Dlight under Mojave 10.14.5
7 years 1 month ago #18788 by SoundSurfer
Dlight under Mojave 10.14.5 was created by SoundSurfer
Hey Nico,
I sugested a friend of mine to use Dlight, but his mac runs mojave. He already bought a licence. How is the Mojave-acceptability of dlight? I read one topic of someone who got it running after mutiple reboots, i tried the same but no luck so far. Any ideas?
happy coding!
jannes
7 years 1 month ago #18791 by sl1200mk2
Replied by sl1200mk2 on topic Dlight under Mojave 10.14.5
Hi Jannes,
DL should run fine on Mojave (please note that 10.14.6 is the actual OS) as the application is now signed and notarized from Apple.
the standard installation process is:
install Xquartz
reboot the computer
install DL and run it
where does it fails?
7 years 1 month ago #18794 by SoundSurfer
Replied by SoundSurfer on topic Dlight under Mojave 10.14.5
currently updating to 10.14.6. i suppose that would fix it. I'll let you know.
7 years 1 month ago #18795 by SoundSurfer
Hi nicolas,
I updated the mac to 10.14.6
I tried the following versions of Dlight with these results:
-4.1.04.b2 DLight opens, but only opens XQuartz. It does not ask anything, and XQuartz does nothing.
-4.1.03 DLight opens, but only opens XQuartz. It does not ask anything, and XQuartz does nothing.
4.0.31.b10 DLight asks for run, when I click run, XQuartz starts, but does nothing, DLight quits itself.
-4.0.30 DLight asks for run, when I click run, XQuartz starts, but does nothing, DLight quits itself.
-4.0.29.b2 DLight asks for run, when I click run, XQuartz starts, but does nothing, DLight quits itself.
any help?
7 years 1 month ago #18796 by sl1200mk2
let's focus on DL4103.
(do you have a dual monitor system)?
DL launching XQuartz is a good sign, it means macOS 10.14 recognize DL as a trusted app and let him launch XQuartz.
did you try (as you did with your computer) to do Ctrl+Clic on DL icon in order to access to 'open anyway'?
7 years 1 month ago #18797 by SoundSurfer
Single monitor. macbookpro.
I did try that 'open anyway', but it didnt do anything.
7 years 1 month ago #18798 by sl1200mk2
open 'ActivityMonitor', check that a DLight process is NOT present.
if you find one kill it and try to launch DL again
7 years 1 month ago #18799 by SoundSurfer
when i run dlight, two instances of dlight appear in activity monitor, one with the logo, one without. when i force quit them both, xquartz stays active, but nothning happens. i tried to restart dlight, with xquarts still running, and without. no changes.
7 years 1 month ago #18800 by sl1200mk2
at this point, I don't know what else to try....
7 years 1 month ago #18801 by SoundSurfer
ok. I'll try some reboots. perhaps the 4.0.0.72 still works..
7 years 1 month ago #18802 by SoundSurfer
the thing is, DLight ran only once on this macbook, so the reason why it has stopped running is a mystery. I'll check with the owner of the macbook.
7 years 1 month ago #18803 by SoundSurfer
Ok, so i got some new info.
This macbook has two admin accounts. one for the owner, one for the show account.
I tried 4.0.0.b72 on the owner admin. that did run! then i installed 4.1.03 that also runs! Then i logged into the show admin account. nothing works. i go back to owner admin account. nothing works. now after rebooting everthing works fine
some how when i log into the other account, nothing works anymore.
good hunting ;-) thanks for your help anyway
7 years 1 month ago #18804 by sl1200mk2
hmmm,
would you mind summarize a little bit... :)
which account works? (with DL4103)
it's pretty unusual to have 2 admins accounts and you should at least delete one...
7 years 1 month ago #18805 by SoundSurfer
on the owners account works with DL4103.
on the show account it does not run.
7 years 3 weeks ago #18953 by Limmerick
Replied by Limmerick on topic Dlight under Mojave 10.14.5
xquartz is now opening and quitting itself with this error: any help::
Process: X11.bin [1196]
Path: /Applications/Utilities/XQuartz.app/Contents/MacOS/X11.bin
Identifier: org.macosforge.xquartz.X11
Version: 2.7.11 (2.7.112)
Code Type: X86-64 (Native)
Parent Process: ??? [1]
Responsible: X11.bin [1196]
User ID: 501
Date/Time: 2019-10-04 15:22:49.415 +0200
OS Version: Mac OS X 10.14.6 (18G95)
Report Version: 12
Bridge OS Version: 3.0 (14Y904)
Anonymous UUID: 4B720C3F-1559-F621-E180-9A18EB657291
Time Awake Since Boot: 240 seconds
System Integrity Protection: enabled
Crashed Thread: 5
Exception Type: EXC_CRASH (SIGABRT)
Exception Codes: 0x0000000000000000, 0x0000000000000000
Exception Note: EXC_CORPSE_NOTIFY
Application Specific Information:
X.Org X Server 1.18.4 Build Date: 20161025
Cannot establish any listening sockets - Make sure an X server isn't already running
abort() called
Thread 0:: Dispatch queue: com.apple.main-thread
0 libsystem_kernel.dylib 0x00007fff7292c1ee __open + 10
1 com.apple.Foundation 0x00007fff48b1d701 _NSReadBytesFromFileWithExtendedAttributes + 125
2 com.apple.Foundation 0x00007fff48ba79ac -[NSString initWithContentsOfFile:encoding:error:] + 83
3 com.apple.Foundation 0x00007fff48c27709 +[NSString stringWithContentsOfFile:encoding:error:] + 61
4 org.andymatuschak.Sparkle 0x00000001002421a1 -[SUHost publicDSAKey] + 152
5 org.andymatuschak.Sparkle 0x000000010024a8aa -[SUUpdater initForBundle:] + 352
6 org.andymatuschak.Sparkle 0x000000010024a733 +[SUUpdater updaterForBundle:] + 152
7 X11.bin 0x000000010000a081 -[X11Controller setup_sparkle] + 186
8 X11.bin 0x0000000100008791 X11ApplicationMain + 1463
9 X11.bin 0x000000010001101e server_main + 185
10 X11.bin 0x0000000100001b0b do_start_x11_server + 445
11 X11.bin 0x00000001000028a2 _Xstart_x11_server + 125
12 X11.bin 0x0000000100002a06 mach_startup_server + 80
13 libsystem_kernel.dylib 0x00007fff72942782 mach_msg_server + 430
14 X11.bin 0x00000001000020fd main + 1476
15 X11.bin 0x0000000100001518 start + 52
Thread 1:
0 libsystem_pthread.dylib 0x00007fff729e93f0 start_wqthread + 0
Thread 2:
Thread 3:
Thread 4:
Thread 5 Crashed:
0 libsystem_kernel.dylib 0x00007fff729312c6 __pthread_kill + 10
1 libsystem_pthread.dylib 0x00007fff729ecbf1 pthread_kill + 284
2 libsystem_c.dylib 0x00007fff7289b6a6 abort + 127
3 X11.bin 0x000000010012e8a3 OsAbort + 9
4 X11.bin 0x000000010000dfc3 AbortDDX + 23
5 X11.bin 0x0000000100134b36 AbortServer + 34
6 X11.bin 0x00000001001334fc FatalError + 315
7 X11.bin 0x0000000100129882 CreateWellKnownSockets + 1651
8 X11.bin 0x00000001000dc031 dix_main + 285
9 X11.bin 0x0000000100010f5e server_thread + 38
10 libsystem_pthread.dylib 0x00007fff729ea2eb _pthread_body + 126
11 libsystem_pthread.dylib 0x00007fff729ed249 _pthread_start + 66
12 libsystem_pthread.dylib 0x00007fff729e940d thread_start + 13
Thread 6:
