Channel check -- freeze program
14 years 7 months ago #4138 by vbs
Channel check -- freeze program was created by vbs
With 3.07 runiing on Osx i have à problem with THE channel check .
When i click channel to check it keeps on runnend Unitill THE last channel..and don,t stop anymore
THE program is stuc and i have to shut down..
regards Vincent
14 years 7 months ago #4141 by sl1200mk2
Replied by sl1200mk2 on topic Re: Channel check -- freeze program
Vincent,
in other words you're able to check the channels using down/up arrows, but at the end (the last channel), it goes further and you can't close the check channel windows?
is that your problem?
14 years 7 months ago #4150 by vbs
Replied by vbs on topic Re: Channel check -- freeze program
Hi Nico,
No that is not. i use the arrow to check and after checking some channels it keeps on running by it self.
can stop any more.
I have to restart the program. I had this problem 5x in a row so i stopt cheching the channels this way.
The next day the problem did't happen ?????
Vincednt
14 years 7 months ago #4175 by sl1200mk2
Vincent,
i know this error, it's related to key repetition.... and hard to fix....
can you please try with the latest beta available and if you still got this problem, post in the thread related to 3.0.8_b1 like that i won't forget to fix it.
14 years 7 months ago #4184 by vbs
Hi
I just tried the 3.0.8 version and it seems to work better, aldo it was not a problem all the time.
Ill let you know if it apears again.
Thank You !
Time to create page: 0.125 seconds
