3.0.12_b10
13 years 7 months ago - 13 years 7 months ago #5867 by sl1200mk2
3.0.12_b10 was created by sl1200mk2
only bug fixes.
available for every supported platforms as it aims to be similar to the final release.
thanx for reporting weird/strange/nice behaviors
Nico
Last edit: 13 years 7 months ago by sl1200mk2.
13 years 7 months ago #5871 by colinc
Replied by colinc on topic 3.0.12_b10
Hi Nico
Good stuff... one *teeny* thing...
sl1200mk2 wrote: @Mode for TGroup works with b10 for the following syntax
...bla bla bla ... [@] z [TGROUP] y <Enter>
[TGROUP] y <Enter>
[ALL] [TGROUP] y <Enter>
The syntax for @Mode doesn't allow you to set a Delay time - you still have to click on the TGroup column and set a Delay there. So you can't do
...bla bla bla ... [@] z [TGROUP] y [DELAY] n <Enter>
which ideally you would :whistle:
Regards
13 years 7 months ago #5872 by sl1200mk2
Replied by sl1200mk2 on topic 3.0.12_b10
@Colin,
not even with rpn mode you can set directly a delay for a tgroup.
we will keep that for later if you don't mind B)
otherwise, does everything is fine?
13 years 7 months ago #5873 by xtineb
Replied by xtineb on topic 3.0.12_b10
encore le processeur à 100% avec 97% pour Dlight. Je comprends pas: je n'ai pas de boucle midi puisque j'utilise que le in avec le naokontrol. Et même en le débranchant... la charge du cpu ne descend pas.
Mais ce coup-ci je peux quitter Dlight.
Désolée pour cette mauvaise nouvelle.
La bonne, c'est qu'on peut bien copier les script midi
13 years 7 months ago #5874 by sl1200mk2
@xtine
est-ce que ça arrive que quand tu as le midi d'activé?
est-ce que ça arrive que quand tu as un périphérique midi de branché?
est-ce que ça arrive que quand tu as un boitier dmx de branché?
13 years 7 months ago #5875 by xtineb
oui
oui et quand je le débranche, çà ne change rien.
pas de boitier DMX
Depuis tout à l'heure, j'ai redémarré l'ordi, remis le nanokontrol et il se passe rien...
Je comprends rien :(
13 years 7 months ago #5876 by sl1200mk2
@xtine,
la première fois quand ton cpu s'est mis à déconner, tu faisais quelque chose de particulier avec ton nanoK?
est-ce que t'as un midi out de renseigné/activé?
13 years 7 months ago #5877 by xtineb
non mais je faisais mes copies de pages midi
non
et depuis tout à l'heure tout va bien
13 years 7 months ago #5878 by sl1200mk2
alors, est-ce que tu peux copier une page midi vers une autre, revenir à la première, faire une modif et recopier vers l'autre.
je vais pas te demander de le faire 500 fois mais fais le quelques fois.
13 years 7 months ago #5879 by xtineb
copie...modif...recopie...retour...remodif...etc
tout va bien !
J'ai que dlight et chrome plus bien sûr les applis propres à windows.
Par contre quand je mets en veille l'ordi, il me dit qu'il ne peut pas à cause du driver (DrvTools_e(1.14_r6))du nanokorg. Il me suffit de le débrancher pour que çà fonctionne. Je te dis çà parce que çà peut être rien à voir mais on sais jamais.
13 years 7 months ago #5880 by sl1200mk2
mmmh, là je sais pas...
si à priori ça à avoir avec le midi, je vais regarder par là si ya pas une boucle qui traine, mais je crois pas...
The following user(s) said Thank You: xtineb
13 years 7 months ago #5882 by sl1200mk2
je crois qu'il y a encore quelque chose qui ne va pas avec cette beta:
sur le midiswitch 1, le CC1 controle le circuit 1
sur le midiswitch 2, le CC1 controle le circuit 1
quand on est sur le midiswitch 1, je monte le CC1 et le circuit 1 atteint la valeur voulue
si je change de midiswitch, et que je bouge le CC1, le circuit 1 devrait également bouger.
ce n'est pas parce que dans le MSwitch 1 le circuit 1 à atteint telle valeur qu'on ne peut pas y accéder par le MSwitch 2.
actuellement, dans la b10 c'est le cas et je pense changer ça.
your thought?
13 years 7 months ago #5883 by xtineb
@Nico,
On a la même chose:
sur le midiswitch 1, le CC1 contrôle le sub 1
sur le midiswitch 2, le CC1 contrôle le sub 11
et je mets le même groupe (par ex) dans ces deux sub
quand on est sur le midiswitch 1, je monte le CC1 par ex à 40% et le sub 1 atteint 40%
si je change de midiswitch, et que je bouge le CC1, le sub 11 ne peut qu'être supérieur à 40%...
effectivement çà peut être gênant.
xtine
13 years 7 months ago #5884 by sl1200mk2
@xtine
je crois aussi... du coup j'ai modifié pour que ça soit pas le cas
Time to create page: 2.686 seconds
