3.0.19_b3
- vbs
- Thank you received: 1
12 years 10 months ago #7375
by vbs
Replied by vbs on topic 3.0.19_b3
Hi
I see that the Inhabitation display is not there any more?
In the version 3.18 it was still there but he when you set a channel in inhabitation it was not visible in the display.
Regards Vincent
Regards Vincent
- colinc
- Thank you received: 22
12 years 10 months ago - 12 years 10 months ago #7376
by colinc
Replied by colinc on topic 3.0.19_b3
@Vincent
The way inhibition works has changed, so the old inhibition window has gone. Now, you select some channels you want to inhibit, create a group with them, and then attach that group to a submaster. In the FLASH/TIME selector for the sub, you will now see a third option - INHIBIT. If you make that submaster an IHIBIT submaster, then wnen it is at FULL, any live channels in eg, the sequence window, which are part of the INHIB group will have their output proportionately reduced. See the thread on Inhibition in the 'Main' forum.
Regards,
Regards,
Last edit: 12 years 10 months ago by colinc. Reason: removed html
- vbs
- vbs
12 years 10 months ago #7394
by vbs
Today i notice that if you have the desk in @Mode and you want to record a cue it don't record it.
For instance que - 4.1 - rec - enter Noting is happening
In RPN mode it works and you see it is recorded
Regards Vincent
Regards Vincent
- vbs
12 years 10 months ago #7399
Replied by sl1200mk2 on topic 3.0.19_b3
:huh:
what is [UPDATE]?
when I try to modify:
[MODIFY] x [ENTER] -> modify the cue x
[REC] x [ENTER] -> record the cue x
[MODIFY] [ENTER] -> modify the cue in the activ' register
x [MODIFY] [ENTER] -> modify the cue in the activ' register
don't you have the same behavior?
what is [UPDATE]?
