Crash on OSX
13 years 5 months ago #6475 by vbs
Crash on OSX was created by vbs
This weekend i had 3 time's in a role a crash with D-Licht 3.0.15
First time by refreshing the midi controller in the setup menu (the USB cable had bin dis connected)
Same thing for the Entecc controller turn the green light off and on then the crash happend.
Third time on the midi controller (Beriinger) i closed two sub-masters at the same time.
Earlier that week i also had a crash using the Iphone true Touch-OSC on d-light.
If the dlicht desk is in RPN mode and i press Channel on the Iphone Dlight crashed.
Later i tried al the same things again and no crash happened.
Some time this make's me little annoying if i have to play life in a play!!!! :sick:
Is there a way to find a crash report some where in the system.
Vincent
13 years 5 months ago #6477 by sl1200mk2
Replied by sl1200mk2 on topic Crash on OSX
can you please specify what OS are you running?
yes, here's where they are located on my computer:
/Users/nico/Library/Logs/DiagnosticReports/DLight_2013-05-13-100050_brouhaha.crash
can you please make .zip of the .crash and post them here?
13 years 5 months ago #6486 by sl1200mk2
Vincent,
are these bugs are reproductible?
did you found the logs?
13 years 5 months ago #6500 by vbs
Replied by vbs on topic Crash on OSX
Hi Nico
I am running on OSX 10.8
I send you the crash report.
The problem:
Happened on 12-05-13
The problem:
Happened on 6&7-05-13
I hope you can find something in the crash report.
Best regards Vincent.
The following user(s) said Thank You: colinc
13 years 5 months ago #6508 by sl1200mk2
@Vincent,
thanx for that, I'll have a look at them.
13 years 5 months ago #6517 by sl1200mk2
this one is the one that worry me...
is it reproductible?
did it happened when you only display used channel in the workspace?
do it happen when you display all the channels?
do u use the command 'only display active submasters' when this crash happen?
13 years 5 months ago #6521 by vbs
* I don't remember if i did but there is a possibility
do u use the command 'only display active submasters' when this crash happen? I don,t understand your question
13 years 5 months ago #6535 by sl1200mk2
first, I've published 3.0.16_b2, can you please do again your tests with this new beta?
it should fix the most worrying bug, but I didn't work on the two others
you can tell DL to display only submasters that have a level.
under the 'RLink' button, press the little blue square to switch submaster's display mode.
Time to create page: 0.346 seconds
