3.0.17
12 years 11 months ago #7153
3.0.17 was created by sl1200mk2
la belle lurette...
I'm proud to announce the 3.0.17 release of
:Light.
It's available for each supported platforms (macOS 10.6->10.9, windows, Linux 32b, Linux 64b).
On MacOSX, it's linked against XQuartz 2.7.4 (xquartz.macosforge.org/landing/)
OLA
- OLA server has been updated
USB DMX
- libusbx has been updated
- Espion2 from Robert Juliat can now be used to output DMX
- USB DMX Pro MK2 from Enttec can now be used and output DMX on 2 universes
- ultraDMX Pro from DMXKing.com can output DMX on 2 universes
ROOM/DMX UNIVERSE:
- now
:Light use 1.1 for the first universe/room and 1.2 for the second, 1.3 and 1.4
OSC:
- more OSC messages
LOOP:
- new function that allow to set the number of times that a FX or a Sample is looping.
available in Submasters as well as in MLinks.
MIDI TIME CODE:
- you can control all the STEPs *not the cue's* thanks to a midi clock.
MIDI:
- fix crash for loooooong midi patch, that leads to a "Midi Channel 2 display" selector.
FX:
- you can now import Cue from the sequence or recorded Groups in the FX Editor
GROUP:
- you can now record only selected channels as GROUP. a pop-up window ask 4 your choice.
lots of work on this one...
many many thanx to every people that have spend some times during the beta process.
Enjoy and consider making donations if u find this software useful.
Nicolas
:Light.It's available for each supported platforms (macOS 10.6->10.9, windows, Linux 32b, Linux 64b).
OLA
USB DMX
ROOM/DMX UNIVERSE:
- now
:Light use 1.1 for the first universe/room and 1.2 for the second, 1.3 and 1.4OSC:
- more OSC messages
LOOP:
MIDI TIME CODE:
MIDI:
FX:
GROUP:
Nicolas
The following user(s) said Thank You: quico, Jefff, loupiotes, bashaut
- loupiotes
- Thank you received: 1
- muzikmateo
12 years 11 months ago #7159
Replied by sl1200mk2 on topic 3.0.17
/seq/X1ActiveCue
/seq/X2ActiveCue
/patch/RoomUniverseRQ (Room, universe request)
/patch/displayActiveRoomUniverse (display active universe / room)
/patch/styleRoomUniverse (display room or universe)
les plus récents étant tout ceux de la précédente version:
www.nicole-banana.com/index.php/forum/2-releases/5133-3-0-16
/seq/X2ActiveCue
- Wilf
- Thank you received: 3
12 years 11 months ago #7182
by Wilf
Replied by Wilf on topic 3.0.17
In this release I have some problems with patching:
- The dimmer and channel text fields (where the numbers are) are now grey in stead of white and I cannot change them by typing anymore. It now takes me forever to go from dimmer/channel 1 to dimmer/channel 455.
- Sometimes typing does not register. I can type [CH} or [DIMMER] but the number will not follow.
- Sometimes, when working with two universes and patching them the patch page becomes unresponsive and the patchfield becomes completely white.
Besides this I have a wish for patching: It would be great if it would be possible to patch multiple dimmers on one channel that are not in a row, like this:
[CH]XX[@][DIMMER]YY[+]RR[+]VV
So one could, for example, patch channel 50 to dimmer 20, 55 and 123.
- colinc
- Thank you received: 22
- petit.did@free.fr
12 years 11 months ago #7184
by petit.did@free.fr
Replied by petit.did@free.fr on topic 3.0.17
Bonsoir,
D Light téléchargé et installé plusieurs fois sur mac OS 10.6.8.
Quand je le lance je n'ai que X11 qui tourne D Light ne démarre pas.
Une idée de ce qui se passe.
J'ai simplement glissé l'Icône dans le répertoire applications comme d'habitude, sans avoir désinstallé la version précédente.
Merci de votre réponse.
- Jefff
- Thank you received: 7
- Jefff
- petit.did@free.fr
12 years 11 months ago - 12 years 11 months ago #7271
Une fois la dernière version de XQuatrz installée plus de problème. Version 3.0.18 Ok. :woohoo:
Last edit: 12 years 11 months ago by petit.did@free.fr.
- Jefff
12 years 11 months ago #7273
by Jefff
Replied by Jefff on topic 3.0.17
j'ai reçu dans ma boite gmail le message de petit.did ci-dessus. Ce qui est normal, mais par contre le message reçu est celui-là :
"Une fois la dernière version de Xflash installée plus de problème. Version 3.0.18 Ok. :woohoo:"
Je suis étonné du "Xflash".. quelqu'un comprend pourquoi ?
(Je sais ça n'a rien à faire ici.... sorry... mais bon j'comprends pas...)
- petit.did@free.fr
Time to create page: 0.182 seconds