0 libsystem_kernel.dylib 0x00007fff7292ef32 __semwait_signal + 10
1 libsystem_c.dylib 0x00007fff728ba914 nanosleep + 199
2 libsystem_c.dylib 0x00007fff728ba776 sleep + 41
3 X11.bin 0x00000001000239f7 xpbproxy_run + 213
4 X11.bin 0x0000000100008819 xpbproxy_x_thread + 9
5 libsystem_pthread.dylib 0x00007fff729ea2eb _pthread_body + 126
6 libsystem_pthread.dylib 0x00007fff729ed249 _pthread_start + 66
7 libsystem_pthread.dylib 0x00007fff729e940d thread_start + 13
Thread 5 crashed with X86 Thread State (64-bit):
rax: 0x0000000000000000 rbx: 0x0000700006a53000 rcx: 0x0000700006a52c78 rdx: 0x0000000000000000
rdi: 0x0000000000009c33 rsi: 0x0000000000000006 rbp: 0x0000700006a52cb0 rsp: 0x0000700006a52c78
r8: 0x00000000000130a8 r9: 0x00007fffa908b288 r10: 0x0000000000000000 r11: 0x0000000000000206
r12: 0x0000000000009c33 r13: 0x00007ffeefbff530 r14: 0x0000000000000006 r15: 0x000000000000002d
rip: 0x00007fff729312c6 rfl: 0x0000000000000206 cr2: 0x00007fffa9086188
Logical CPU: 0
Error Code: 0x02000148
Trap Number: 133
Binary Images:
0x100000000 - 0x1001b5fff +X11.bin (???) <C155122F-0027-361A-8BCA-A94C2A722F5B> /Applications/Utilities/XQuartz.app/Contents/MacOS/X11.bin
0x100238000 - 0x10025bff7 +org.andymatuschak.Sparkle (1.6 git - 1.6) <BE5E3396-7A0B-3C4C-8838-A7765B2B0A44> /Applications/Utilities/XQuartz.app/Contents/Frameworks/Sparkle.framework/Versions/A/Sparkle
0x10027a000 - 0x100287ff7 +libXplugin.1.dylib (1) <CAC780C2-5B07-313B-A3A2-74106D525846> /opt/X11/*/libXplugin.1.dylib
0x100292000 - 0x100293fff +libAppleWM.7.dylib (8) <2E5075C2-6FD0-3F66-A6C4-0C3CE5C1DDF3> /opt/X11/*/libAppleWM.7.dylib
0x100298000 - 0x10029bfff +libXfixes.3.dylib (5) <4C581BB8-C505-32A0-8D08-11DCDCF6446B> /opt/X11/*/libXfixes.3.dylib
0x1002a1000 - 0x1003acfff +libX11.6.dylib (10) <1BAB7ED3-D9A4-3AAD-9DBA-CCA9C5F54E49> /opt/X11/*/libX11.6.dylib
0x1003d6000 - 0x1003efff7 +libxcb.1.dylib (3) <FDEDEE32-91A5-3301-AFB5-50B8D4CCCBBD> /opt/X11/*/libxcb.1.dylib
0x100403000 - 0x10047dfff +libpixman-1.0.dylib (35) <1A0A1869-8383-3157-8F2B-533DAD7CC18F> /opt/X11/*/libpixman-1.0.dylib
0x100495000 - 0x1004c4fff +libXfont.1.dylib (6.1) <C8137553-50E4-3756-A918-6D0472132B99> /opt/X11/*/libXfont.1.dylib
0x1004d2000 - 0x10055afff +libfreetype.6.dylib (19.6) <51ECD8C8-7B61-3A4A-8C22-0E207ACC2383> /opt/X11/*/libfreetype.6.dylib
0x100576000 - 0x100579fff +libfontenc.1.dylib (2) <D14E1B5D-0069-37E9-9F9D-3F9B0E822791> /opt/X11/*/libfontenc.1.dylib
0x100580000 - 0x100581fff +libXau.6.dylib (7) <45CD2F7C-EDBB-3575-B883-9C397685B211> /opt/X11/*/libXau.6.dylib
0x100586000 - 0x100586fff +libxshmfence.1.dylib (2) <ED0A7C98-736F-3437-B406-2EB50F30E7ED> /opt/X11/*/libxshmfence.1.dylib
0x10058b000 - 0x10058efff +libXdmcp.6.dylib (7) <B8414558-7AF1-357E-9361-79D317C6AB28> /opt/X11/*/libXdmcp.6.dylib
0x100594000 - 0x1005a0fff +libXext.6.dylib (11) <899041F6-4E8D-322E-9A21-03BDB005BD63> /opt/X11/*/libXext.6.dylib
0x104f1a000 - 0x104f1d047 libobjc-trampolines.dylib (756.2) <5795A048-3940-3801-90CE-33D1B1AF81F4> /usr/lib/libobjc-trampolines.dylib
0x105564000 - 0x1055ce70f dyld (655.1.1) <DFC3C4AF-6F97-3B34-B18D-7DCB23F2A83A> /usr/lib/dyld
0x7fff3afc8000 - 0x7fff3b321fff com.apple.RawCamera.bundle (8.15.0 - 1031.4.4) <AB6E8A8F-0BFE-37EE-A135-44ABA4FCB559> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
0x7fff42c4a000 - 0x7fff42c4afff com.apple.Accelerate (1.11 - Accelerate 1.11) <762942CB-CFC9-3A0C-9645-A56523A06426> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x7fff42c4b000 - 0x7fff42c61ff7 libCGInterfaces.dylib (506.22) <1B6C92D9-F4B8-37BA-9635-94C4A56098CE> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/Libraries/libCGInterfaces.dylib
0x7fff42c62000 - 0x7fff432fbfef com.apple.vImage (8.1 - ???) <53FA3611-894E-3158-A654-FBD2F70998FE> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x7fff432fc000 - 0x7fff43575ff3 libBLAS.dylib (1243.200.4) <417CA0FC-B6CB-3FB3-ACBC-8914E3F62D20> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x7fff43576000 - 0x7fff435e8ffb libBNNS.dylib (38.250.1) <538D12A2-9B9D-3E22-9896-F90F6E69C06E> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBNNS.dylib
0x7fff435e9000 - 0x7fff43992ff3 libLAPACK.dylib (1243.200.4) <92175DF4-863A-3780-909A-A3E5C410F2E9> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x7fff43993000 - 0x7fff439a8feb libLinearAlgebra.dylib (1243.200.4) <CB671EE6-DEA1-391C-9B2B-AA09A46B4D7A> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLinearAlgebra.dylib
0x7fff439a9000 - 0x7fff439aeff3 libQuadrature.dylib (3.200.2) <1BAE7E22-2862-379F-B334-A3756067730F> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libQuadrature.dylib
0x7fff439af000 - 0x7fff43a2bff3 libSparse.dylib (79.200.5) <E78B33D3-672A-3C53-B512-D3DDB2E9AC8D> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparse.dylib
0x7fff43a2c000 - 0x7fff43a3ffe3 libSparseBLAS.dylib (1243.200.4) <E9243341-DB77-37C1-97C5-3DFA00DD70FA> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparseBLAS.dylib
0x7fff43a40000 - 0x7fff43c27ff7 libvDSP.dylib (671.250.4) <7B110627-A9C1-3FB7-A077-0C7741BA25D8> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x7fff43c28000 - 0x7fff43cdbff7 libvMisc.dylib (671.250.4) <D5BA4812-BFFC-3CD0-B382-905CD8555DA6> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x7fff43cdc000 - 0x7fff43cdcfff com.apple.Accelerate.vecLib (3.11 - vecLib 3.11) <74288115-EF61-30B6-843F-0593B31D4929> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0x7fff43e7e000 - 0x7fff44c33ffb com.apple.AppKit (6.9 - 1671.60.107) <2F7E5984-E89A-3451-A3DF-FAAA509CF884> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x7fff44c85000 - 0x7fff44c85fff com.apple.ApplicationServices (50.1 - 50.1) <84097DEB-E2FC-3901-8DD7-A670EA2274E0> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x7fff44c86000 - 0x7fff44cf1fff com.apple.ApplicationServices.ATS (377 - 453.11.2.2) <A258DA73-114B-3102-A056-4AAAD3CEB9DD> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x7fff44d8a000 - 0x7fff44ea1fff libFontParser.dylib (228.6.2.3) <3602D55B-3B9E-3B3A-A814-08C1244A8AE4> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
0x7fff44ea2000 - 0x7fff44ee4fff libFontRegistry.dylib (228.12.2.3) <2A56347B-2809-3407-A8B4-2AB88E484062> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
0x7fff44f3e000 - 0x7fff44f70fff libTrueTypeScaler.dylib (228.6.2.3) <7E4C5D9C-51AF-3EC1-8FA5-11CD4BEE477A> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libTrueTypeScaler.dylib
0x7fff44fd5000 - 0x7fff44fd9ff3 com.apple.ColorSyncLegacy (4.13.0 - 1) <C0D9E23C-ABA0-39DE-A4EB-5A41C5499056> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSyncLegacy.framework/Versions/A/ColorSyncLegacy
