 by sl1200mk2
@Wilf,
there'll be no 3.0.24 for yosemite && >
and I believe 4.0.0_b47 is stable enough for standard (non Device) use.
I believe b47 is better regarding plenty of stuff and precisely regarding inhibition mechanism...
b48 wiil be better for Device and for chases as I'm adding TLinks && DLinks inside chasers.
The following user(s) said Thank You: nomatter
11 years 3 weeks ago #10833 by Benp
Replied by Benp on topic 3.0.24
Dlight 3.0.24 est-elle disponible pour linux 32b?
Ds la rubrique download je trouve uniquement la version 64b,
pourtant le 1er post de ce sujet précise que la version 3.0.24 sera compatible sous linux 32 et 64b...
Quelqu'un peut m'orienter?
11 years 3 weeks ago #10834 by totoine
Replied by totoine on topic 3.0.24
désolé, la version 32bits a disparu dans une mise à jour du serveur. Et on ne l'a pas retrouvé dans le backup.
Mais aujourd'hui tu peux utiliser la 4.0b47 pour une utilisation avec des projecteurs traditionnels.
Il faut attendre confirmation de nico, mais elle a je pense la stabilité de la 3.0.24 pour la partie traditionnel.
11 years 3 weeks ago #10835 by Benp
Ok merci de l'info je ne comprenais pas.
J'ai encore la 3.0.23 qui tourne sans problème, je vais continuer avec,
je voulais juste essayer la dernière version pour me tenir à jour.
11 years 2 weeks ago #10876 by La Rotule
Replied by La Rotule on topic 3.0.24
Je cherche à télécharger, Dlight pour linux la version 32 bits. Seulement je ne la trouve nulle part. J'ai fini par voir cet article sur le forum, est-il possible d'obtenir un lien pour télécharger l'ancienne version?
11 years 2 weeks ago #10877 by sl1200mk2
la 3.0.24 pour Linux 32bits s'est perdue dans la mise à jour du site.
j'ai pas le temps de la refaire, du coup il faut vous orienter vers la version en cours de dev à savoir à ce jour la 4.0.0_b47
11 years 2 weeks ago #10878 by La Rotule
Ok dommage. Merci pour la réponse super rapide!
Mais du coup je ne comprends pas ce que c'est la "version en cours de dev à savoir à ce jour la 4.0.0_b47" c'est un autre logiciel?
11 years 2 weeks ago - 11 years 2 weeks ago #10879 by totoine
Bonsoir,
la version en cours de développement est la prochaine version de D::Light qui sera la version 4.
Celle-ci est toujours en phase beta, ce qui veut dire que tout n'est pas stable. Elle apporte nottament la gestion des projecteurs asservis (devices). Cette section contient encore des bugs qui sont en cours de correction
Pour la partie 'traditionnel', elle peut-être considéré comme stable.
Tu peux trouver cette version dans la partie beta de la section téléchargement.
La 4.0.0_b47 signifie que c'est la 47e version beta (et oui déjà) de ce futur D::Light
Last edit: 11 years 2 weeks ago by totoine.
10 years 11 months ago - 10 years 11 months ago #11102 by dFVarela
Replied by dFVarela on topic 3.0.24
Hello, long time no see... I have the version 3.0.24 32 bits for Linux if you need it download it here !
dFVarela
Last edit: 10 years 11 months ago by dFVarela.
The following user(s) said Thank You: totoine, La Rotule
10 years 11 months ago #11105 by totoine
Thanks for this one.
I will upload it on the server !
10 years 11 months ago - 10 years 11 months ago #11106 by dFVarela
I'm trying to download it and it looks like there is an error check first if everything is OK!
Can't dowload and open on Windows, can anyone download with Linux and try it? I can only do it later at home!
dFVarela
Last edit: 10 years 11 months ago by dFVarela. Reason: Error on downloading whit windows!
Time to create page: 0.189 seconds
