Shortcuts
12 years 10 months ago #7438 by snarf36
Shortcuts was created by snarf36
Hi Nico,
I am using a numeric keypad for quick input for channels and patching with my laptop.
My old numpad broke down and now with a new one or a external mac keyboard the enter command does not work anymore.
Is it possible to add ENTER in the shortcut list? or add KP_Enter as an action input?
Maybe KP_1 for 1 and vice versa?
12 years 10 months ago #7439 by sl1200mk2
Replied by sl1200mk2 on topic Shortcuts
Hi,
This is exactly the purpose of the double columns in the shortcuts window.
Open the shortcuts window, put the cursor on the validate command in the second column, hit the enter key on your keypad, you should see KP_Enter, then validate with ENTER on your computer keyboard.
Doing this you should be able to use your external keypad.
Do the same for numbers or whatever....
12 years 10 months ago #7440 by snarf36
Replied by snarf36 on topic Shortcuts
Yes I know how that works,I use it all the time, but the reason I write this is that ENTER is not in the shortcut window
12 years 10 months ago #7441 by sl1200mk2
Does a validate command exists?
If you create a new sho, does the ENTER shortcuts appears for any command?
12 years 10 months ago #7444 by snarf36
I should say a validate command like Enter should exist because it can be written in macro's.
And no, Enter shortcut does not appear in the shortcut window in a new show.
It never did but I used a numeric key pad before that had the enter as a genuine enter command.
The one I now use outputs KP_ENTER.
12 years 10 months ago #7446 by sl1200mk2
k, I'll double the ENTER command with KP_Enter in the next release.
Thanx for noticing that.
Can you please post in the 3.0.20 release thread for me not to forgot.
12 years 9 months ago #7541 by sl1200mk2
Hi,
I've published a second beta before the next release.
in this one you can use any key to map to Enter function.
can you please test and report?
12 years 9 months ago #7543 by snarf36
Works!
Thanks Nico.
12 years 9 months ago #7544 by sl1200mk2
thanx,
enjoy!!
Time to create page: 0.151 seconds