0x7fff45074000 - 0x7fff450c6ff7 com.apple.HIServices (1.22 - 628) <2BE461FF-80B9-30D3-A574-AED5724B1C1B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x7fff450c7000 - 0x7fff450d6fff com.apple.LangAnalysis (1.7.0 - 1.7.0) <F5617A2A-FEA6-3832-B5BA-C2111B98786F> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x7fff450d7000 - 0x7fff45120ff7 com.apple.print.framework.PrintCore (14.2 - 503.8) <57C2FE32-0E74-3079-B626-C2D52F2D2717> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x7fff45121000 - 0x7fff4515aff7 com.apple.QD (3.12 - 407.2) <28C7D39F-59C9-3314-BECC-67045487229C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x7fff4515b000 - 0x7fff45167fff com.apple.speech.synthesis.framework (8.1.3 - 8.1.3) <5E7B9BD4-122B-3012-A044-3259C97E7509> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x7fff45168000 - 0x7fff453dfff7 com.apple.audio.toolbox.AudioToolbox (1.14 - 1.14) <04F482F1-E1C1-3955-8A6C-8AA152AA06F3> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x7fff453e1000 - 0x7fff453e1fff com.apple.audio.units.AudioUnit (1.14 - 1.14) <ABC54269-002D-310D-9654-46CF960F863E> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x7fff4573a000 - 0x7fff45adbfff com.apple.CFNetwork (978.0.7 - 978.0.7) <B2133D0D-1399-3F17-80F0-313E3A241C89> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x7fff45af0000 - 0x7fff45af0fff com.apple.Carbon (158 - 158) <56AD06AA-7BB4-3F0B-AEF7-9768D0BC1C98> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x7fff45af1000 - 0x7fff45af4ffb com.apple.CommonPanels (1.2.6 - 98) <1CD6D56D-8EC7-3528-8CBC-FC69533519B5> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
0x7fff45af5000 - 0x7fff45decfff com.apple.HIToolbox (2.1.1 - 918.7) <13F69D4C-D19F-3E09-9231-1978D783A556> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x7fff45ded000 - 0x7fff45df0ff3 com.apple.help (1.3.8 - 66) <A08517EB-8958-36C9-AEE0-1A8FEEACBE3F> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
0x7fff45df1000 - 0x7fff45df6ff7 com.apple.ImageCapture (9.0 - 1534.2) <DB063E87-ED8F-3E4E-A7E2-A6B45FA73EF7> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
0x7fff45df7000 - 0x7fff45e8cff3 com.apple.ink.framework (10.9 - 225) <7C7E9483-2E91-3DD3-B1E0-C238F42CA0DD> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x7fff45e8d000 - 0x7fff45ea5ff7 com.apple.openscripting (1.7 - 179.1) <9B8C1ECC-5864-3E21-9149-863E884EA25C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
0x7fff45ec5000 - 0x7fff45ec6ff7 com.apple.print.framework.Print (14.2 - 267.4) <A7A9D2A0-D4E0-35EF-A0F7-50521F707C33> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
0x7fff45ec7000 - 0x7fff45ec9ff7 com.apple.securityhi (9.0 - 55006) <05717F77-7A7B-37E6-AB3E-03F063E9095B> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
0x7fff45eca000 - 0x7fff45ed0ff7 com.apple.speech.recognition.framework (6.0.3 - 6.0.3) <3CC050FB-EBCB-3087-8EA5-F378C8F99217> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x7fff45ff2000 - 0x7fff45ff2fff com.apple.Cocoa (6.11 - 23) <8D092DD2-0CA4-34C9-872C-8BBFAE1995A4> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x7fff46000000 - 0x7fff4614fff7 com.apple.ColorSync (4.13.0 - 3345.6) <31648BB6-7239-3D0E-81B1-BCF51FEF557F> /System/Library/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x7fff462db000 - 0x7fff46361fff com.apple.audio.CoreAudio (4.3.0 - 4.3.0) <1E8E64E6-0E58-375A-97F7-07CB4EE181AC> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x7fff463c5000 - 0x7fff463efffb com.apple.CoreBluetooth (1.0 - 1) <A73F1709-DD18-3052-9F22-C0015278834B> /System/Library/Frameworks/CoreBluetooth.framework/Versions/A/CoreBluetooth
0x7fff463f0000 - 0x7fff46775fef com.apple.CoreData (120 - 866.6) <132CB39B-8D58-30FA-B8AD-49BFFF34B293> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x7fff46776000 - 0x7fff46866ff7 com.apple.CoreDisplay (101.3 - 110.18) <0EB2A997-FCAD-3D17-B140-9829961E5327> /System/Library/Frameworks/CoreDisplay.framework/Versions/A/CoreDisplay
0x7fff46867000 - 0x7fff46cabfe7 com.apple.CoreFoundation (6.9 - 1575.19) <B2850F42-CE01-3156-B121-FD4777290C8F> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x7fff46cad000 - 0x7fff4733cfff com.apple.CoreGraphics (2.0 - 1265.9) <BC95B558-EF77-3A57-A0BC-11606C778991> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x7fff4733e000 - 0x7fff4765efff com.apple.CoreImage (14.4.0 - 750.0.140) <11026E39-D2FF-3CF6-8ACE-7BA293F9853E> /System/Library/Frameworks/CoreImage.framework/Versions/A/CoreImage
0x7fff4795b000 - 0x7fff47a5ffff com.apple.CoreMedia (1.0 - 2290.13) <A739B93D-23C2-3A34-8D61-6AC924B9634F> /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
0x7fff47abc000 - 0x7fff47abcfff com.apple.CoreServices (946 - 946) <6EC9F377-EBD8-3358-92D1-6586F6F1E8E9> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x7fff47abd000 - 0x7fff47b39ff7 com.apple.AE (773 - 773) <55AE7C9E-27C3-30E9-A047-3B92A6FD53B4> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x7fff47b3a000 - 0x7fff47e11fff com.apple.CoreServices.CarbonCore (1178.33 - 1178.33) <CB87F0C7-2CD6-3983-8E32-B6A2EC925352> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x7fff47e12000 - 0x7fff47e5aff7 com.apple.DictionaryServices (1.2 - 284.16.4) <746EB200-DC51-30AE-9CBC-608A7B4CC8DA> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
0x7fff47e5b000 - 0x7fff47e63ffb com.apple.CoreServices.FSEvents (1239.200.12 - 1239.200.12) <8406D379-8D33-3611-861B-7ABD26DB50D2> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framework/Versions/A/FSEvents
0x7fff47e64000 - 0x7fff48015ff7 com.apple.LaunchServices (946 - 946) <A0C91634-9410-38E8-BC11-7A5A369E6BA5> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x7fff48016000 - 0x7fff480b4ff7 com.apple.Metadata (10.7.0 - 1191.57) <BFFAED00-2560-318A-BB8F-4E7E5123EC61> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x7fff480b5000 - 0x7fff480ffff7 com.apple.CoreServices.OSServices (946 - 946) <20C4EEF8-D5AC-39A0-9B4A-78F88E3EFBCC> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x7fff48100000 - 0x7fff48167ff7 com.apple.SearchKit (1.4.0 - 1.4.0) <DA08AA6F-A6F1-36C0-87F4-E26294E51A3A> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x7fff48168000 - 0x7fff48189ff3 com.apple.coreservices.SharedFileList (71.28 - 71.28) <487A8464-729E-305A-B5D1-E3FE8EB9CFC5> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SharedFileList.framework/Versions/A/SharedFileList
0x7fff48494000 - 0x7fff485f6ff3 com.apple.CoreText (352.0 - 584.26.3.2) <59919B0C-CBD5-3877-8D6F-D6048F1E5F42> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
0x7fff485f7000 - 0x7fff48637ff3 com.apple.CoreVideo (1.8 - 281.4) <10CF8E52-07E3-382B-8091-2CEEEFFA69B4> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x7fff48638000 - 0x7fff486c7fff com.apple.framework.CoreWLAN (13.0 - 1375.2) <BF4B29F7-FBC8-3299-98E8-C3F8C04B7C92> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
