Chasers speed & Strobo effect
2 years 4 months ago #26967 by NachoL
Chasers speed & Strobo effect was created by NachoL
Hola, could somebody explain me how to be able to manually change the speed of a chaser for example programming a fader for that? could it be that the dimmer is. fixed in the chaser and the fader of submaster changes the speed?  is this possible?
...are you planning to include some FX patterns in the future?
Thanx!!
2 years 4 months ago #26968 by sl1200mk2
Replied by sl1200mk2 on topic Chasers speed & Strobo effect
Hola,
let's say you Chaser is loaded in Sub 1, open the Chaser Editor for another Sub, click on the 'Load' button and select SPEED.
Now you need to define for which Sub it's the Speed, so choose your Sub 1.
the new Speed submaster is at 50% by default, under this value you slow down the Chaser, above you speed it up.
using the playMode of the sub Speed you can also define in which way the Chaser is played (aka CWise, CCWise or Random).
of course
2 years 4 months ago #26969 by NachoL
Replied by NachoL on topic Chasers speed & Strobo effect
Great, Thanx a lot
Time to create page: 0.120 seconds
