3.0.17_b6
13 years 3 weeks ago #6869
3.0.17_b6 was created by sl1200mk2
a release candidate.
available for all supported platforms, Linux 32&64 bits, Windows, MacOSX 10.6, 10.7, 10.8
it should work on MacOSX 10.9
news :
USB DMX PRO MK2:
DL can now output on the 2 universe of the new widget from Enttec
MIDI:
fix a bug when Midi map are huge. There's now a "Midi Channel 2 display" selector.
please test heavily and report.
Nicolas
news :
USB DMX PRO MK2:
MIDI:
Nicolas
- vbs
- Thank you received: 1
13 years 3 weeks ago - 13 years 3 weeks ago #6874
by vbs
Replied by vbs on topic 3.0.17_b6
Hi
I see for a long time the Inhibitation Editor in Dlight but i can not find out wat i can do with it.
Can you help?
Regards Vincent
Can you help?
Regards Vincent
Last edit: 13 years 3 weeks ago by vbs.
13 years 3 weeks ago #6876
Replied by sl1200mk2 on topic 3.0.17_b6
Hi Vincent,
when you register a channel in the inhibition editor @FF, the channel will be blocked until you de-register it.
if you set a level to this channel, 80% for example, all level for this channel will be output at 80% of the recorded levels. in this case it's a scale.
did you understood the 1.1 and 2.1 in the patch editor?
- Jefff
- Thank you received: 7
13 years 2 weeks ago #6892
by Jefff
Replied by Jefff on topic 3.0.17_b6
J'ai des clignotements quand j'utilise l'osc, comme des micros chutes de tension, cela persiste après l'arrêt d'envoi de données vers dlight. Une fois l'osc en position OFF tout redevient normal.
je suis sur la 3.0.17_b6 sur mac
- Jefff
- vbs
- Wilf
- Thank you received: 3
- friedrick
- friedrick
- ouzadia
Time to create page: 0.177 seconds
