Reset a Show: Freeze and Blackout button
- nomatter
11 years 9 months ago #9175
by nomatter
Reset a Show: Freeze and Blackout button was created by nomatter
Hi Nico,
I'm working to create a reset sequence in Qlab (via OSC) in order to be ready to start the show properly.
So, at the moment: Goto 0, Kill Sub (or any value), Grandmaster, Masters of Sub, Scene and Flash to FF and Freeze and Blackout OFF.
To make masters work I had to send 0 then 255 (e.g. "/grandmaster 0" and then "/grandmaster 255"). And that's ok.
My problem is with Freeze and Blackout functions. They only toggle and I couldn't find how to set to 0 for sure.
Is there something I'm missing or there is not a way to set them off?
Thanks,
Carlo.
Thanks,
Carlo.
11 years 9 months ago #9186
Replied by sl1200mk2 on topic Reset a Show: Freeze and Blackout button
Hi Carlo,
I'll check that...
I'll check that...
11 years 9 months ago #9192
so in order to not mess everything, I've added two methods:
/force/blackout 0/1
/force/freeze 0/1
toggle /pad/blackout and /pad/freeze still behave as expected and with this two new methods, you can do want you want (I guess)
please update the wiki according to this change
thanx
/force/blackout 0/1
/force/freeze 0/1
thanx
- nomatter
11 years 9 months ago #9195
by nomatter
Replied by nomatter on topic Reset a Show: Freeze and Blackout button
Hallo Nico,
thanks for your work.
Anyway I'm sorry but with b17 it doesn't work. I've tried some text variation but it doesn't react at all.
I've tried also from outside Qlab but it still doesn't answer.
11 years 9 months ago #9196
I've work on that after the b17...
you'll have to wait for the b18 (witch can land rather soon as I don't have any job for 2 weeks...)
- nomatter
11 years 9 months ago #9197
by nomatter
Good. (for the b17 and corrections not the lack of job).
Did you understand why the midi controller connected after program launch still doesn't work? It's very strange: values go up but not down and I'm forced to restart Dligth. And it happen only with subs; channels and masters work.
Cheers,
Carlo.
Cheers,
Carlo.
11 years 9 months ago #9222
Carlo,
changes are available with b18
- nomatter
11 years 9 months ago #9233
by nomatter
Great,
new Osc commands work.
Wiki page updated. New complete table for 4.0.0_b18: www.nicole-banana.com/wiki/index.php?title=OSC
And Midi Controlled Subs now work too, even after an hot plug.
Very good.
Thanks,
Carlo.
Very good.
Thanks,
Carlo.
11 years 9 months ago #9235
hey!
thanx for the wiki update!
Time to create page: 0.157 seconds
