INHIBIT FUNCTION IN A SUBMASTER
- polillin
5 years 3 weeks ago #22092
by polillin
INHIBIT FUNCTION IN A SUBMASTER was created by polillin
I'd like to program a submaster to inhibit, lets say, the frontal light so in case it is too much intensity I can take out some live or in the process of readapting a show to a particular stage.
I put 'inhibit' in a submaster with all my frontal channels at full and click inhibit, but I can't get it working. I also tried with target in "00" but no result. Where am I wrong? Thanks!
- Thank you received: 1075
5 years 3 weeks ago #22093
Replied by sl1200mk2 on topic INHIBIT FUNCTION IN A SUBMASTER
Hi,
you have to open the submaster in order to inhib.
the more you'll open it, the more it'll inhib channels inside.
tell me if it's ok.
tell me if it's ok.
The following user(s) said Thank You: polillin
- polillin
5 years 3 weeks ago #22101
by polillin
Replied by polillin on topic INHIBIT FUNCTION IN A SUBMASTER
I do open the submaster and it only marks a square around the channels's level in the circuits screen, but it doesn't reduce the intensities.
- polillin
5 years 3 weeks ago #22102
by polillin
OK. I will answer myself. I found the solution in this old post
getdlight.com/forum/2-releases/5372-3-0-24-b2#8295
I was working blind, today I connected a PARLED and could verify that DLight does apply the inhibition and marks with a square the channels it inhibits BUT it does not reflect the actual intensities in the sequentiel, right? Even when the light is at 0%, the screen marks your channel at FULL (in my case) with a square around it.
5 years 3 weeks ago #22103
that's it !
inhib does not modify displayed levels, it only applies on DMX output.
the reason is that sometimes you can inhib/scale some levels just for a moment but when you record/update a cue you probably want to record initial levels, not the scaled ones.
Time to create page: 0.135 seconds
