Right way to use groups ?
12 years 1 month ago #8557 by jeanbelin
Right way to use groups ? was created by jeanbelin
Hi, when I create a group what is the expected behavior for each dmx channel value ?
I mean, if I set all the values to '1', then use the group in a cue and put the channels values to FF in the cue, what will be the fina l values ? Is FF = 100% of 1 ?
And as a side question : is there a way to select multiples channels in the sequence or in a cue (make them yellow), without using groups ?
Thanks
12 years 1 month ago - 12 years 1 month ago #8561 by aroom
Replied by aroom on topic Right way to use groups ?
I doubt that. But I don't understand the way you want to use groups. If you put a group in a sub master with 1 value for all channels, then yes, when you'll recall the submaster at FF , the channels level will be 1
You can select multiple channels by typing regulars @mode commands like Channel 1 Thru 5 then Enter(C1>5Enter), or Channel 1 + 2 then Enter(C1+2Enter), or ALL > Enter(AEnter)
ALL will select all actives channels. Check the menu Display > Shortcuts
Then you can change the level with both left and right arrow key.
Last edit: 12 years 1 month ago by aroom.
12 years 1 month ago #8562 by jeanbelin
Replied by jeanbelin on topic Right way to use groups ?
I don't understand what a submaster is... And where to create them (don't have a menu for that)
What I've done with groups was :
- creating a group (eg. 8 scene backlights)
- creating a cue, and when editing the cue, load the group to avoid rolling all the 8 values with the mouse
I'm just trying to find a simple solution to change all the backlights quickly without having to select (with the mouse, or with expressions as in your example (didn't know it was possible this way))
To be more precise :
I need to adapt the show (a theater show) depending of the light gears available in the place we play. We can have 5/6 lights in very small venues to 20 in bigger and better equipped places.
- I thought I could have my main sequence remaining the same (30/40 differents step, corresponding to the 30/40 differents light states, and only 10 cues)
- Then only modify the cues to adapt them to the gears available in the place we play
- So, for bigger venues, I wanted a solution to edit the cues without having to adjust each channel individually and I thought that groups were the solution (and it works, because I can load them in cue editing and edit the cue faster)
But I don't know if it's the simplest way to fulfill my needs
12 years 1 month ago #8565 by aroom
man, you're so close to reach your goal, in my opinion.
Time to create page: 0.120 seconds
