Chaser + Cue List
11 months 3 weeks ago #29339 by Kpumba
Chaser + Cue List was created by Kpumba
HOla,
tengo un 'chaser' guardado y no se si se puede guardar dentro de una cue, que cuando hagas GO, la cue tenga el 'chaser'
es posible hacerlo?
grácias
11 months 3 weeks ago #29340 by sl1200mk2
Replied by sl1200mk2 on topic Chaser + Cue List
you'll want to use MasterLinks for that purpose.
Load your Chaser in a Submaster. (you can also use another Submaster for Speed Control)
at the step you want the Chaser to be played, record a masterLink (M∞) for your Submaster. You can set the target and Timings for the Submaster.
please not that you'll want another M∞ at some point to close the Submaster (Target at 0)
The following user(s) said Thank You: Kpumba
Time to create page: 0.109 seconds
