Dlight 4.0.0 b65 shutting down when trying to load
10 years 6 months ago #12458 by tarabini
I'm having a problem with the b65 version. Every time I try to load an old show, the show loads but then DLight shuts down. In b64 I can open any show without problems (went back to the b64 after several shut downs in b65).
10 years 6 months ago #12462 by sl1200mk2
Hi,
can you please post a faulty .sho?
thanx,
10 years 6 months ago #12475 by tarabini
Here are two different shows that makes it shut down, but it happens for me with any show programmed in an older version of Dlight........
File Attachment:
File Name: Shlomi.sho
File Size:29.14 KB
File Attachment:
File Name: KeretHanut.sho
File Size:18.33 KB
10 years 6 months ago #12476 by tarabini
Tried on 2 different machines. Both shuts down when trying to open them in b65 but can run them in b64
10 years 6 months ago #12477 by sl1200mk2
ok, will be fixed for the next beta...
thanx,
The following user(s) said Thank You: tarabini
10 years 6 months ago #12479 by guilmay
j'ai également le même problème plantage au chargement d'un show édité sous une ancienne version de D light. (quand j'étais encore sous snow leopard) ...
Passé maintenant sous El capitan, et donc avec Dlight B65... je n'arrive pas à loader le show...
ci joint le .show défaillant...
dois je repasser sous une version antérieure de Dlight qui tourne sous EL capitan ??
la b64 ??
Sylvain
10 years 6 months ago #12480 by tarabini
@ Sylvain.
If you downgrade to b64, you should be able to open your old files again.....
10 years 6 months ago #12481 by sl1200mk2
it's fixed for the next beta... stupid stuff...
10 years 6 months ago #12482 by guilmay
where can I find it ?
I've not seen it on the download section ..
10 years 6 months ago #12483 by sl1200mk2
there's a b66 preview for X10_X11 in the download section because I'm working on other stuff with someone...
If you're lucky with the OS, you can try it cause there's the fix inside
10 years 6 months ago #12484 by sl1200mk2
by the way be carefull, it's a preview, not the public beta...
10 years 6 months ago #12486 by guilmay
merci !
j'ai réussi à créer un nouveau projet .show avec la beta65... en important un ascii antérieur...
ça à l'air de tourner...
merci pour la beta 66.. ça me fait un plan de secours..
10 years 6 months ago #12487 by sl1200mk2
encore un fois ne l'utilise pas en spectacle, c'est une preview pour un truc particulier à tester....
depuis j'ai corrigé d'autre essais et cette preview est inutilisable en spectacle....
la b66 final peut-etre vendredi
Time to create page: 0.183 seconds
