VLC avec D-Light
5 years 1 month ago #21998 by siger
VLC avec D-Light was created by siger
Bonjour, j'essaie d'utiliser VLC dans D-light pour y associer des tops son. En suivant les instructions du Wiki, je rentre les données dans D-Light : 127.0.0.1:8081 et je fais de même sur VLC avec Lua. Je lance VLC avant D-Light. Et pourtant aucune connexion n'est établie. Le bouton en haut à droite de la fenêtre du setup VLC reste rouge sur "OFF".
Quelqu'un peut-il m'aider à comprendre ??
Merci d'avance
Régis
5 years 1 month ago #22021 by sl1200mk2
Replied by sl1200mk2 on topic VLC avec D-Light
sur macOS ? PC ? Linux ?
sur PC faut p-e mettre une règle dans ton firewall...
5 years 1 month ago #22053 by polillin
Replied by polillin on topic VLC avec D-Light
I,m not sure enough of which was the cause, but yesterday my D:Light couldn't recognize my VLC neither.
Everything supposedly allright and red light OFF.
I remember that:
1) I ensured myself to record the interfaz advanced preferences in VLC, close and open everything again.
2) I updated some pendant W10 options and restarted the PC. Suddenly it gave me green light.
(MAYBE OFFTOPIC, BUT RELATED...)
3) I installed the Korg Nanokontrol2 driver and D:light didn't recognize my USB-dmx EnttecPro (Red light again) but it worked when I reinstalled the enttec driver again
4) in MIDI, I had to look for a way to open the MIDI port with MIDI Tools.
5) today, I sent DMX to stage from Dlight and it didn't work, except for 2 lamps, hahahahahahaha, I had copied with another patch different than 1:1. Finally I noticed!
6) By the way, I use VLC to trigger a VLC list of music tracks with Slinks, but I have desisted of the Mlinks for volume control, I can't get it running perfectly, it kept giving me surprises on airshow, like keeping at zero and not fading in until FF...
5 years 1 month ago #22059 by sl1200mk2
@polillin
Hi,
Windows can be in an unstable state when there's some pendant updates and it requires you to restart.
I don't think it's related to your VLC issue.
but I guess the korg driver's installation screwed up the winUSB driver.
that's unfortunately windows drivers business ...
if I understand well you use Mlink to deal with volume control of VLC.
There's something you should know about MLinks in D::Light, as long as you don't touch Submasters with midi fader or whatever, MLinks will control them.
But if you touch Submasters with Midi faders or whatever, DL will not process MLinks for them anymore as long as MLink target != Submasters level.
The choice of this design is:
if the user haver decided to take manually control over the Submaster it'sd maybe because there is a problem and in case there's a problem, do not process them.
Hope it's clear and helpful
The following user(s) said Thank You: polillin
Time to create page: 0.131 seconds