0x7fff4891e000 - 0x7fff48923ffb com.apple.DiskArbitration (2.7 - 2.7) <F481F2C0-884E-3265-8111-ABBEC93F0920> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x7fff48ae9000 - 0x7fff48e96ffb com.apple.Foundation (6.9 - 1575.19) <A85BF812-B784-36B9-89BB-E29772B0708C> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x7fff48f05000 - 0x7fff48f34ffb com.apple.GSS (4.0 - 2.0) <E2B90D08-3857-3155-9FCC-07D778988EC9> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
0x7fff49034000 - 0x7fff4913efff com.apple.Bluetooth (6.0.14 - 6.0.14d3) <C2D1A774-2390-363D-8215-BF51FFCB6CCA> /System/Library/Frameworks/IOBluetooth.framework/Versions/A/IOBluetooth
0x7fff491a1000 - 0x7fff49230fff com.apple.framework.IOKit (2.0.2 - 1483.260.4) <8A90F547-86EF-3DFB-92FE-0E2C0376DD84> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x7fff49232000 - 0x7fff49241ffb com.apple.IOSurface (255.6.1 - 255.6.1) <85F85EBB-EA59-3A8B-B3EB-7C20F3CC77AE> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
0x7fff49295000 - 0x7fff49420fef com.apple.ImageIO.framework (3.3.0 - 1850.2) <75E46A31-D87D-35CE-86A4-96A50971FDB2> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x7fff49421000 - 0x7fff49425ffb libGIF.dylib (1850.2) <4774EBDF-583B-3DDD-A0E1-9F427CB6A074> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x7fff49426000 - 0x7fff49502fef libJP2.dylib (1850.2) <697BB77F-A682-339F-8659-35432962432D> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
0x7fff49503000 - 0x7fff49528feb libJPEG.dylib (1850.2) <171A8AC4-AADA-376F-9F2C-B9C978DB1007> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x7fff497eb000 - 0x7fff49811feb libPng.dylib (1850.2) <FBCEE909-F573-3AD6-A45F-AF32612BF8A2> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x7fff49812000 - 0x7fff49814ffb libRadiance.dylib (1850.2) <56907025-D5CE-3A9E-ACCB-A376C2599853> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x7fff49815000 - 0x7fff49862fe7 libTIFF.dylib (1850.2) <F59557C9-C761-3E6F-85D1-0FBFFD53ED5C> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x7fff49b5d000 - 0x7fff4a9bdfff com.apple.JavaScriptCore (14607 - 14607.3.9) <9B7D9E8B-619D-34A1-8FA9-E23C0EA3CD02> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
0x7fff4a9d5000 - 0x7fff4a9eefff com.apple.Kerberos (3.0 - 1) <DB1E0679-37E1-3B93-9789-32F63D660C3B> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
0x7fff4aca8000 - 0x7fff4acb2fff com.apple.MediaAccessibility (1.0 - 114.4) <76C449C5-DB45-3D7F-BFAD-3DACEF15DA21> /System/Library/Frameworks/MediaAccessibility.framework/Versions/A/MediaAccessibility
0x7fff4ad62000 - 0x7fff4b408fff com.apple.MediaToolbox (1.0 - 2290.13) <71BB5D76-34CA-3A30-AECF-24BE29FCC275> /System/Library/Frameworks/MediaToolbox.framework/Versions/A/MediaToolbox
0x7fff4b40a000 - 0x7fff4b4b2ff7 com.apple.Metal (162.2 - 162.2) <FFF7DFF3-7C4E-32C6-A0B5-C356079D3B7C> /System/Library/Frameworks/Metal.framework/Versions/A/Metal
0x7fff4b4ce000 - 0x7fff4b4edff7 com.apple.MetalPerformanceShaders.MPSCore (1.0 - 1) <44CE8362-E972-3697-AD6F-15BC863BAEB8> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSCore.framework/Versions/A/MPSCore
0x7fff4b4ee000 - 0x7fff4b56afe7 com.apple.MetalPerformanceShaders.MPSImage (1.0 - 1) <EE8440DA-66DF-3923-ABBC-E0543211C069> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSImage.framework/Versions/A/MPSImage
0x7fff4b56b000 - 0x7fff4b592fff com.apple.MetalPerformanceShaders.MPSMatrix (1.0 - 1) <E64450DF-2B96-331E-B7F4-666E00571C70> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSMatrix.framework/Versions/A/MPSMatrix
0x7fff4b593000 - 0x7fff4b6beff7 com.apple.MetalPerformanceShaders.MPSNeuralNetwork (1.0 - 1) <F2CF26B6-73F1-3644-8FE9-CDB9B2C4501F> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSNeuralNetwork.framework/Versions/A/MPSNeuralNetwork
0x7fff4b6bf000 - 0x7fff4b6d9fff com.apple.MetalPerformanceShaders.MPSRayIntersector (1.0 - 1) <B33A35C3-0393-366B-ACFB-F4BB6A5F7B4A> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSRayIntersector.framework/Versions/A/MPSRayIntersector
0x7fff4b6da000 - 0x7fff4b6dbff7 com.apple.MetalPerformanceShaders.MetalPerformanceShaders (1.0 - 1) <69F14BCF-C5C5-3BF8-9C31-8F87D2D6130A> /System/Library/Frameworks/MetalPerformanceShaders.framework/Versions/A/MetalPerformanceShaders
0x7fff4c4d2000 - 0x7fff4c4deff7 com.apple.NetFS (6.0 - 4.0) <E917806F-0607-3292-B2D6-A15404D61B99> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
0x7fff4ef7c000 - 0x7fff4efd3ff7 com.apple.opencl (2.15.3 - 2.15.3) <056BAD8A-23BC-3F74-9E2C-3AC81E7DEA5A> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
0x7fff4efd4000 - 0x7fff4efefff7 com.apple.CFOpenDirectory (10.14 - 207.200.4) <F03D84EB-49B2-3A00-9127-B9A269824026> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
0x7fff4eff0000 - 0x7fff4effbffb com.apple.OpenDirectory (10.14 - 207.200.4) <A8020CEE-5B78-3581-A735-EA2833683F31> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
0x7fff4f94b000 - 0x7fff4f94dfff libCVMSPluginSupport.dylib (17.7.3) <8E051EA7-55B6-3DF1-9821-72C391DE953B> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dylib
0x7fff4f94e000 - 0x7fff4f953ff3 libCoreFSCache.dylib (166.2) <222C2A4F-7E32-30F6-8459-2FAB98073A3D> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreFSCache.dylib
0x7fff4f954000 - 0x7fff4f958fff libCoreVMClient.dylib (166.2) <6789ECD4-91DD-32EF-A1FD-F27D2344CD8B> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
0x7fff4f959000 - 0x7fff4f961ff7 libGFXShared.dylib (17.7.3) <8C50BF27-B525-3B23-B86C-F444ADF97851> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
0x7fff4f962000 - 0x7fff4f96dfff libGL.dylib (17.7.3) <2AC457EA-1BD3-3C8E-AFAB-7EA6234EB749> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x7fff4f96e000 - 0x7fff4f9a8fef libGLImage.dylib (17.7.3) <AA027AFA-C115-3861-89B2-0AE946838952> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
0x7fff4fb1c000 - 0x7fff4fb5afff libGLU.dylib (17.7.3) <CB3B0579-D9A2-3CA5-8942-0C8344FAD054> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x7fff504f7000 - 0x7fff50506ffb com.apple.opengl (17.7.3 - 17.7.3) <94B5CF34-5BD6-3652-9A8C-E9C56E0A9FB4> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x7fff51309000 - 0x7fff51560ff7 com.apple.QuartzCore (1.11 - 701.14) <33E846BE-1794-3186-9BF2-6ADF62C782A3> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x7fff51d95000 - 0x7fff52095fff com.apple.security (7.0 - 58286.270.3.0.1) <DF7677A7-9765-3B6A-9D1C-3589145E4B65> /System/Library/Frameworks/Security.framework/Versions/A/Security
0x7fff52096000 - 0x7fff52122fff com.apple.securityfoundation (6.0 - 55185.260.1) <1EE899E6-222A-3526-B505-B0D0B6FA042A> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
