3.0.15_b6
with the previous one, it could happen that the patch was not recorded ->fixed
news:
in the Midi Patch, when you select a channel for a connection, you can specify the ROOM it belongs.
happy testing!
ps:
I plan to release the 3.0.15 by the end of the next week (if everything goes well).
- noelvd
- Thank you received: 4
Tested the new features in the Patch-window.
Works as designed
Also noticed that export (of the patch) to XML, now writes 'rooms', instead of 'universes'.
Good job !
Wll do more testing (multiple universes -live- in one room) in the next few days.
Best regards,
Noël
I've pushed a b7 with different code to handle usb widget connections.
as it's expected to work on 32b computer as on 64 and you're the only one with this kind of material (and as you're active on the tests
Nico
- noelvd
sl1200mk2 wrote: thank you Noel for the tests.
as it's expected to work on 32b computer as on 64 and you're the only one with this kind of material (and as you're active on the tests), can you try the DMX connection on your MacMini? (and reply in the b7 thread).
Nico
Will download b7 ASAP, and test.
But remember that I have an ArtNet node, not a USB-DMX interface.
Best regards,
Noël
- noelvd
sl1200mk2 wrote: damned!!!!!
Sorry
But look at the bright side : with the ArtNet node (electron design), I can test up to 4 universes in 1 room.
Working on getting the cabling done for that.
Will report the result.
Best regards,
Noël
P.S. Second BCR2000 ordered
by the way, do you work in a theater or do you got a theater?
- noelvd
sl1200mk2 wrote: by the way, do you work in a theater or do you got a theater?
Yes, I work in the biggest theatre in the world: the Internet. :laugh:
(I'm a telecom engineer)
No, actually I have been doing light for theatre and bands for many years (freelance, in the weekends), but stopped when I got married.
Now that my children are getting bigger, I picked up my old hobby.
I don't have a lot of light fixtures, but I have.many different fixtures : some Par56 LEDs, 2 mini moving heads, 4 Martins 812, and a Revolution III -which needs 256(!) channels, all -soon- connected to 4 universes on an ArtNet node.
And of course a BCF2000, a BCR2000 (soon 2), an iPad, and an iPod, which can all be used to control DL
You've seen the pictures of the "BigDesk" (3-4 BCF2000, 2 BCR2000, and the Mac Mini inside) that I'm hoping to build one day.
I have looked at other DMX-software, and I like yours the best..
Keep up the good work
Best regards,
Noël
glad you enjoy DL
may I ask you one thing:
did you tried OLA DMX server included in DL?
it would be nice if we can make some tests on both 32 & 64 bits machine before the release.
- noelvd
I'll see what I can do, but I will be very busy for the next 2 weeks, so it may take a while.
What exactly do you want me to test with the OLA DMX server ?
Best regards,
Noël
- noelvd
