4.0.0_b6
12 years 3 months ago #8386 by sl1200mk2
4.0.0_b6 was created by sl1200mk2
let's move on!
a new beta is available for macOS >= 10.8 and Windows (if you want the other builds, just ask.)
here's a non-finished list of modifications:
move CONTROL command
add HOME command
add Palette Macro function to set preferences for Palette recording
add Palette recording/updating functions
add Palette listing and editor
added +/-1 option for FOCUS commands
add the ability to use CTRL in the BLADE commands in order to scroll both Blade or Fine Balde
in the setup, add an option fro automagically switch to Device board at loading time
about Device Editor:
- rename it to Device Personnality Editor
- change internal display (need to rewrite personnality files... sorry)
- add a column to define if a parameter must be activate temporary (eg: Lamp On/Off needs to go to xx level then goback to 0)
attached a model of devices for the device editor.
I think it's robust now and you can build Personality based on the attached example.
if there's an english speaker that follow this beta stage, please correct grammar and sentence.
next step will be Cue and Group recording with Palettes
please give feedback about this work.
12 years 3 months ago #8392 by xtineb
Replied by xtineb on topic 4.0.0_b6
slt nico
je ne peux plus patcher un device !
(depuis patch droit ou patch vide)
selection ok
"c" pas ok
12 years 3 months ago #8394 by xtineb
je recree mon device
-ajout des attributes ok
-ajout des parameters ok sauf colonne de valeurs min: message log (cf pj)
12 years 3 months ago #8395 by sl1200mk2
Replied by sl1200mk2 on topic 4.0.0_b6
salut Xtine,
est-ce que le patch des devices est ok quand tu recréer ton device ?
aussi, ya pas la pj...
thanx,
12 years 3 months ago #8396 by xtineb
pas pu tester mon device car pas fini !
mais essai de patch des tiens: le patch reste vide!
12 years 3 months ago #8397 by sl1200mk2
et la pj de l'erreur de la colonne min...
12 years 3 months ago #8398 by xtineb
la pj veux pas passer.... alors copier/coller:
can not find channel named "stdout"
while executing
"puts "$col $row""
(procedure "editFixEditorTbleStartCmd" line 42)
invoked from within
"editFixEditorTbleStartCmd .fixtureEditor.f.sh.editor.tbl 5 4 0"
("uplevel" body line 1)
invoked from within
"uplevel #0 $data(-editstartcommand)
    (procedure "doEditCell" line 148)
    invoked from within
    "doEditCell $win $row $col 0 "" $charPos"
    (procedure "tablelist::condEditContainingCell" line 26)
    invoked from within
    "tablelist::condEditContainingCell $tablelist::W $tablelist::x $tablelist::y"
    invoked from within
    "if {[winfo exists .fixtureEditor.f.sh.editor.tbl.body]} {
    foreach {tablelist::W tablelist::x tablelist::y} [tablelist::convEventFields .fixtureE..."
    (command bound to event)
12 years 3 months ago #8399 by sl1200mk2
pour la pj:
mince.... c'est un truc de debug que j'ai oublié d'enlever...
pour le patch, sur le mac ça fonctionne, je vais essayer sur le PC et je te dis.
thanx
The following user(s) said Thank You: xtineb
12 years 3 months ago #8400 by sl1200mk2
@xtine,
j'ai mis en ligne une b7, du coup on va quitter ce thread et je vais en ouvrir un autre.
dis moi si il y a du mieux.
12 years 3 months ago #8402 by xtineb
dac, je fais çà maintenant!
Time to create page: 0.198 seconds
