- Thank you received: 1
Fx in step?
- p.leijstra
I already have an effect applied to the submaster. I presses Rlink in the step and I see it at Rlink (target FF) but it does not seem to play when the step is active.
How do I start the effect?
Thnx in advance!
recording MLink with the RLink (RecordLink) is a good thing.
MLink are processed with the GO command.
thus if you have in X2 a step loaded with MLink associated, the next time you press GO, MLink will be triggered.
ps: you'll be able very soon to write all these missing part in the Wiki
- p.leijstra
Mlink are independent of the times registered within the steps, you can for example set a time for a mlink of 20 minutes and have time for a step set to 1 second.Ok, but then it wil only play as long as the fade-in time lasts?
the step will xfade in 1 second and the Linked submaster will fade In(or Out) in 20 minutes.
after that the submaster is opened and you need to set another MLink if you want to close it.
on the next step, you set another MLink to close the submaster that contain the FX.How can I play the FX untill I go to the next step?
- p.leijstra
I'm do not see my Fx playing (I do'nt see the values of the channels changing when I press go) The fx only plays when I set the sub to FF manualy, or is this normal that I don't see it?
Thanks allot!
right.Ok, so on the next step you repeat the mlink, but set the level to 0 in stead of FF?
nope.I'm do not see my Fx playing (I do'nt see the values of the channels changing when I press go) The fx only plays when I set the sub to FF manualy, or is this normal that I don't see it?
can you post your sho to have a look?
- p.leijstra
On step 3 the mlink is added.
Thanks!
in the MLink editor, don't forget to click on 'Valid' to save MLinks (or use the 'Modify' shortcut)
- p.leijstra
here it is again, now with mlink
looks like you've found a bug.
I'm working on Colin's one, and after I'll fix yours.
and after it will be time for a next beta...
- p.leijstra
Is it also possible (maybe in a beta-beta-version) to use the Enttec Pro with the original driver? This because I use the enttec in other software as well. (or would this be very difficult?) In that case the installing of the liusbx driver is also not necessary..
in the setup, when 'Inhib MLink' is active, that means that MLink won't be processed.
idem for 'Inhib Wait Times'
these options are usefull when you want to check particular feature of the sequence without being polluted by subs or whatever.
so unselect the options and you'll see that the sub is fired
on MacOS you can by selecting /dev/usb-serial as 'modus operandi'Is it also possible (maybe in a beta-beta-version) to use the Enttec Pro with the original driver?
BUT, FTDI drivers have a limited size buffer of 1K and in the case of several univers, it leads to error.
so always use libusbx as 'modus operandi' as this lib is chunking memory.
- p.leijstra
I's using the FTDI driver also possible on windows? For now I only use 30 dmx channels, so no real problem with that I suppose
Again great help!
Greets
nope, libusbx is the way I've choose...I's using the FTDI driver also possible on windows?