0x7fff52123000 - 0x7fff52153ffb com.apple.securityinterface (10.0 - 55109.200.8) <02B83641-2D21-3DB8-AAB8-6F8AAD0F6264> /System/Library/Frameworks/SecurityInterface.framework/Versions/A/SecurityInterface
0x7fff52154000 - 0x7fff52158fff com.apple.xpc.ServiceManagement (1.0 - 1) <FCF7BABA-DDDD-3770-8DAC-7069850203C2> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
0x7fff524f1000 - 0x7fff5255efff com.apple.SystemConfiguration (1.17 - 1.17) <30C8327F-3EFF-3520-9C50-016F8B6B954F> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x7fff527bd000 - 0x7fff52b1efff com.apple.VideoToolbox (1.0 - 2290.13) <7FCB2FC0-EFB8-37C2-B0D3-60AE9FDFE230> /System/Library/Frameworks/VideoToolbox.framework/Versions/A/VideoToolbox
0x7fff52df3000 - 0x7fff533ffff7 libwebrtc.dylib (7607.3.9) <4D2A43AD-B95E-3CF7-8822-553411D3EF15> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versions/A/Frameworks/libwebrtc.dylib
0x7fff53400000 - 0x7fff54d86ff7 com.apple.WebCore (14607 - 14607.3.9) <F50B7FC8-60F1-3FC4-83E1-0065463B27E6> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versions/A/WebCore
0x7fff54d87000 - 0x7fff54f78ffb com.apple.WebKitLegacy (14607 - 14607.3.9) <59707811-F21F-388C-A801-C51D32E99392> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebKitLegacy.framework/Versions/A/WebKitLegacy
0x7fff54f79000 - 0x7fff554c9ff7 com.apple.WebKit (14607 - 14607.3.9) <AE6029DD-0CED-3FEF-92D5-DB8D4F9757F9> /System/Library/Frameworks/WebKit.framework/Versions/A/WebKit
0x7fff5579a000 - 0x7fff5583ffeb com.apple.APFS (1.0 - 1) <2D22485D-552D-3CB6-9FE1-38547597918F> /System/Library/PrivateFrameworks/APFS.framework/Versions/A/APFS
0x7fff55dcc000 - 0x7fff55dd6fff com.apple.accessibility.AXCoreUtilities (1.0 - 1) <C97597AF-865F-3A33-A6EB-807EE9881521> /System/Library/PrivateFrameworks/AXCoreUtilities.framework/Versions/A/AXCoreUtilities
0x7fff56254000 - 0x7fff56255ff7 com.apple.AggregateDictionary (1.0 - 1) <A6AF8AC4-1F25-37C4-9157-A02E9C200926> /System/Library/PrivateFrameworks/AggregateDictionary.framework/Versions/A/AggregateDictionary
0x7fff56856000 - 0x7fff56882ff7 com.apple.framework.Apple80211 (13.0 - 1380.2) <16F093EF-370B-3B90-8DB4-E94624431D15> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211
0x7fff569aa000 - 0x7fff569b9fc7 com.apple.AppleFSCompression (96.200.3 - 1.0) <3CF60CE8-976E-3CB8-959D-DD0948C1C2DE> /System/Library/PrivateFrameworks/AppleFSCompression.framework/Versions/A/AppleFSCompression
0x7fff56ab5000 - 0x7fff56ac0fff com.apple.AppleIDAuthSupport (1.0 - 1) <2E9D1398-DBE6-328B-ADDA-20FA5FAD7405> /System/Library/PrivateFrameworks/AppleIDAuthSupport.framework/Versions/A/AppleIDAuthSupport
0x7fff56b01000 - 0x7fff56b4aff3 com.apple.AppleJPEG (1.0 - 1) <4C1F426B-7D77-3980-9633-7DBD8C666B9A> /System/Library/PrivateFrameworks/AppleJPEG.framework/Versions/A/AppleJPEG
0x7fff56d9e000 - 0x7fff56dc0fff com.apple.applesauce (1.0 - ???) <F49107C7-3C51-3024-8EF1-C57643BE4F3B> /System/Library/PrivateFrameworks/AppleSauce.framework/Versions/A/AppleSauce
0x7fff56e84000 - 0x7fff56ed4ff7 com.apple.AppleVAFramework (5.1.4 - 5.1.4) <3399D678-8741-3B70-B8D0-7C63C8ACF7DF> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
0x7fff56f1f000 - 0x7fff56f33ffb com.apple.AssertionServices (1.0 - 1) <456E507A-4561-3628-9FBE-173ACE7429D8> /System/Library/PrivateFrameworks/AssertionServices.framework/Versions/A/AssertionServices
0x7fff57302000 - 0x7fff573eeff7 com.apple.AuthKit (1.0 - 1) <2765ABE9-54F2-3E45-8A93-1261E251B90D> /System/Library/PrivateFrameworks/AuthKit.framework/Versions/A/AuthKit
0x7fff575b0000 - 0x7fff575b8fff com.apple.coreservices.BackgroundTaskManagement (1.0 - 57.1) <2A396FC0-7B79-3088-9A82-FB93C1181A57> /System/Library/PrivateFrameworks/BackgroundTaskManagement.framework/Versions/A/BackgroundTaskManagement
0x7fff575b9000 - 0x7fff5764efff com.apple.backup.framework (1.10.5 - ???) <4EEC51E2-AE4C-340A-B686-901810152C12> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
0x7fff5764f000 - 0x7fff576bcff3 com.apple.BaseBoard (360.28 - 360.28) <68FA8044-F3CD-3BC6-9DAB-27DACF52BFC0> /System/Library/PrivateFrameworks/BaseBoard.framework/Versions/A/BaseBoard
0x7fff59327000 - 0x7fff59330ffb com.apple.CommonAuth (4.0 - 2.0) <93335CB6-ABEB-3EC7-A040-8A667F40D5F3> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
0x7fff597c9000 - 0x7fff59bacfef com.apple.CoreAUC (274.0.0 - 274.0.0) <C71F1581-E73B-3DA0-958B-E912C3FB3F23> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
0x7fff59bad000 - 0x7fff59bdbff7 com.apple.CoreAVCHD (6.0.0 - 6000.4.1) <A04A99B8-DAC5-36FC-BAC7-7431600C1F89> /System/Library/PrivateFrameworks/CoreAVCHD.framework/Versions/A/CoreAVCHD
0x7fff5a009000 - 0x7fff5a01aff7 com.apple.CoreEmoji (1.0 - 69.19.9) <228457B3-E191-356E-9A5B-3C0438D05FBA> /System/Library/PrivateFrameworks/CoreEmoji.framework/Versions/A/CoreEmoji
0x7fff5a5c4000 - 0x7fff5a62aff7 com.apple.CoreNLP (1.0 - 130.15.22) <27877820-17D0-3B02-8557-4014E876CCC7> /System/Library/PrivateFrameworks/CoreNLP.framework/Versions/A/CoreNLP
0x7fff5a791000 - 0x7fff5a795ff7 com.apple.CoreOptimization (1.0 - 1) <1C724E01-E9FA-3AEE-BE4B-C4DB8EC0C812> /System/Library/PrivateFrameworks/CoreOptimization.framework/Versions/A/CoreOptimization
0x7fff5a8d7000 - 0x7fff5a8dfff7 com.apple.CorePhoneNumbers (1.0 - 1) <11F97C7E-C183-305F-8E6C-9B374F50E26B> /System/Library/PrivateFrameworks/CorePhoneNumbers.framework/Versions/A/CorePhoneNumbers
0x7fff5a8e0000 - 0x7fff5a936ff7 com.apple.CorePrediction (1.0 - 1) <A66C8A6F-C3B2-3547-985D-C62C62F9FA48> /System/Library/PrivateFrameworks/CorePrediction.framework/Versions/A/CorePrediction
0x7fff5aa5b000 - 0x7fff5aa8cff3 com.apple.CoreServicesInternal (358 - 358) <DD6EF60D-048F-3186-83DA-EB191EDF48AE> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesInternal
0x7fff5ae53000 - 0x7fff5aed7fff com.apple.CoreSymbolication (10.2 - 64490.25.1) <28B2FF2D-3FDE-3A20-B343-341E5BD4E22F> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolication
0x7fff5af67000 - 0x7fff5b092ff7 com.apple.coreui (2.1 - 499.10) <A80F4B09-F940-346F-A9DF-4EFADD9220A8> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
0x7fff5b093000 - 0x7fff5b233fff com.apple.CoreUtils (5.9 - 590.16) <66CC50F7-766D-33E2-A388-4DE22840ADFB> /System/Library/PrivateFrameworks/CoreUtils.framework/Versions/A/CoreUtils
0x7fff5b287000 - 0x7fff5b2eaff7 com.apple.framework.CoreWiFi (13.0 - 1375.2) <CA4B835A-27AC-3FAB-9F44-E48548EA2442> /System/Library/PrivateFrameworks/CoreWiFi.framework/Versions/A/CoreWiFi
0x7fff5b2eb000 - 0x7fff5b2fcff7 com.apple.CrashReporterSupport (10.13 - 938.26) <E93D84A6-891D-38EE-BB4F-E9CD681189B7> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporterSupport
