X-Fader behavior
- stebian
When halfway moving into a new cue and then back, it doesn't matter which other cue I load into prep register, I always have to fade through the cue I like to skip.
That doesn't apply for the use of GO and GOBACK buttons.
stephan
my English is not as accurate to exactly understand what you mean....
can you post a video or something and tell me what's the wrong behaviour you observe
- stebian
What happens is that if I fade halfway into the new cue and then back, that new cue gets locked into the prep register. I can load any ather cue into prep but it will fade into the "locked" cue first.
stephan
it's clear... thanks you for the video.
for now I have to find a way to replicate it in OSC.... which version of
:Light do you use?++
- stebian
would you mind testing a preview? which system are you running?
- stebian
I've uploaded DL4.3.21_b1 in the download/beta section of the website.
thank you for your feedback
- stebian
may I ask you what's is your hardware? it's not that common to find hardware that exports OSC command...
- stebian
:Light. I wanted a lightwight lighting desk which I can take on the airplane if I do a show somewhere far away. So it consists of two OSC controllers actually that i can fold into one little wooden case. One is just a faderbank of 48 faders and the other one has 24 fader plus buttons to control
:Light plus master faders and X-faders.Both controllers are based on the Teensy 3.6 microcontroller.
But we chatted about that 3 years or so ago.
stephan
I think you've built what a looooot of people want!!
I remember our chatting , but I forgot (so shamed....)...
did the wheel also works?
the Width x Height of the box looks very nice, the design too !!
it's handMade but can it be serialMade?
- stebian
The wheel works as well.
I'm sure it can be manufactured in series. That would involve a lot of work of course. Not sure how to do that.
stephan
from my point of view, doing hardware involve a lot of CEE certifications and boring things that I don't wish to anyone.
sharing code and PCB stuff (along with screwing diagram ) could be something but that's up to you.
