[résolu] Installation dans Tango Studio
12 years 1 week ago - 12 years 5 days ago #8682 by Machin
J'utilise Tango Studio et je voudrais installer DLight...
Après avoir suivi le tuto qui est ici: www.nicole-banana.com/wiki/index.php?tit...stallation_sur_Linux
Je n'arrive pas à lancer le logiciel.
Avec le lanceur, cela me renvoie:
L'exécution du processus fils « /home/xxx/Bureau/Dlight/DLight-64-Linux/DLight.sh » a échoué (Permission non accordée)
Quand je lance Dlight.sh dans un terminal, cela me retourne:
:~$ sh /home/petit/Bureau/Dlight/DLight-64-Linux/DLight.sh
/home/petit/Bureau/Dlight/DLight-64-Linux/bin/DLight: /lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.15' not found (required by /home/petit/Bureau/Dlight/DLight-64-Linux/bin/DLight)
/home/petit/Bureau/Dlight/DLight-64-Linux/bin/DLight: /lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.14' not found (required by /home/petit/Bureau/Dlight/DLight-64-Linux/bin/DLight)
/home/petit/Bureau/Dlight/DLight-64-Linux/bin/DLight: /lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.14' not found (required by /home/petit/Bureau/Dlight/DLight-64-Linux/bin/libola.so.1)
/home/petit/Bureau/Dlight/DLight-64-Linux/bin/DLight: /lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.15' not found (required by /home/petit/Bureau/Dlight/DLight-64-Linux/bin/libolacommon.so.0)
/home/petit/Bureau/Dlight/DLight-64-Linux/bin/DLight: /lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.14' not found (required by /home/petit/Bureau/Dlight/DLight-64-Linux/bin/libolacommon.so.0)
/home/petit/Bureau/Dlight/DLight-64-Linux/bin/DLight: /lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.14' not found (required by /home/petit/Bureau/Dlight/DLight-64-Linux/bin/libtcl8.5.so)
/home/petit/Bureau/Dlight/DLight-64-Linux/bin/DLight: /lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.15' not found (required by /home/petit/Bureau/Dlight/DLight-64-Linux/bin/libtcl8.5.so)
/home/petit/Bureau/Dlight/DLight-64-Linux/bin/DLight: /lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.14' not found (required by /home/petit/Bureau/Dlight/DLight-64-Linux/bin/libtk8.5.so)
/home/petit/Bureau/Dlight/DLight-64-Linux/bin/DLight: /lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.14' not found (required by /home/petit/Bureau/Dlight/DLight-64-Linux/bin/libxml2.so.2)
/home/petit/Bureau/Dlight/DLight-64-Linux/bin/DLight: /lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.15' not found (required by /home/petit/Bureau/Dlight/DLight-64-Linux/bin/libxml2.so.2)
/home/petit/Bureau/Dlight/DLight-64-Linux/bin/DLight: /lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.14' not found (required by /home/petit/Bureau/Dlight/DLight-64-Linux/bin/libnettle.so.5)
/home/petit/Bureau/Dlight/DLight-64-Linux/bin/DLight: /lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.14' not found (required by /home/petit/Bureau/Dlight/DLight-64-Linux/bin/libartnet.so.1)
/home/petit/Bureau/Dlight/DLight-64-Linux/bin/DLight: /lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.15' not found (required by /home/petit/Bureau/Dlight/DLight-64-Linux/bin/libartnet.so.1)
/home/petit/Bureau/Dlight/DLight-64-Linux/bin/DLight: /lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.14' not found (required by /home/petit/Bureau/Dlight/DLight-64-Linux/bin/liblo.so.7)
/home/petit/Bureau/Dlight/DLight-64-Linux/bin/DLight: /lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.14' not found (required by /home/petit/Bureau/Dlight/DLight-64-Linux/bin/libhpdf-2.4.0dev.so)
/home/petit/Bureau/Dlight/DLight-64-Linux/bin/DLight: /lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.14' not found (required by /home/petit/Bureau/Dlight/DLight-64-Linux/bin/libusb-1.0.so.0)
/home/petit/Bureau/Dlight/DLight-64-Linux/bin/DLight: /lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.14' not found (required by /home/petit/Bureau/Dlight/DLight-64-Linux/bin/libprotobuf.so.7)
/home/petit/Bureau/Dlight/DLight-64-Linux/bin/DLight: /lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.14' not found (required by /home/petit/Bureau/Dlight/DLight-64-Linux/bin/libpng16.so.16)
Je comprends qu'il me manque quelque chose concernant Glib 2.14 et 2.15, mais je ne mes trouve pas dans synaptic.
Si quelqu'un saurait m'aider, merci d'avance...!
Last edit: 12 years 5 days ago by Machin.
