Curve save in patch
16 years 4 months ago #1197 by sonolivier85
Curve save in patch was created by sonolivier85
Hi Nico
An explanation about save a patch it does not remeber (safe) the curv.
And your answer:
you'right, but i don't know how to do as curves are related to the show, and not exactly to the Patch...
What i mend is that i use the curve patch to limit the output of dimmers..
Lets say if you visit a theater where the only have 2 or 5 kw lights, than you can set it at a max. of 80% in the dimmer patch.
In that case it would be handy to safe the patch file including the curves.
Thank you.
Regards Vincent
16 years 4 months ago #1198 by sl1200mk2
Replied by sl1200mk2 on topic Re:Curve save in patch
Vincent,
what if you use the grand-master to reduce all the levels?
my problem is that if we associate the curves in the patch file, what behaviour we choose when you unpatch a dimmer? reset the curve or not....
16 years 4 months ago #1201 by sonolivier85
Replied by sonolivier85 on topic Re:Curve save in patch
Yes i understand your point.
Putting the master at 80% will bring down al the channels and it is only necessary for curtain channels.
But i can live with it
Thanks and keep up the very good work you do.
Regards Vincent
Time to create page: 0.113 seconds
