3.0.12
13 years 7 months ago #5906
3.0.12 was created by sl1200mk2
écran total...
This is the douzième patch of the 3.0 series of
:Light.
It's available for each supported platforms (macOS 10.5->10.8, windows, Linux 32b, Linux 64b).
On MacOSX, it's linked against XQuartz 2.7.4 (xquartz.macosforge.org/landing/)
Please be aware that this should be the last available release for Windows XP systems.
Please be aware that this should be (as usual) the last available release for MacOX 10.5 systems.
but this time, I mean it.
thank you for everyone who helped during the beta process.
news:
General:
- New 'Scene Master' (control via OSC (/seq/master xxx) and Midi). Allow to dim channel's that have a level in the active working register.
- DMX Universe / Channels Universe have been cleaned... here comes 'ROOMs' for channel.
that mean that 1 Room = 512 channels, 2 Room = 1024 channels, etc...
MIDI:
- Master (eg AllSubMaster, FlashMater, GrandMaster, SceneMaster, Joystick) have now their levels exported.
- You're now able to select between several Input/Output
- Channel's level are now exported to Midi Out.
- New 'Script' button to load a default Midi Patch
OSC:
- You're now able to use several IP/Port as output.
Time:
- You can now set 0.01 as time for xfade, wait, etc...
Sample:
- There's no need to set a time length to record a sample. just push the button (elapsed time is displayed) and stop it when you want. a maximum of 1 hour can be recorded.
Shortcut:
- standard shourtcuts now include &é"'(§è!çà as 1234567890
ChannelTrack:
- Better behavior when a lot of channels are loaded.
and several bug fixes, enhancements, etc...
If you appreciate the software, please consider making donations.
Enjoy.
Nicolas BATS
:Light.It's available for each supported platforms (macOS 10.5->10.8, windows, Linux 32b, Linux 64b).
news:
General:
MIDI:
OSC:
Time:
Sample:
Shortcut:
ChannelTrack:
Enjoy.
Nicolas BATS
The following user(s) said Thank You: pipou
- colinc
- Thank you received: 22
- celio
- Thank you received: 72
- celio
- boeckel
Time to create page: 0.259 seconds