12 years 1 week ago #8683 by aroom
Replied by aroom on topic Installation dans Tango Studio
salut
est-ce que ça ne serait pas juste une histoire de permission ?
il faut que tu rendes le fichier DLight.sh exécutable. tu peux le faire avec un clic-droit dessus, tu cherches un peu il doit avoir un case à cocher "rendre se fichier exécutable" ou alors dans le terminal :
chmod +x /home/petit/Bureau/Dlight/DLight-64-Linux/DLight.sh
12 years 1 week ago #8684 by Machin
Replied by Machin on topic Installation dans Tango Studio
Alors, j'ai essayé les deux suite à ton post. Le seul changement est que cela ne me retourne plus de message d'erreur.
Mais rien n'a l'air de se lancer...
12 years 1 week ago #8685 by Machin
Replied by Machin on topic [résolu] Installation dans Tango Studio
Je m'auto répend:
J'ai utilisé Wine pour installer le .exe du coup.
Et ça se lance!
Ne me reste plus qu'a appréhender DLight maintenant!
Merci à vous!
Cyril.
12 years 1 week ago - 12 years 1 week ago #8686 by aroom
Replied by aroom on topic [résolu] Installation dans Tango Studio
je pense quand même que tu devrais utiliser la version pour linux.
linux et dlight c'est très stable.
si tu lances DLight.sh via le terminal, tu n'a aucun messages ?
as-tu essayé avec la version 32 bits ?
edit :
check ce post :
www.nicole-banana.com/index.php/forum/1-...-debian-6-0-6-64bits
Last edit: 12 years 1 week ago by aroom.
12 years 1 week ago - 12 years 1 week ago #8688 by Machin
Re,
Encore faut-il pouvoir l'installer... Rhoo...je rigole! ;)
Pour le lancement via un terminal cela me retourne la même chose que dans mon premier post.
Si j'ai bien compris le lien que tu m'as donné, il faudrait que je recompile les sources de Glibc...
Et sinon, je n'ai pas essayé la version 32 bits. Je vais commencer par ça dans mes tests.
Merci à toi pour ton oeil extérieur!
Last edit: 12 years 1 week ago by Machin.
12 years 1 week ago - 12 years 5 days ago #8705 by Machin
Alors pour la version 32 bits et après avoir rendu le .sh executable:
* via le menu, cela ne donne rien
* via un terminal, cela retourne cela:
petit@petit:~$ sh /home/petit/Bureau/Dlight/DLight-32-Linux/DLight.sh
/home/petit/Bureau/Dlight/DLight-32-Linux/bin/DLight: error while loading shared libraries: libusb-1.0.so.0: cannot open shared object file: No such file or directory
Edit: j'ai récupéré les sources de Glibc 2.15...je ne comprend pas/ ne sais pas/ comment les compiler.
J'ai ouvert le fichier install pour suivre les instructions, mais je ne comprend pas. Mon niveau en américain est moyen...
Si quelqu'un peut me faire la traduction, merci d'avance!
12 years 1 week ago #8709 by aroom
essai d'installer la libusb
www.libusb.org
12 years 1 week ago #8715 by sl1200mk2
Replied by sl1200mk2 on topic Installation dans Tango Studio
sans se précipiter et essayer d'essayer la 32 bits sur un système 64 bits...
si ton OS est en 64 bits, c'est la version idoine de DL qu'il faut que tu utilises.
regarde cette page:
stackoverflow.com/questions/10863613/how...13-to-2-15-on-debian
et essaye d'installer la glibc 2.15
étant donné le faible nombre d'utilisateur de DL sur Linux c'est beaucoup de boulot pour moi de compiler DL pour chaque distro.... du coup je me suis dis que j'allais le produire sur la plus répandue _ ubuntu, qui même si elle est basée sur un debian est maintenant différente en plusieurs points...
12 years 5 days ago - 12 years 5 days ago #8757 by Machin
Yep!
Et bien après quelques bidouilles, cela fonctionne grâce au lien que tu as fourni!
Pour les bidouilles, voici comment je me suis arrangé avec le tuto:
* je ne suis pas passé par le tty 1 comme indiqué, j'ai juste ouvert un terminal sous Gnome. Ça permet d'avoir accès au tuto en ligne sans avoir à passer son temps à basculer entre les différentes fenêtres.
* les modifications ont été faites avec "su" et non "sudo", pour une histoire de droits (oui, j'ai un peu bourriné...)
* j'ai ajouté les 2 dépôts indiqués et fait tout bien comme il faut.
Maintenant je peux lancer DLight depuis le menu de Debian...en version 64bits.
Encore merci!
Pas besoin de te flageller sur le pourquoi tu ne l'as sorti que pour Ubuntu. Je comprends tout à fait!
En tout cas tu es présent et tu assures! Alors un grand merci pour tout ce boulot!!!!
Edit:
Après quelques essais comme la création d'un FX, son assignation à un sub est enfin la création d'un link entre ce sub et un step, je peux faire ces retours:
* impossible de rentrer des valeurs, de modifier les temps dans le fx, etc. C'est un peu comme si le clavier n'était pas pris en compte. Mais j'ai pu modifer le nom du sub sans problème.
* j'ai créé tout ça dans la version windows, ait enregistré le .sho. Il est bien ouvert par la version Linux de Dlight et corectement lu. Le fx est envoyé correctement...
Vala vala...
Time to create page: 0.217 seconds
