how to connect D:LIGHT to WYSIWYG using sACN on 2 different laptop
2 years 11 months ago #25873 by MAscene
Dear All
I am trying to connect D:LIGHT with WYSIWYG on two diferrent laptop using sACN
[could not connect the following console: sACN ]
note that connextion  works  with GMA  ( IP are good )
do i forgot something is there any tricks
many thaks
jc
2 years 11 months ago #25874 by Poypoy
If it works with GMA, there's no reason why it shouldn't work with DLight.
Check in DLight:
- Setup/DMX Utility :   Available Universe you need to stream
- SetUp/NetDMX/Writer Setting : Be sure to select the right Network Interface (after the connection of the other computer if you use DHCP / self-assigned IP)
- SetUp/NetDMX : Select E1.31 (sACN) and turn Red button to green "ON"
That works at home with a single RJ45 (without Switch or Router) with self-assigned IP address on both computer (169.254.XXX.XXX)
The following user(s) said Thank You: sl1200mk2, MAscene
2 years 11 months ago #25877 by MAscene
many thanks for that quick reply
is may be D:LIGHT was in DEMO mode?
as I restared laptop demo mode was not mentioned on the top pad comment.
regards
2 years 11 months ago #25878 by Poypoy
Hi!
Indeed, the license must be activated, otherwise the DMX output is altered in demo mode
Time to create page: 0.122 seconds
