- Thank you received: 4
3.0.15_b1
- noelvd
13 years 7 months ago #6079
by noelvd
Replied by noelvd on topic 3.0.15_b1
Still no luck
But no we know that it is me, not DL.
I have removed Dl and XQuartz, did a fresh download of both, and re-installed it. Still no luck.
Any suggestions ?
I am thinking of re-installing the system software.
Best regards,
Noel
Any suggestions ?
Best regards,
Noel
13 years 7 months ago #6080
Replied by sl1200mk2 on topic 3.0.15_b1
@JJ
ok, on va faire des tests dans ce sens.
@pancho,
tu tombes pile poil à l'endroit que je voulais tester.
est-ce que le niveaux des circuits est aussi erroné quand tu n'est pas en affichage 'Only Used Channel'?
@Noel
there still can be a difference if your macMini is in 32bits and pancho's computer is in 64bits
@pancho,
@Noel
- noelvd
13 years 7 months ago #6082
@Noel,
attached a zip that contain 2 libraries.
would you mind trying to copy them in the DLight.app/Contents/MacOs instead of existing ones and try to launch DL?
you unzip the archive.
you 'Ctrl+Click' on DL icon, you move to Contents/MacOS and you copy the two dylib (libnettle.4.5.dylib and libhogweed.2.3.dylib)
you relaunch DL and it works
The following user(s) said Thank You: noelvd
- noelvd
13 years 7 months ago #6084
Nice
thank you for reporting that.
today I've to do some drawing stuff, I need to figure out Pancho && JJ's issue and I will update a b3 with those libraries.
(maybe tomorrow or next week)
Nico
Nico
- noelvd
13 years 7 months ago #6087
by noelvd
Did a few quick tests, all of which worked flawless
- Connected iPod (TouchOSC), and verified 2-way communication.
- Imported .asc file (only the Title did not import correctly, but that is a minor issue. Will need to check that again)
- Changed (background) colours
- Saved .sho
- Changed circuit view from 'all' to 'used only', and back (a few times, at different stages)
Will test more tonight and in the next few days.
(discovered that I find the dark blue [submaster levels] on the black background [in the 'circuits' window] hard to read. Could be my old eyes...)
Best regards,
Noel
- Saved .sho
Best regards,
Noel
- noelvd
- pancho
- Thank you received: 12
13 years 7 months ago #6090
by pancho
Replied by pancho on topic 3.0.15_b1
te joint mon patch puredata
un petit patch de débutant pas commenté et sans doute bancale : je ne garanti pas que le problème ne vienne pas de lui...
il permet d'envoyer la valeur du slider de droite à tous le circuits correspondants aux cases cochées, avec un possibilité de sélectionner une ligne ou une colonne out tout ou rien ou inverser, et de scroller ce qui est allumé dans les 4 directions.
les circuits sont affectés en midi channel 5, de 1 à 80
j'ai aussi essayé sur la 3.0.7 sans souci
- pancho
Time to create page: 0.221 seconds
