Confused about Palette and leds behavior
- NachoL
1 day 6 hours ago #31078
by NachoL
Confused about Palette and leds behavior was created by NachoL
I try to explain. I have a show with 4 PARLed, a lot of scenes recorded, different colors, some palettes. In a new Theater I have to use 3 devices more, same than the ones I have (I merge this ones and create new devices the extra three). I have very hard time trying to unify the colors in the scenes. Don't get to record the same palette for everyone and use the palettes I have recorded. Could you explain me the best way to do this?
Some more video-tutorials would be very nice, the ones in the web page are very old
Thank You
Thank You
- LightUP69210
- Thank you received: 1
1 day 6 hours ago #31079
by LightUP69210
Replied by LightUP69210 on topic Confused about Palette and leds behavior
Hello.
If i have understood the problem:
Have you recorded the palettes with "same personality devices" mode selected?
If not, you must edit each palette to ad the ch if the new devices.
- Thank you received: 1083
1 day 6 hours ago #31080
Replied by sl1200mk2 on topic Confused about Palette and leds behavior
Hi,
in your case you would want to clone devices (in the deviceListing) in order to automatically add new ones to palettes and eventually to DLinks and Presets.
The following user(s) said Thank You: NachoL
- kreps
- Thank you received: 11
1 day 6 hours ago #31081
by kreps
Replied by kreps on topic Confused about Palette and leds behavior
English is not my forte, but i'll try to help.
Lightup is right, but you could also clone the devices instead of creating new ones and select clones source devices in palettes and clone source devices in cues and cuelink.
- kreps
1 day 6 hours ago #31083
by kreps
there is a new help button in the last version where you can find a lot of info. better than the wiki
- NachoL
1 day 6 hours ago #31084
by NachoL
Replied by NachoL on topic Confused about Palette and leds behavior
Ok, thank you. Can you explain a bit more what does to block a palette reference? what is a palette reference and when or why is it handy to block it?
Thanx
Thanx
- NachoL
1 day 6 hours ago #31085
by NachoL
Where is it?
- NachoL
1 day 6 hours ago - 1 day 5 hours ago #31086
by NachoL
...Where is the help button?
Last edit: 1 day 5 hours ago by NachoL.
1 day 6 hours ago #31087
Instead of créating your cue from scratch you can register Preset and build your cue with a référence to them.
for exemple your create a Preset for the backLights registered with some levels, and if you don’t block Preset référence, levels of the cue will be levels of the Preset. It’s very handy for Touring because if you modify the Preset every cues that référ to it will be updated.
but it can be a sort of gymnastic that is not easy for everyone… so Preset référence is blocked (not use) by default.
hope this helps
hope this helps
- kreps
1 day 6 hours ago #31088
by kreps
at the top,
File Edit ... Licence Help
you need the last versio of dlight
Time to create page: 0.150 seconds