0x7fff5b38c000 - 0x7fff5b39bfff com.apple.framework.DFRFoundation (1.0 - 211.1) <E3F02F2A-2059-39CC-85DA-969676EB88EB> /System/Library/PrivateFrameworks/DFRFoundation.framework/Versions/A/DFRFoundation
0x7fff5b39c000 - 0x7fff5b3a0ff7 com.apple.DSExternalDisplay (3.1 - 380) <787B9748-B120-3453-B8FE-61D9E363A9E0> /System/Library/PrivateFrameworks/DSExternalDisplay.framework/Versions/A/DSExternalDisplay
0x7fff5b421000 - 0x7fff5b496ffb com.apple.datadetectorscore (7.0 - 590.27) <06FB1A07-7AE6-3ADD-8E7E-41955FAB38E8> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore
0x7fff5b4e2000 - 0x7fff5b51fff7 com.apple.DebugSymbols (190 - 190) <6F4FAACA-E06B-38AD-A0C2-14EA5408A231> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
0x7fff5b520000 - 0x7fff5b65bff7 com.apple.desktopservices (1.13.5 - ???) <265C0E94-B8BF-3F58-8D68-EA001EEA0B15> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x7fff5c5a2000 - 0x7fff5c9bdfff com.apple.vision.FaceCore (3.3.4 - 3.3.4) <A576E2DA-BF6F-3B18-8FEB-324E5C5FA9BD> /System/Library/PrivateFrameworks/FaceCore.framework/Versions/A/FaceCore
0x7fff61912000 - 0x7fff61917fff com.apple.GPUWrangler (3.50.12 - 3.50.12) <6C820ED9-F306-3978-B5B8-432AD97BBDAF> /System/Library/PrivateFrameworks/GPUWrangler.framework/Versions/A/GPUWrangler
0x7fff62723000 - 0x7fff62732fff com.apple.GraphVisualizer (1.0 - 5) <48D020B7-5938-3FAE-B468-E291AEE2C06F> /System/Library/PrivateFrameworks/GraphVisualizer.framework/Versions/A/GraphVisualizer
0x7fff62733000 - 0x7fff62740ff7 com.apple.GraphicsServices (1.0 - 1.0) <56646B62-B331-31DC-80EB-7996DCAB6944> /System/Library/PrivateFrameworks/GraphicsServices.framework/Versions/A/GraphicsServices
0x7fff62898000 - 0x7fff6290cffb com.apple.Heimdal (4.0 - 2.0) <D97FCF19-EAD6-3E2F-BE88-F817E45CAE96> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
0x7fff63c12000 - 0x7fff63c19ffb com.apple.IOAccelerator (404.14 - 404.14) <11A50171-C8AE-3BBC-9FB9-2A3313FFBD31> /System/Library/PrivateFrameworks/IOAccelerator.framework/Versions/A/IOAccelerator
0x7fff63c1d000 - 0x7fff63c35fff com.apple.IOPresentment (1.0 - 42.6) <6DFD9A6E-BF95-3A27-89E7-ACAA9E30D90A> /System/Library/PrivateFrameworks/IOPresentment.framework/Versions/A/IOPresentment
0x7fff63fdd000 - 0x7fff6400aff7 com.apple.IconServices (379 - 379) <7BAD562D-4FA3-3E11-863C-1EEBE2406D2C> /System/Library/PrivateFrameworks/IconServices.framework/Versions/A/IconServices
0x7fff6429d000 - 0x7fff642afff3 com.apple.security.KeychainCircle.KeychainCircle (1.0 - 1) <30CFE05C-4108-3879-AFAA-5BB02CBE190B> /System/Library/PrivateFrameworks/KeychainCircle.framework/Versions/A/KeychainCircle
0x7fff642ca000 - 0x7fff643a5ff7 com.apple.LanguageModeling (1.0 - 159.15.15) <3DE3CE61-542B-37B7-883E-4B9717CAC65F> /System/Library/PrivateFrameworks/LanguageModeling.framework/Versions/A/LanguageModeling
0x7fff643a6000 - 0x7fff643e2ff7 com.apple.Lexicon-framework (1.0 - 33.15.10) <4B5E843E-2809-3E70-9560-9254E2656419> /System/Library/PrivateFrameworks/Lexicon.framework/Versions/A/Lexicon
0x7fff643e9000 - 0x7fff643eefff com.apple.LinguisticData (1.0 - 238.25) <F529B961-098C-3E4C-A3E9-9DA9BFA1B3F0> /System/Library/PrivateFrameworks/LinguisticData.framework/Versions/A/LinguisticData
0x7fff64c0c000 - 0x7fff64c0ffff com.apple.Mangrove (1.0 - 25) <537A5B2E-4C30-3CFD-8BDC-79F9A04AC327> /System/Library/PrivateFrameworks/Mangrove.framework/Versions/A/Mangrove
0x7fff650e3000 - 0x7fff6510bff7 com.apple.spotlight.metadata.utilities (1.0 - 1191.57) <38BB1FB7-3336-384C-B71F-4D0D402EB606> /System/Library/PrivateFrameworks/MetadataUtilities.framework/Versions/A/MetadataUtilities
0x7fff6510c000 - 0x7fff65199ff7 com.apple.gpusw.MetalTools (1.0 - 1) <CBE2176A-8048-3A9C-AFE4-13973D44C704> /System/Library/PrivateFrameworks/MetalTools.framework/Versions/A/MetalTools
0x7fff651b0000 - 0x7fff651c9ffb com.apple.MobileAssets (1.0 - 437.250.3) <8BE5B3A0-8F3A-3FAE-9AFF-32836300183C> /System/Library/PrivateFrameworks/MobileAsset.framework/Versions/A/MobileAsset
0x7fff65344000 - 0x7fff6535fffb com.apple.MobileKeyBag (2.0 - 1.0) <C7C5DD21-66DE-31D1-92D9-BBEEAAE156FB> /System/Library/PrivateFrameworks/MobileKeyBag.framework/Versions/A/MobileKeyBag
0x7fff653e8000 - 0x7fff65412ffb com.apple.MultitouchSupport.framework (2450.1 - 2450.1) <42A23EC9-64A7-31C7-BF33-DF4412ED8A3F> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
0x7fff6564e000 - 0x7fff65658fff com.apple.NetAuth (6.2 - 6.2) <0D01BBE5-0269-310D-B148-D19DAE143DEB> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
0x7fff65eb9000 - 0x7fff65f0aff3 com.apple.OTSVG (1.0 - ???) <5BF1A9EB-2694-3267-9514-A4EB3BEF4081> /System/Library/PrivateFrameworks/OTSVG.framework/Versions/A/OTSVG
0x7fff670a2000 - 0x7fff670b1ff7 com.apple.PerformanceAnalysis (1.218.2 - 218.2) <65F3DB3E-6D4E-33A0-B510-EF768D323DAB> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAnalysis
0x7fff68f43000 - 0x7fff68f61ff7 com.apple.ProtocolBuffer (1 - 263.2) <907D6C95-D050-31DE-99CA-16A5135BC6F9> /System/Library/PrivateFrameworks/ProtocolBuffer.framework/Versions/A/ProtocolBuffer
0x7fff690f9000 - 0x7fff69149fff com.apple.ROCKit (27.6 - 27.6) <756C2253-E8B1-3C48-9945-DE8D6AD24DE2> /System/Library/PrivateFrameworks/ROCKit.framework/Versions/A/ROCKit
0x7fff692a3000 - 0x7fff692c5fff com.apple.RemoteViewServices (2.0 - 128) <8FB0E4EB-DCBB-32E6-94C6-AA9BA9EE4CAC> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServices
0x7fff6a004000 - 0x7fff6a04dfff com.apple.Safari.SafeBrowsing (14607 - 14607.3.9) <F4DA3E55-28AF-3406-8120-9B797197ABED> /System/Library/PrivateFrameworks/SafariSafeBrowsing.framework/Versions/A/SafariSafeBrowsing
0x7fff6aacf000 - 0x7fff6abedfff com.apple.Sharing (1288.62 - 1288.62) <48B1F247-7910-3C16-814C-B99DE231F7F0> /System/Library/PrivateFrameworks/Sharing.framework/Versions/A/Sharing
0x7fff6ba01000 - 0x7fff6bcb0fff com.apple.SkyLight (1.600.0 - 340.54) <90EB1C2E-B264-3EC4-AF7F-CDE7E7585746> /System/Library/PrivateFrameworks/SkyLight.framework/Versions/A/SkyLight
0x7fff6c453000 - 0x7fff6c45ffff com.apple.SpeechRecognitionCore (5.0.21 - 5.0.21) <7A6A67DB-C813-328E-AAFB-D267A5B50B3D> /System/Library/PrivateFrameworks/SpeechRecognitionCore.framework/Versions/A/SpeechRecognitionCore
0x7fff6cafe000 - 0x7fff6cb3aff3 com.apple.StreamingZip (1.0 - 1) <046FAD5C-E0C5-3013-B1FE-24C018A0DDCF> /System/Library/PrivateFrameworks/StreamingZip.framework/Versions/A/StreamingZip
0x7fff6cbb0000 - 0x7fff6cc3bfc7 com.apple.Symbolication (10.2 - 64490.38.1) <9FDCC98D-5B32-35AD-A9BF-94DF2B78507F> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
0x7fff6d123000 - 0x7fff6d12fffb com.apple.TCC (1.0 - 1) <73CF6FA9-44CE-30C9-887F-235940976585> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
