3.0.5 (Release)
15 years 7 months ago #2284 by db-kristian
Replied by db-kristian on topic Re: 3.0.5 (Release)
oui le coup de la fenêtre d'erreur qui bloque tout c'est con j'ai fait pas mal d'aller retour en régie à cause de ça :(
15 years 5 months ago #2510 by sonolivier85
Replied by sonolivier85 on topic Re: 3.0.5 (Release)
Hello
I tried the 3.05 and like the improvements.
There are two problems i think.
There is a problem with the .sho encode to older version.
The que list is exported but there is no dimmer info also no Sequence is encoded.
If i record a sample and assign it to a submaster it is ok, but if i edit the sample the change is not visible in the submaster.
Are you also planning to make .1 steps available in the future?
15 years 5 months ago #2511 by sl1200mk2
Replied by sl1200mk2 on topic Re: 3.0.5 (Release)
hi,
when do you have a problem? when you want to encode former show to the new .sho file format or when you want to decode new .sho to the former form?
ok i'll check that
no, steps will always be +1
but you can create 1000000 cues between 1.0 and 2.0. i think that's enough for many uses ;-)
15 years 5 months ago - 15 years 5 months ago #2512 by reno-
Replied by reno- on topic Re: 3.0.5 (Release)
Salut. Je n'arrive pas a avoir de retour d'infos circuits ou cue pour savoir quel cue ou circuit est sur scene. Pourriez vous me dire quelle syntax utiliser et avec quelle fonction de osc édit. "label" ou autre. Merci
Last edit: 15 years 5 months ago by reno-.
15 years 5 months ago #2513 by sonolivier85
Hi,
The Problem is when i want to decode new .sho to the former form
15 years 5 months ago #2514 by JoMa
Replied by JoMa on topic Re: 3.0.5 (Release)
tu peux allervoir dans le wiki du site, section midi et osc, toutes les syntaxes sont écrites (et mises à jour il me semble)
a+
pipou
15 years 5 months ago #2515 by sl1200mk2
@vbs
on wich platform?
15 years 5 months ago #2528 by sonolivier85
Hi,
This is on OSX Intel 10.6.7
15 years 5 months ago #2530 by sl1200mk2
@vbs
ok, i'll check that.
i think i've fixed the sample modify issue.
please can you test that particulary with the next 3.0.6 beta release.
15 years 5 months ago #2534 by reno-
fabien.wen wrote: Salut. Je n'arrive pas a avoir de retour d'infos circuits ou cue pour savoir quel cue ou circuit est sur scene. Pourriez vous me dire quelle syntax utiliser et avec quelle fonction de osc édit. "label" ou autre. Merci
En fait je suis un gros NAZ je n'avais pas bien reglé le writer OSC.
Merci qd même je m'éclate et me prépare un petit pad perso... Vraiment trop bon cet outil
15 years 5 months ago #2563 by sl1200mk2
@vbs
can you post here, the .sho wich is malformed when you want to decode it?
i've tried with some sho i have and they all decoded fine
thanks
15 years 5 months ago #2566 by sonolivier85
Here is the show that i have a problem with
15 years 5 months ago #2568 by sl1200mk2
@vbs
the sho you sent me decode fine here.
for example, it produce the joined seq list wich seems to be fine.
i don't know if it's possible to reopen with previous realease of DL a show passed throught 3.0.6_b3...
15 years 5 months ago #2569 by sonolivier85
How about the que list
15 years 5 months ago #2570 by sl1200mk2
the cue list is built after the sequence pass throught DL and against present cue in the memory folder.
do you have the same conduite.xml file?
does the memory folder is empty?
Time to create page: 0.186 seconds
