bug d'ouverture de show offline en 3.0.10
13 years 11 months ago #5194 by jgastonraoul
bug d'ouverture de show offline en 3.0.10 was created by jgastonraoul
Petit topic de rappel pour correction du bug dans une prochaine version de DLight :
Lorsqu'on a enregistré un show en étant connecté à une node ArtNet, et qu'on essaye de le rouvrir à la maison (cad loin de la node), DLight plante au moment du "ArtNet Setup".
Workaround sur le conseil de Colin : définir une adresse IP en 10.X.X.X et un masque en 255.0.0.0 en manuel sur l'une de ses interfaces réseau.
13 years 11 months ago #5195 by colinc
Replied by colinc on topic bug d'ouverture de show offline en 3.0.10
@Nico
One other observation - DLight does *not* appear as a node to Artnetominator :
www.lightjams.com/artnetominator/
which is a very useful (and free!)general utility (for Windows anyway) for discovering what any ArtNet universes might be doing.
I observed the above when I was trying to get DLight to play a little bit with iLED on my iPod. iLed can create a 6x4 Pixel Display on an iPod/iPhone or iPad via ArtNet and a wifi connection (ie no actual hardware ArtNet node needed), and I had managed a sample FX using Jands Vista2 software - but when I tried with DLight to send a basic 3 or four channel RGB or RGBW to iLED, it did not respond at all. It didn't matter whether I was using a 2.x.x.x or 10.x.x.x addressing range. Unfortunately my iPod has now died, so I can't keep trying...
Regards
13 years 11 months ago #5197 by sl1200mk2
Replied by sl1200mk2 on topic bug d'ouverture de show offline en 3.0.10
@Colin,
DL do not act as a node, neither as a server (wich make me thing I should change the 'Start ArtNet Server' in the artnet editor).
DL is designed to find nodes and to connect to them.
i'll have a look to iLED and see why it does not respond.
13 years 11 months ago #5198 by colinc
@Nico
Sorry, that should be iLEDMapper !
url: iledmapper.geldreich.net/
Time to create page: 0.125 seconds