0x7fff6d395000 - 0x7fff6d45dff3 com.apple.TextureIO (3.8.4 - 3.8.1) <7CEAC05A-D283-3D5A-B1E3-C849285FA0BF> /System/Library/PrivateFrameworks/TextureIO.framework/Versions/A/TextureIO
0x7fff6d51a000 - 0x7fff6d6d1ffb com.apple.UIFoundation (1.0 - 551.2) <917480B5-14BE-30E0-ABE6-9702336CC35A> /System/Library/PrivateFrameworks/UIFoundation.framework/Versions/A/UIFoundation
0x7fff6d71f000 - 0x7fff6d725ffb com.apple.URLFormatting (59 - 59.46) <8FA3A00C-7BFF-33B9-95EA-A7FC04091D4D> /System/Library/PrivateFrameworks/URLFormatting.framework/Versions/A/URLFormatting
0x7fff6e869000 - 0x7fff6eadbffb libAWDSupportFramework.dylib (2131) <AC78D095-4D47-37DF-AE0D-8EEC7C2553F0> /System/Library/PrivateFrameworks/WirelessDiagnostics.framework/Versions/A/Libraries/libAWDSupportFramework.dylib
0x7fff6eadc000 - 0x7fff6eaedfff libprotobuf-lite.dylib (2131) <297886A7-F889-38AA-B6F6-162598345EC4> /System/Library/PrivateFrameworks/WirelessDiagnostics.framework/Versions/A/Libraries/libprotobuf-lite.dylib
0x7fff6eaee000 - 0x7fff6eb48fff libprotobuf.dylib (2131) <05141A5F-1870-3AA7-B339-6EB13E375BA4> /System/Library/PrivateFrameworks/WirelessDiagnostics.framework/Versions/A/Libraries/libprotobuf.dylib
0x7fff6eb49000 - 0x7fff6eb8aff7 com.apple.awd (1.0 - 930.11) <652A1F08-52A3-36CC-8055-EF57143BED76> /System/Library/PrivateFrameworks/WirelessDiagnostics.framework/Versions/A/WirelessDiagnostics
0x7fff6ebfe000 - 0x7fff6ec01fff com.apple.dt.XCTTargetBootstrap (1.0 - 14490.66) <7AE3457F-AF40-3508-93FB-1D9E31EB1C9D> /System/Library/PrivateFrameworks/XCTTargetBootstrap.framework/Versions/A/XCTTargetBootstrap
0x7fff6f002000 - 0x7fff6f004ffb com.apple.loginsupport (1.0 - 1) <3F8D6334-BCD6-36C1-BA20-CC8503A84375> /System/Library/PrivateFrameworks/login.framework/Versions/A/Frameworks/loginsupport.framework/Versions/A/loginsupport
0x7fff6f23e000 - 0x7fff6f252ffb libAccessibility.dylib (2402.95) <6BC07631-25B1-3C31-A2CB-E5E477836A5E> /usr/lib/libAccessibility.dylib
0x7fff6f2ce000 - 0x7fff6f302fff libCRFSuite.dylib (41.15.4) <406DAC06-0C77-3F90-878B-4D38F11F0256> /usr/lib/libCRFSuite.dylib
0x7fff6f305000 - 0x7fff6f30fff7 libChineseTokenizer.dylib (28.15.3) <9B7F6109-3A5D-3641-9A7E-31D2239D73EE> /usr/lib/libChineseTokenizer.dylib
0x7fff6f39d000 - 0x7fff6f39effb libDiagnosticMessagesClient.dylib (107) <A14D0819-0970-34CD-8680-80E4D7FE8C2C> /usr/lib/libDiagnosticMessagesClient.dylib
0x7fff6f3d5000 - 0x7fff6f62cff3 libFosl_dynamic.dylib (18.3.4) <1B5DD4E2-8AE0-315E-829E-D5BFCD264EA8> /usr/lib/libFosl_dynamic.dylib
0x7fff6f64c000 - 0x7fff6f653fff libMatch.1.dylib (31.200.1) <EF8164CB-B599-39D9-9E73-4958A372DC0B> /usr/lib/libMatch.1.dylib
0x7fff6f67d000 - 0x7fff6f69cfff libMobileGestalt.dylib (645.270.1) <99A06C8A-97D6-383D-862C-F453BABB48A4> /usr/lib/libMobileGestalt.dylib
0x7fff6f69d000 - 0x7fff6f69dfff libOpenScriptingUtil.dylib (179.1) <4D603146-EDA5-3A74-9FF8-4F75D8BB9BC6> /usr/lib/libOpenScriptingUtil.dylib
0x7fff6f7dd000 - 0x7fff6f7deffb libSystem.B.dylib (1252.250.1) <B1006948-7AD0-3CA9-81E0-833F4DD6BFB4> /usr/lib/libSystem.B.dylib
0x7fff6f7df000 - 0x7fff6f859ff7 libTelephonyUtilDynamic.dylib (3705) <155194D3-2B24-3A5F-9C04-364E0D583C60> /usr/lib/libTelephonyUtilDynamic.dylib
0x7fff6f85a000 - 0x7fff6f85bfff libThaiTokenizer.dylib (2.15.1) <ADB37DC3-7D9B-3E73-A72A-BCC3433C937A> /usr/lib/libThaiTokenizer.dylib
0x7fff6f86d000 - 0x7fff6f883ffb libapple_nghttp2.dylib (1.24.1) <6F04250A-6686-3FDC-9A8D-290C64B06502> /usr/lib/libapple_nghttp2.dylib
0x7fff6f884000 - 0x7fff6f8adffb libarchive.2.dylib (54.250.1) <47289946-8504-3966-9127-6CE39993DC2C> /usr/lib/libarchive.2.dylib
0x7fff6f8ae000 - 0x7fff6f92dfff libate.dylib (1.13.8) <92B44EDB-369D-3EE8-AEC5-61F8B9313DBF> /usr/lib/libate.dylib
0x7fff6f931000 - 0x7fff6f931ff3 libauto.dylib (187) <3E3780E1-96F3-3A22-91C5-92F9A5805518> /usr/lib/libauto.dylib
0x7fff6fa01000 - 0x7fff6fa11ffb libbsm.0.dylib (39.200.18) <CF381E0B-025B-364F-A83D-2527E03F1AA3> /usr/lib/libbsm.0.dylib
0x7fff6fa12000 - 0x7fff6fa1ffff libbz2.1.0.dylib (38.200.3) <272953A1-8D36-329B-BDDB-E887B347710F> /usr/lib/libbz2.1.0.dylib
0x7fff6fa20000 - 0x7fff6fa73ff7 libc++.1.dylib (400.9.4) <9A60A190-6C34-339F-BB3D-AACE942009A4> /usr/lib/libc++.1.dylib
0x7fff6fa74000 - 0x7fff6fa89ff7 libc++abi.dylib (400.17) <38C09CED-9090-3719-90F3-04A2749F5428> /usr/lib/libc++abi.dylib
0x7fff6fa8a000 - 0x7fff6fa8aff3 libcharset.1.dylib (51.200.6) <2A27E064-314C-359C-93FC-8A9B06206174> /usr/lib/libcharset.1.dylib
0x7fff6fa8b000 - 0x7fff6fa9bffb libcmph.dylib (6.15.1) <9C52B2FE-179F-32AC-B87E-2AFC49ABF817> /usr/lib/libcmph.dylib
0x7fff6fa9c000 - 0x7fff6fab4ffb libcompression.dylib (52.250.2) <7F4BB18C-1FB4-3825-8D8B-6E6B168774C6> /usr/lib/libcompression.dylib
0x7fff6fd29000 - 0x7fff6fd3ffff libcoretls.dylib (155.220.1) <4C64BE3E-41E3-3020-8BB7-07E90C0C861C> /usr/lib/libcoretls.dylib
0x7fff6fd40000 - 0x7fff6fd41ff3 libcoretls_cfhelpers.dylib (155.220.1) <0959B3E9-6643-3589-8BB3-21D52CDF0EF1> /usr/lib/libcoretls_cfhelpers.dylib
0x7fff701ed000 - 0x7fff70243ff3 libcups.2.dylib (462.12) <095619DC-9233-3937-9E50-5F10D917A40D> /usr/lib/libcups.2.dylib
0x7fff70377000 - 0x7fff70377fff libenergytrace.dylib (17.200.1) <80BB567A-FD18-3497-BF97-353F57D98CDD> /usr/lib/libenergytrace.dylib
0x7fff703a9000 - 0x7fff703aeff7 libgermantok.dylib (17.15.2) <E5F0F794-FF27-3D64-AE52-C78C6A84DD67> /usr/lib/libgermantok.dylib
0x7fff703af000 - 0x7fff703b4ff7 libheimdal-asn1.dylib (520.270.1) <73F60D6F-76F8-35EF-9C86-9A81225EE4BE> /usr/lib/libheimdal-asn1.dylib
0x7fff703df000 - 0x7fff704cffff libiconv.2.dylib (51.200.6) <2047C9B7-3F74-3A95-810D-2ED8F0475A99> /usr/lib/libiconv.2.dylib
0x7fff704d0000 - 0x7fff70731ffb libicucore.A.dylib (62141.0.1) <A0D63918-76E9-3C1B-B255-46F4C1DA7FE8> /usr/lib/libicucore.A.dylib
0x7fff7077e000 - 0x7fff7077ffff liblangid.dylib (128.15.1) <22D05C4F-769B-3075-ABCF-44A0EBACE028> /usr/lib/liblangid.dylib
0x7fff70780000 - 0x7fff70798ff3 liblzma.5.dylib (10.200.3) <E1F4FD60-1CE4-37B9-AD95-29D348AF1AC0> /usr/lib/liblzma.5.dylib
0x7fff707b0000 - 0x7fff70854ff7 libmecab.1.0.0.dylib (779.24.1) <A8D0379B-85FA-3B3D-89ED-5CF2C3826AB2> /usr/lib/libmecab.1.0.0.dylib
0x7fff70855000 - 0x7fff70a59fff libmecabra.dylib (779.24.1) <D71F71E0-30E2-3DB3-B636-7DE13D51FB4B> /usr/lib/libmecabra.dylib
0x7fff70c31000 - 0x7fff70f82ff7 libnetwork.dylib (1229.250.15) <72C7E9E3-B2BE-3300-BE1B-64606222022C> /usr/lib/libnetwork.dylib
0x7fff71014000 - 0x7fff71799fdf libobjc.A.dylib (756.2) <7C312627-43CB-3234-9324-4DEA92D59F50> /usr/lib/libobjc.A.dylib
0x7fff717ab000 - 0x7fff717afffb libpam.2.dylib (22.200.1) <586CF87F-349C-393D-AEEB-FB75F94A5EB7> /usr/lib/libpam.2.dylib
0x7fff717b2000 - 0x7fff717e7fff libpcap.A.dylib (79.250.1) <C0893641-7DFF-3A33-BDAE-190FF54837E8> /usr/lib/libpcap.A.dylib
