Faire un chase avec une device
10 years 6 months ago #12366 by sl1200mk2
Replied by sl1200mk2 on topic Faire un chase avec une device
first I need to upgrade to 10.11.4 the virtualMachine and will send you the alpha.
10 years 6 months ago #12367 by nomatter
Replied by nomatter on topic Faire un chase avec une device
Ok, I thinks there are only minor changes since 10.11.3.
But I can wait, thanks.
10 years 6 months ago #12368 by sl1200mk2
@Carlo,
so you can grab it from Download/beta
tagged as b65
10 years 6 months ago - 10 years 6 months ago #12379 by nomatter
Well, I tested it.
At beginning it worked pretty fine.
It reads previous position and then continues movement.
When SPEED goes to 0 movement stopped, and that's Ok.
But, raising againg the speed up the position go to 0-0 and stuck there.
I had to Stop the chase to reset it.
After that, even closing and reopening the program, chase starts again and always from 0-0 ignoring last position.
I tried also to create another chase but no success.
Who knows?
EDIT: problems happen only working with palettes. Otherwise it works fine.
Last edit: 10 years 6 months ago by nomatter.
10 years 6 months ago #12380 by sl1200mk2
@Carlo,
I've tried with Chase1(sub10) and Speed (sub9)
setting speed to 0 stop the chase _ fine
setting the speed to another level after the 0 goes fine too
and chase1 is made with palette...
can you point me to another example where you've noticed that?
10 years 6 months ago #12381 by sl1200mk2
@got
tout dépend du temps que t'as mais j'ai réussi à sampler du focus d'un device.
c'est le tout début, ça sera surement long, mais it's a start ;-)
10 years 6 months ago #12382 by nomatter
The chase starting bad behavior depends on palette as last recorded position, the last Dlink, as in my show at step 3.
If I remove palette from Dlink, changing values, it starts good.
Speed issues depends on "Submasters rolling style" on Sub10: if No Rolling it stucks to 0. If "All parameters" (as it should be, I think, it works fine). What is "no Rolling" for?
I hope this helps.
10 years 6 months ago #12383 by sl1200mk2
ok, I saw...
thanx
10 years 6 months ago #12384 by got
Replied by got on topic Faire un chase avec une device
@nico
cool çà avance çà avance.
pour l'instant j'arrive à faire mon chase tout nickel.
je le met dans un sub.
je met un Master link sur mon cue pour lancer l'effet en même temps que mon go
et la petit soucis ,l'auto fait une "pirouette" de rotation avant d'arriver au départ du chase.
j'ai l'impression aussi de pas avoir de Mouve in black sur le cue d'avant. car je voit pas l'auto se préparer, avant qu'il lance le chase.
j'essaye aussi du coup de rajouter un device link sur un cue qui existe déjà, mais sans grand succès.
il faut que je réessaye demain.
10 years 6 months ago #12385 by sl1200mk2
@got
c'est pas que la position initiale est différente de 180° par rapport aux positions enregistrées dans ton chase?
le MIB ne fonctionne que pour les DLinks, pas pour les MLinks
10 years 6 months ago #12386 by sl1200mk2
@Carlo,
I think I got it...
will tell you if I get a chance to update the b65_X10_X11
10 years 6 months ago #12387 by sl1200mk2
@Carlo
for effects or gobo....
if you record an effect palette with let's say the third gobo, when you load the palette in a sub and launch the sub, you don't to see the first gobo, the second one and finally the third...
thus, 'No Rolling' will directly lead to the third one
10 years 6 months ago #12388 by sl1200mk2
@Got
au cas où tu serais interressé par l'enregistrement de sample de Device, dis moi l'OS de ta machine et j'essaierai de te produire aussi une version.
c'est encore imparfait dans le sens où ça enregistre tous les devices et uniquement les variations issues de sub ou du 'device command' (ça sample pas la séquence par exemple), mais ça commence à etre cool et les samples s'enregistrent bien avec le sho....
ya pas d'édition fine du sample non plus, tu ne peux pas visualiser les niveaux des offsets des devices à une frame précise dans le sample editor.
ça s'est du bon beta testing B)
10 years 6 months ago #12389 by got
@ nico
pour la pirouette je pense aussi que c'est çà j'ai du faire un tour de trop...
je me plantai car dans les palettes j'étais en pourcent et sur l'edition des offset ou palette c'est en réel ...
et pour le Dlink c'est exactement ce que je me suis dis aussi.
du coup petite mémoire avec un Dlink sur première position du chase ;)
10 years 6 months ago #12396 by sl1200mk2
can I please have your thoughts about that:
getdlight.com/index.php/forum/free-talk/5844-autom4tic#12395
Time to create page: 0.203 seconds
