3.0.5_b7
15 years 8 months ago #2148 by sl1200mk2
3.0.5_b7 was created by sl1200mk2
à tester par rapport à la précédente:
tous les petits trucs que vous avez fait remonter
OSC : nouveau modèle (transparent pour vous) à tester en émission/réception
avec un peu de chance, c'est la dernière de la série...
15 years 8 months ago #2152 by samir
Replied by samir on topic Re: 3.0.5_b7
Hi
Bravo
XFade crash - no more!
File->Open problem - no more!
But... (There is always a 'But'...)
1) I cannot get the window position resaved. I am using two monitors, and have at some time put the DLight Window on Monitor 2 (so that I could see the SFX6 window on monitor 1. Now, if I try to reposition DL on monitor 1, and resave, it reloads on M2. This becomes a real problem if M1 is disconnected, because only a *tiny* portion of the edge of thw DL window is visible, *just* enough to grab the top and pull it onto the screen
2) The DL .sho files are no longer loadable by double-click on them, and if I try 'Open With...' and browse to DLight.exe and click ok, Windows does not open the exe into the list of applications. (I know this is perhaps a minor niggle, but sometimes to have the show file on the desktop is the quickest way to load it
Otherwise, superb
Best regards
15 years 8 months ago - 15 years 8 months ago #2154 by martko
Replied by martko on topic Re: 3.0.5_b7
hi,
Bugs OSC :
Le message '/seq/X1 xx' n'est plus transmit après un transfert.
Plantage de DLight sur réception de messages '/sub/xx/level xx'.
Idée (OSC):
Fonctionnement des subs (/sub/xx/level xx) comme le Grand Maître : Le message entrant ne serait alors valide qu'après avoir atteint la valeur de DLight.
Voila pour ce soir...
fxw
Last edit: 15 years 8 months ago by martko.
15 years 8 months ago #2155 by sl1200mk2
Replied by sl1200mk2 on topic Re: 3.0.5_b7
@fxw
un transfert manuel, automatique?
c'est bizarre ça, j'ai touché qu'à l'émission des messages OSC....
aurais-tu un rapport d'erreur à poster et des détails quand au crash - ça arrive dès le début du contrôle, ça arrive près de FF, sur n'importe quel sub...
j ne le ferais pas pour la 3.0.5 mais t'as raison faudrait que ça fonctionne comme ça...
de toute façon, c'est un algorithme que je dois réécrire....
15 years 8 months ago #2156 by sl1200mk2
ici, /sub/xx/level xx fonctionne bien.....
15 years 8 months ago #2158 by martko
Salut Nico
sl1200mk2 wrote: un transfert manuel, automatique?
Un transfert automatique, apres GO ou GOBACK
Sur un transfert manuel, c'est le message '/fadeX2 xx xx' qui est transmit aléatoirement.
!!!/sub/xx/level xx fonctionne bien pour moi aussi !!!
Les crashs de DL semble aléatoire sur réception ou envoie de message OSC.
J'en ai eu deux hier soir et je viens d'en avoir un ce matin.
DLight à crash (quitter...parti...) et je n'arrive pas à reproduire ce bug.
pour info : MacOs 10.6.6, XQuartz 2.6.0, Max/MSP 5.1.7
fxw
15 years 8 months ago #2159 by sl1200mk2
@fx,
dans /Applications/Utilitaires, se trouve une application qui se nomme Console, elle gère les crashs logs des appli et les infos de ton système (du kernel et des meilleures...)
bref,
dans l'arborescence de la fenêtre de Console, tu vas trouver un onglet nommé
informations de diagnostic et d'utilisation
puis
rapport de diagnostic de l'utilisateur.
tu fouilles un peu et tu devrait trouver un crash de DL qui correspond à tes manips (fais bien gaffe à l'heure et au jour, pour pas qu'on se retrouve avec des rapports d'erreurs d'anciennes versions)
et tu m'envoies un .zip de tout ça ;-)
15 years 8 months ago #2160 by martko
et voila !
15 years 8 months ago #2161 by DylanB01
Replied by DylanB01 on topic Re: 3.0.5_b7
je reviens sur le bug défilement rapide via step+: toujours présent dans la b7 sur go et step+ maintenus enfoncés , il semble effectivement disparaitre lorsque je regle la vitesse de répétition au plus lent.
15 years 8 months ago #2162 by db-kristian
Replied by db-kristian on topic Re: 3.0.5_b7
Probléme du X fade ok mais il affiche les pourcent de transfère que une fois sur deux.
15 years 8 months ago #2163 by db-kristian
Toujours dans les affichage : les valleur ne remonte pas quand on fait un go back si les projot son pas monter dans la mémoire d'ou on vient.
je mexplique :
si dans cue 1 on as le circuit 1@60 le 2@ 70
dans le cue 2 on as le cirtuit 2@30
lors d'un goback entre cue 2 à 1 on verras les valeur du circuit 2 bouger mais le circuit 1 apparaitras que lorsque le transfère sera terminé !
je sait pas si j'ai etait claire ?
15 years 8 months ago #2164 by sl1200mk2
@fx
j'ai affiné le modèle OSC qui ne devrait plus poser de pb quand à l'envoi aléatoire des messages /seq et /fade
à tester dans la beta suivante
@pierre
quand je fais un goback avec le bouton de la fenêtre principale, je ne constate pas le phénomène que tu décris...
tu le constates en midi ou quoi?
15 years 8 months ago #2165 by db-kristian
non non ! je te fait une chtite video de la chose...
15 years 8 months ago #2166 by sl1200mk2
je constate le phénomène en mode Only used channel (la baguette magique).
toi aussi, ou même en affichage normal?
15 years 8 months ago #2167 by db-kristian
Je confire je suis en mode baguette magique ! Pour l'autre j'ai pas tester et pour le coup je pourais pas avant cette aprem....
Pierre depuis la rue ;)
Time to create page: 0.238 seconds