0x7fff71900000 - 0x7fff71918ffb libresolv.9.dylib (65.200.2) <893142A5-F153-3437-A22D-407EE542B5C5> /usr/lib/libresolv.9.dylib
0x7fff7191a000 - 0x7fff71955ff3 libsandbox.1.dylib (851.270.1) <04B924EF-2385-34DF-807E-93AAD9EF3AAB> /usr/lib/libsandbox.1.dylib
0x7fff71969000 - 0x7fff7196aff7 libspindump.dylib (267.3) <A584E403-8C95-3841-9C16-E22664A5A63F> /usr/lib/libspindump.dylib
0x7fff7196b000 - 0x7fff71b48fff libsqlite3.dylib (274.26) <6404BA3B-BCA4-301F-B2FE-8776105A2AA3> /usr/lib/libsqlite3.dylib
0x7fff71d61000 - 0x7fff71d64ff7 libutil.dylib (51.200.4) <CE9B18C9-66ED-32D4-9D29-01F8FCB467B0> /usr/lib/libutil.dylib
0x7fff71d65000 - 0x7fff71d72fff libxar.1.dylib (417.1) <39CCF46B-C81A-34B1-92A1-58C4E5DA846E> /usr/lib/libxar.1.dylib
0x7fff71d77000 - 0x7fff71e59ff3 libxml2.2.dylib (32.10) <AA4E1B1F-0FDE-3274-9FA5-75446298D1AC> /usr/lib/libxml2.2.dylib
0x7fff71e5a000 - 0x7fff71e82ff3 libxslt.1.dylib (16.5) <E330D3A2-E32B-378A-973E-A8D245C0F712> /usr/lib/libxslt.1.dylib
0x7fff71e83000 - 0x7fff71e95ff7 libz.1.dylib (70.200.4) <B048FC1F-058F-3A08-A1FE-81D5308CB3E6> /usr/lib/libz.1.dylib
0x7fff72679000 - 0x7fff7267dff3 libcache.dylib (81) <1987D1E1-DB11-3291-B12A-EBD55848E02D> /usr/lib/system/libcache.dylib
0x7fff7267e000 - 0x7fff72688ff3 libcommonCrypto.dylib (60118.250.2) <1765BB6E-6784-3653-B16B-CB839721DC9A> /usr/lib/system/libcommonCrypto.dylib
0x7fff72689000 - 0x7fff72690ff7 libcompiler_rt.dylib (63.4) <5212BA7B-B7EA-37B4-AF6E-AC4F507EDFB8> /usr/lib/system/libcompiler_rt.dylib
0x7fff72691000 - 0x7fff7269aff7 libcopyfile.dylib (146.250.1) <98CD00CD-9B91-3B5C-A9DB-842638050FA8> /usr/lib/system/libcopyfile.dylib
0x7fff7269b000 - 0x7fff7271ffc3 libcorecrypto.dylib (602.260.2) <01464D24-570C-3B83-9D18-467769E0FCDD> /usr/lib/system/libcorecrypto.dylib
0x7fff727a6000 - 0x7fff727dfff7 libdispatch.dylib (1008.270.1) <97273678-E94C-3C8C-89F6-2E2020F4B43B> /usr/lib/system/libdispatch.dylib
0x7fff727e0000 - 0x7fff7280cff7 libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib
0x7fff7280d000 - 0x7fff7280dffb libkeymgr.dylib (30) <0D0F9CA2-8D5A-3273-8723-59987B5827F2> /usr/lib/system/libkeymgr.dylib
0x7fff7280e000 - 0x7fff7281aff3 libkxld.dylib (4903.271.2) <FBF128C8-D3F0-36B6-983A-A63B8A3E0E52> /usr/lib/system/libkxld.dylib
0x7fff7281b000 - 0x7fff7281bff7 liblaunch.dylib (1336.261.2) <2B07E27E-D404-3E98-9D28-BCA641E5C479> /usr/lib/system/liblaunch.dylib
0x7fff7281c000 - 0x7fff72821fff libmacho.dylib (927.0.3) <A377D608-77AB-3F6E-90F0-B4F251A5C12F> /usr/lib/system/libmacho.dylib
0x7fff72822000 - 0x7fff72824ffb libquarantine.dylib (86.220.1) <6D0BC770-7348-3608-9254-F7FFBD347634> /usr/lib/system/libquarantine.dylib
0x7fff72825000 - 0x7fff72826ff7 libremovefile.dylib (45.200.2) <9FBEB2FF-EEBE-31BC-BCFC-C71F8D0E99B6> /usr/lib/system/libremovefile.dylib
0x7fff72827000 - 0x7fff7283eff3 libsystem_asl.dylib (356.200.4) <A62A7249-38B8-33FA-9875-F1852590796C> /usr/lib/system/libsystem_asl.dylib
0x7fff7283f000 - 0x7fff7283fff7 libsystem_blocks.dylib (73) <A453E8EE-860D-3CED-B5DC-BE54E9DB4348> /usr/lib/system/libsystem_blocks.dylib
0x7fff72840000 - 0x7fff728c7fff libsystem_c.dylib (1272.250.1) <7EDACF78-2FA3-35B8-B051-D70475A35117> /usr/lib/system/libsystem_c.dylib
0x7fff728c8000 - 0x7fff728cbffb libsystem_configuration.dylib (963.270.3) <2B4A836D-68A4-33E6-8D48-CD4486B03387> /usr/lib/system/libsystem_configuration.dylib
0x7fff728cc000 - 0x7fff728cfff7 libsystem_coreservices.dylib (66) <719F75A4-74C5-3BA6-A09E-0C5A3E5889D7> /usr/lib/system/libsystem_coreservices.dylib
0x7fff728d0000 - 0x7fff728d6fff libsystem_darwin.dylib (1272.250.1) <EC9B39A5-9592-3577-8997-7DC721D20D8C> /usr/lib/system/libsystem_darwin.dylib
0x7fff728d7000 - 0x7fff728ddff7 libsystem_dnssd.dylib (878.270.2) <E9A5ACCF-E35F-3909-AF0A-2A37CD217276> /usr/lib/system/libsystem_dnssd.dylib
0x7fff728de000 - 0x7fff72929ffb libsystem_info.dylib (517.200.9) <D09D5AE0-2FDC-3A6D-93EC-729F931B1457> /usr/lib/system/libsystem_info.dylib
0x7fff7292a000 - 0x7fff72952ff7 libsystem_kernel.dylib (4903.271.2) <EA204E3C-870B-30DD-B4AF-D1BB66420D14> /usr/lib/system/libsystem_kernel.dylib
0x7fff72953000 - 0x7fff7299eff7 libsystem_m.dylib (3158.200.7) <F19B6DB7-014F-3820-831F-389CCDA06EF6> /usr/lib/system/libsystem_m.dylib
0x7fff7299f000 - 0x7fff729c9fff libsystem_malloc.dylib (166.270.1) <011F3AD0-8E6A-3A89-AE64-6E5F6840F30A> /usr/lib/system/libsystem_malloc.dylib
0x7fff729ca000 - 0x7fff729d4ff7 libsystem_networkextension.dylib (767.250.2) <FF06F13A-AEFE-3A27-A073-910EF78AEA36> /usr/lib/system/libsystem_networkextension.dylib
0x7fff729d5000 - 0x7fff729dcfff libsystem_notify.dylib (172.200.21) <145B5CFC-CF73-33CE-BD3D-E8DDE268FFDE> /usr/lib/system/libsystem_notify.dylib
0x7fff729dd000 - 0x7fff729e6fef libsystem_platform.dylib (177.270.1) <9D1FE5E4-EB7D-3B3F-A8D1-A96D9CF1348C> /usr/lib/system/libsystem_platform.dylib
0x7fff729e7000 - 0x7fff729f1ff7 libsystem_pthread.dylib (330.250.2) <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7> /usr/lib/system/libsystem_pthread.dylib
0x7fff729f2000 - 0x7fff729f5ff7 libsystem_sandbox.dylib (851.270.1) <9494594B-5199-3186-82AB-5FF8BED6EE16> /usr/lib/system/libsystem_sandbox.dylib
0x7fff729f6000 - 0x7fff729f8ff3 libsystem_secinit.dylib (30.260.2) <EF1EA47B-7B22-35E8-BD9B-F7003DCB96AE> /usr/lib/system/libsystem_secinit.dylib
0x7fff729f9000 - 0x7fff72a00ff3 libsystem_symptoms.dylib (820.267.1) <03F1C2DD-0F5A-3D9D-88F6-B26C0F94EB52> /usr/lib/system/libsystem_symptoms.dylib
0x7fff72a01000 - 0x7fff72a16fff libsystem_trace.dylib (906.260.1) <FC761C3B-5434-3A52-912D-F1B15FAA8EB2> /usr/lib/system/libsystem_trace.dylib
0x7fff72a18000 - 0x7fff72a1dffb libunwind.dylib (35.4) <24A97A67-F017-3CFC-B0D0-6BD0224B1336> /usr/lib/system/libunwind.dylib
0x7fff72a1e000 - 0x7fff72a4dfff libxpc.dylib (1336.261.2) <7DEE2300-6D8E-3C00-9C63-E3E80D56B0C4> /usr/lib/system/libxpc.dylib
External Modification Summary:
Calls made by other processes targeting this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by all processes on this machine:
task_for_pid: 133
thread_create: 0
thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=450.5M resident=0K(0%) swapped_out_or_unallocated=450.5M(100%)
Writable regions: Total=68.1M written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=68.1M(100%)
VIRTUAL REGION
REGION TYPE SIZE COUNT (non-coalesced)
Activity Tracing 256K 1
CoreServices 180K 1
CoreUI image file 560K 4
Dispatch continuations 8192K 1
Foundation 4K 1
Kernel Alloc Once 8K 1
MALLOC 47.7M 24
MALLOC guard page 32K 8
Mach message 8K 1
STACK GUARD 56.0M 7
Stack 11.0M 7
VM_ALLOCATE 64K 5
__DATA 29.7M 282
__FONT_DATA 4K 1
__LINKEDIT 223.4M 18
__TEXT 227.1M 280
__UNICODE 564K 1
mapped file 53.2M 15
shared memory 632K 8
TOTAL 658.5M 666
