Bad file format - conversion Dlight 3 vers Dlight 4?
4 years 6 months ago #23168 by Artamuse
je veux récupérer un vieux show créé sous Dlight 3 et l'utiliser sous Dlight 4.3.04.
J'ai le message "bad file format".
J'ai le même problème d'ouverture sur MAC et PC.
Que faut-il faire? Forcément, c'est urgent....
Fichier sho joint.
Merci de ton aide
4 years 6 months ago #23169 by sl1200mk2
Hello
c urgent pour quand ?
4 years 4 months ago #23436 by tamarcblom
Hi, Im trying to open a sho that I made in 2017 and haven't opened since in the new Dlight but I'm not managing. It tells me : Bad file format. What am I supposed to do? I saw something in this thread about converting the files. but i have no clue how to do this. Could you maybe help me?
I put the files with this message.
best
4 years 4 months ago #23437 by sl1200mk2
@tamarcblom
here are your sho converted for D::Light 4.3.xx
The following user(s) said Thank You: tamarcblom
4 years 4 months ago #23440 by tamarcblom
That works! thank you very much!
Saved my day.
4 years 4 months ago #23460 by tamarcblom
Hello Nicolas,
Thank you for your help with the conversion.
I've hit another problem. For some reason, some of my channels are not sent through the dmx. It depends on which .sho file I open. I have 20 channels open. with one version of the sho ch 9 - 12 dont work. In another version of the sho its 9 13 and 19. So its a bit random. Im not sure why it doesnt work. Could it have to do something with the conversion you did? Or is there a spot in the software I could check to have it fixed.
Hope to hear from you, thanks in advance.
best
4 years 4 months ago #23461 by sl1200mk2
@tamarcblom
Hi,
did you checked the Patch?
for example on finaleversievoorenkelerunplusrustaaneindtotaal12min_v43, output 9, 10, 11 & 12 are not patched...
4 years 4 months ago #23469 by tamarcblom
Hey Nicolas,
Yes I just found out. I'm sorry. I'm a bit of a technical noob with these things. thanks for your help
4 years 4 months ago #23473 by sl1200mk2
cool.
Time to create page: 0.175 seconds
