Que list
16 years 7 months ago #854 by sonolivier85
Que list was created by sonolivier85
When i record a new que and give it a name, then when i load it in the sequenze/step the name does not apear, in de sequenze/ step list.
Also is it posible to make a record or store button in the numeriek spaceto record a que.
regards vincent
16 years 7 months ago #862 by sl1200mk2
Replied by sl1200mk2 on topic Re:Que list
hi,
when you record a text to a cue, it belongs to the cue.
when you insert a cue in the sequence, it will not load the text. the text you see under the sequence panel of the main window belongs to the sequence, not to the cues.
from the COM button at the right of the main window, you can have access to Load/Modify/Record facilities.
Time to create page: 0.106 seconds
